Add chip support to EZP2019, EZP2019+, EZP2020, EZP2023, EZP2025, MinPro Programmers
  • rockman97
    • Aug 2025
    • 10
    • Hungary
    Originally posted by m1ch43lzm
    rockman97
    I'll attach the EZP2019+ software for you, downloaded from site linked at 1st post, I don't own this programmer
    The W25Q256FW is listed, it should be compatible, you have to use 1.8V adapter
    I'm really noob for ad this type of chip can i get a help please how can i do it i really want fix this motherboard for myself but i don't really understand what i need to do.
    I had this Windbond 25Q256JWEQ which chip is similar to choose this?
    I tried use chatgpt what i need to add but not really understand how work i tried select the FW version but sadly it 0 when i want read the chip.
    Thank you for the files!
    • Derach
      • Jun 2017
      • 17
      • burkina faso
      thanks for sharing
      • shaddy254
        • Feb 2021
        • 37
        • kenya
        Originally posted by ToNe 36
        here you can find updated version fixed by the developer which he has sent me...no need for locale emulator
        works very well. Thanks for sharing.
        • rockman97
          • Aug 2025
          • 10
          • Hungary
          rockman97
          Thank you for the link maybe i noob but how can i use it i need overwrite databas file from here EZP2019+ database.rar if i does this the program not open and crash.
          If i select W25Q256FW 1.8V with the 1.8v adapter not recognize it. I tried select this
          • m1ch43lzm
            • Mar 2019
            • 1044
            • Peru
            If you're using a clip, it may take few tries to align it properly, even if it looks right sometimes there's 1 or 2 pins that don't make proper contact, make sure you didn't connect the 1.8V adapter or the clip the wrong way, also try lowering the SPI clock speed to 3MHz or even 1.5MHz
            I don't own that programmer so I can't give advice how to use it, sorry, but check some YT videos, couldn't find videos in English for this programmer
            How to use 1.8v adapter (EZP2010, but it's similar)
            https://www.youtube.com/watch?v=eED9r9B89uM
            How to use EZP2019+
            https://www.youtube.com/watch?v=_7l9Ov3cUhY
            https://www.youtube.com/watch?v=ysvZjrYNIdw
            • Elephant Geeks
              • Jun 2024
              • Kenya
              #26
              EZP2025 works but you have to tweak it around ad i did there... You have to use locale editor I sent email to the producer hope he will fix it
              You sir are heaven sent. This worked for me!!!!👊👏
              Problem is programme was coded for chinese/Japanese region so if your ststem locale settings is overseas it will fails.
              Step to fix install error:
              Install Locale Emulator for all users, restart pc.
              Go to program right click. Exe >Locale emulator>Run in Japanese.
              Program will open in Japanese language
              Go to forth tab on top
              Change language to English.
              SUCCESS!!!
              • mr.Data
                • Sep 2018
                • 77
                • Netherlands
                #27
                So I did some research on how to add a new unknown chip to the datase of the EZP2019 software.
                I figured out how to add it as shown in the image.
                It did read the chip when I selected it but after an extremely amount of reading time it said the chip is empty while it actually is not, just came out of a working laptop.
                Some expet advice on BIOS chips would be greatly appriciated
                  SMDFlea commented
                  Editing a comment
                  Thread merged. You might find the answer in this topic.
              • sk3690
                • Jun 2022
                • 9
                When you run EZP2025 English file must use " run as administrator or Open". You get error display.
                • Troystain
                  Help EZP2023+ updated chip database for w25q256jveq?
                  by Troystain
                  Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                  I need to add w25q256jveq chip but I do not know what data should I type.
                  I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                  The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                  11-25-2024, 12:53 AM
                • sume
                  bios chip can not detected on ezp
                  by sume
                  I'm having trouble writing the BIOS to an mXIC MX77U25650F chip using both the EZP2019+ and EZP2023+ programmers. I have tried various connections, but I'm still encountering the same issue. The chip itself is kind of hard to solder. I am using SOP16/8-DIP8 REV4 Board Adapter because it is the only suitable one. How can i fix this issue. The motherboard it belong to is HE430HE530 NM-D481 Rev1.0. And the laptop is Lenovo thinkpad e15 gen3. I fixed many bios chips, but this one is very different.
                  05-03-2025, 04:34 AM
                • ToNe 36
                  EZP2025 Working english program
                  by ToNe 36
                  Hello from Romania here I present you the working EZP2025 without using locale editor sent to me by the developer.
                  It works without having to tweak it with locale emulator..
                  I sent mails to the developer and he was kind enough to send me the fixed version which is not having the richedit error....
                  Please save it and share it on other forums as well as the chinese man said he can not upload it on his website....strange....
                  EZP 2025 works only with this version so it will not work with older versions..........
                  06-21-2025, 01:32 PM
                • pengamat_hebat
                  Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                  by pengamat_hebat
                  I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                  Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                  However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                  I also tried applying 3.3V to pin 3, but it still didn't work.
                  I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                  03-25-2025, 04:13 AM
                • redbaron1007
                  Looking for a way to read this bios chip. Lenovo Yoga 7 16arp8 bios chip.
                  by redbaron1007
                  I'm working on a lenovo yoga 7 16arp8 that had a bad charge port. When I replaced the port the laptops charge light will come on and stay on now, but when I push the power button the power light will come on for a couple seconds and then go right back out. I'm suspecting a bad bios, but when I went to read the bios to start the process of getting a new one it I found that none of my programmers will read the IC. I mainly use a T48 with Xgpro. I also have a ch341 and it's software that I use for ps5 uart and bios's, and a EZP2019+ and it's software.
                  The chip is labeled MXIC MX77u2565ofz4142...
                  10-02-2025, 12:51 PM
