Technical Documentation of Dell Bios Boot Process: Stuck Inspiron E1705
  • sattech200
    • Aug 2012
    • 59
    Afternoon All!
    My question is specifically: Does anyone know where I can find technical documentation on the process of the Dell Bios during boot up?
    I've been kicking around an Inspiron E1705 laptop for more than a year now that I keep meaning to get to. It seems everytime I get started on it something else comes up and I get distracted. This unit will power up but hangs at the dell logo. The progress indicator bar always stops at a 1/3 of the way and then it just sits there. It hangs before any options appear to enter bios, select boot device, etc...
    When this was first given to me the previous owner had ordered a second video card (GPU is a module.) which produced the same symptoms. At that time I also had an identical laptop that worked great. Basically I swapped the motherboard between units and the problem followed MB. The only thing I can't specifically remember doing is a reset of the bios if there is even a way to even do that?
    I am suspecting some type of bios corruption which really caused me to start thinking and questioning. What exactly is the process the dell bios goes through behind the scenes when it boots up? This would help me identify what it's doing at 1/3 of the way when it gets stuck.
    Any thoughts, ideas, or suggestions are greatly welcomed and appreciated.
    Thank you
  • spleenharvester
    • Mar 2010
    • 921
    Re: Technical Documentation of Dell Bios Boot Process: Stuck Inspiron E1705
    Check your AC adapter (is it genuine/middle wire working?) and RAM. Both have caused post screen hangs on my E5500.
    BIOS corruption is quite possible though.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • 3d0
      • Jan 2014
      • 159
      • BiH
      You can reset the BIOS by removing the onboard battery, aka CMOS battery.
      I'm sure there are smarter people here that understand more about what really goes on during the boot process. IIRC during startup the BIOS checks if the gpu, ram etc. is ok, if there is any problems it beeps, or shows a message or maybe even hangs like yours.
      I would test it with another gpu, and start troubleshooting from there, usually removing hadware piece by piece (if for example you have 2x ram modules, test it with just one, then test them in various slots).
      • sattech200
        • Aug 2012
        • 59
        Thanks for the reply's
        As mentioned in my first post I've tried all of those suggestions. "Swapped motherboards between working and bad laptops" which included the Ac Adapter, RAM, 3 different GPU's, etc... In fact all components from bad system were tested good and working on good laptop.
        Unless I'm blind I don't see the battery on the top of the board. Might pull it back out of case in a little while and check bottom side but I'm pretty sure I would have disconnected that when I swapped boards a while back.
        • 3d0
          • Jan 2014
          • 159
          • BiH
          You have a motherboard that gets stuck at the dell logo, and have tested this mb. with components from a working mb? That rules out allot of stuff.
          It's basically a mb. problem now.
          Have you tried removing the onboard batt. first, or replacing it with a good working one?
          Tried updating/flashing the bios?
          • sattech200
            • Aug 2012
            • 59
            Sorry guy's. Just want to clarify that my primary goal with this post is to find information and learn about the inner workings/behind the scenes operations of the specific dell bios in question. I've already narrowed it down to a motherboard problem and want to dig deeper into the problem with the board itself. An understanding of what's going on within the bios during the boot process will help greatly. Can't screw it up any more than it already is.
            Is there a specific trick to updating/reflashing the bios without yanking the chip and using a programer?
            • 3d0
              • Jan 2014
              • 159
              • BiH
              I know there is a usb utility for the dell mini/vostro with which you can recover the BIOS, not sure about the inspiron you have, you might not be so lucky.
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
              • TVAddict
                TCL 40S6500A - stuck in boot process
                by TVAddict
                Hi everyone, i have a TCL 40" that's stuck in the boot process,here's what happens, at first turn on you get the TCL logo after that it goes to the 4 rotating color circles, it does not go beyond this point, the color circles just keep going on, from what i've read and seen on YT apparently it's a firmware/software issue, i'm willing to try a software update via the usb method but have no luck finding a suitable site to download the correct software for my model TCL, i have tried the TCL site with no luck, so the real question is can anyone HELP point me to a reliable source i can download...
                10-27-2024, 08:57 PM
              • futadmytro
                Asus g713qm-es94 stuck on boot bios problem
                by futadmytro
                sn^M4NRKD02753616E
                MB- g533-6050a3250201-MB-A03
                Stuck on boot after ROG logo, did not enter to bios
                In flash bios , laprop boot but have video issue
                orig bios...
                06-25-2025, 08:07 AM
              • ivtec
                Ubuntu 22.04 wont boot stuck in initramfs help
                by ivtec
                Hi folks i installed Win10 in 1 HDD and Unbuntu 22.04 in other HDD and installed Grub manager ,it has been working fine till i installed new updates. now it wont boot and doesn't make recovery either and stuck on initramfs ,i type blkid and get this see pic attac. bellow ,althou it boot in Win10 .Any help will be apreciated ....
                06-02-2025, 10:56 AM
              • Prott
                Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
                by Prott
                Hello fellow Badcappers,
                I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
                I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
                Thank you!
                03-01-2024, 08:23 AM
