Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
  • Prott
    • May 2022
    • 154
    • Czechia
    Hello fellow Badcappers,
    I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
    I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
    Thank you!
  • Prott
    • May 2022
    • 154
    • Czechia
    UPDATE: Indeed, it is a dead ssd
    • praveenramavath
      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
      by praveenramavath
      Hello All,
      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
      https://www.hifivision.com/threads/m...-screen.98243/
      Troubleshooting Summary: Majority Internet Radio - Flash Chip
      04-26-2025, 09:08 AM
    • DynaxSC
      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
      by DynaxSC
      Hi Folks
      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
      09-29-2024, 04:27 PM
    • ivtec
      Ubuntu 22.04 wont boot stuck in initramfs help
      by ivtec
      Hi folks i installed Win10 in 1 HDD and Unbuntu 22.04 in other HDD and installed Grub manager ,it has been working fine till i installed new updates. now it wont boot and doesn't make recovery either and stuck on initramfs ,i type blkid and get this see pic attac. bellow ,althou it boot in Win10 .Any help will be apreciated ....
      06-02-2025, 10:56 AM
    • TVAddict
      TCL 40S6500A - stuck in boot process
      by TVAddict
      Hi everyone, i have a TCL 40" that's stuck in the boot process,here's what happens, at first turn on you get the TCL logo after that it goes to the 4 rotating color circles, it does not go beyond this point, the color circles just keep going on, from what i've read and seen on YT apparently it's a firmware/software issue, i'm willing to try a software update via the usb method but have no luck finding a suitable site to download the correct software for my model TCL, i have tried the TCL site with no luck, so the real question is can anyone HELP point me to a reliable source i can download...
      10-27-2024, 08:57 PM
    • ohren
      Samsung UE32D6515WS — boot loop + what does this pixel pattern suggest?
      by ohren
      I'm trying to determine the nature of these faults and whether they're coincidental or in fact connected.
      Symptom 1: boot looping, showing logo and then going blank, backlight turning on for 2 s or 14 s intermittently, and arriving at logo again after approx 1 minute. Never appears to boot fully.
      Symptom 2: vertical lines across whole screen while logo showing. Every 4th pixel column.
      Backlight seems to work fine and is lit while logic board is disconnected. 12v, 5V seem stable and only dip when the system resets.
      System still seems to reboot...
      02-17-2024, 07:20 PM
