Dell Vostro 3420 BIOS Password Removal
  • kimarth21
    • Jan 2020
    • 12
    • Philippines
    please help me unlock device freeze
    dell latitude 3420 device freeze 7332
    st: 726FXL3
      • 21472
      st: 726FXL3
      This thread is for the Vostro .Post your request in the latitude 3420 thread --> https://www.badcaps.net/forum/troubl...assword-unlock
      • spider300
        • Apr 2022
        • 35
        • morocoo
        Hello. Ive got problem with Dell Vostro 3420. After power on, no display . Standard job, I exported a clean bios from update via pfs extract.
        Steps i done and results:
        I exported a clean bios from update file via pfs extract.
        1. Build clean bios with clean ME, PMC, PCH in flash image tool.
        Result: Dead
        2. Build clean bios with no changes in ME, new PMC, PCH
        Result: Dead
        3. Build old bios with clean ME, new PMC, PCH
        Result: The same
        GDM51 LA-L242P Rev:1.0(A00) 2021-07-04
        ST:HJ5LB24
        In the attachment i give you original dump. I would be grateful for any tips on building batches in new generations - maybe I don't know something.
        • peste
          peste commented
          Editing a comment
          merged post..
      • OmanCloud
        • Aug 2023
        • 17
        • Oman
        Hi Brothers
        please Help me remove password
        Dell Inspiron 15- 3520
        LA-L946P-REV;1.0
        Service Tag : 8CLNVH3
        hoca peste
Name:	WhatsApp Image 2025-06-19 at 5.36.36 PM.jpg
        • lapfix
          • Mar 2020
          • 2750
          • my workshop
          Originally posted by OmanCloud
          Hi Brothers
          LA-L946P-REV;1.0
          hoca peste
          Click image for larger version  Name:	WhatsApp Image 2025-06-19 at 5.36.36 PM.jpg Views:	0 Size:	1.45 MB ID:	3664366
          1st boot, press F2, write service tag, disable Absolute, save, restart.
          2nd boot press Alt+F to exit manufacturing mode.
          Good luck.
          • OmanCloud
            • Aug 2023
            • 17
            • Oman
            #26
            Good luck.
            Caps lock Blinking no Display
            • lapfix
              • Mar 2020
              • 2750
              • my workshop
              #27
              I guess you try without cmos..the unlock file is OK..verify again
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • 417731
                BIOS needed for Dell Vostro 3405
                by 417731
                Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                Model: Dell Vostro 3405
                Tag:F0B1YF3
                CPU:Ryzen 3500U
                Thanks in advance
                07-06-2025, 06:48 PM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
