HP 840 g10 bios
  • Duckie-Electronics
    • Jun 2025
    • 10
    Originally posted by Duckie-Electronics
    Oh yes, main from post # 120 and updated EC on post # 156. Flashed both.
    Hey rex98 and lapfix, I have confirmed process on second device. The process I used is what is noted in post # 120
    1. Take full BCU config dump
    2. Flash EC chip with EC_NVRAM_CLEAR.BIN from post # 156
    3. Flash SPI Main with MAIN CLEAN UNLOCKED.bin from post # 120
    4. first boot press f10 apply factory defaults and restart.
    5. 2nd boot reset security settings to defaults and exit.
    6. use BCU and put your original DMI. I had to add the following:
    Product Name
    Serial Number
    SKU Number
    System Board CT Number
    Feature Byte
    Build ID
    HBMA Factory MAC Address
    HBMA System MAC Address
    Cirrus Discrete Amp Calibration Data
    • lapfix
      • Mar 2020
      • 2744
      • my workshop
      #162
      Product Name
      Serial Number
      SKU Number
      Feature Byte
      Build ID
      That's one BIG step for 'a' man. 😎
      Very good news...We can now try same processsus for others lap..
      A BIG thank man​
      • jafasbay@gmail.com
        • May 2019
        • 19
        • mocambique
        #163
        Originally posted by rex98
        i cant download post 120 ,can u send
        • rex98
          • Feb 2023
          • 1282
          • Mandaue CEBU, Philippines
          #164
          use the post # 161
          • jymmytuan95
            • Jan 2021
            • 30
            • Viet Nam
            #165
            I NEED BIOS, EC HP 840 G10..BIOS ORIGINAL Caps Lock blinking 3 long and 2 short.
            6050A3452701-MB-A01
            SN: 5CG3333NDL
            • minhdigital
              • Nov 2022
              • 758
              • Vietnam
              #166
              6050A3452701-MB-A01
              SN: 5CG3333NDL
              Send to you, try
              • jymmytuan95
                • Jan 2021
                • 30
                • Viet Nam
                #167
                Originally posted by minhdigital
                Send to you, try
                TKS BRO.STILL THE SAME. BLINK 3 LONG 2 SHORT
                  SMDFlea commented
                  Editing a comment
                  check for loose ram slot pins
              • kouider
                • Sep 2023
                • 12
                • Maroc
                #168
                Try and report
                • jymmytuan95
                  • Jan 2021
                  • 30
                  • Viet Nam
                  #169
                  RAM CONTACT LEGS AND WELDING JOINTS ARE BRIGHT AND BEAUTIFUL.STILL THE SAME. BLINK 3 LONG 2 SHORT
                  • jymmytuan95
                    • Jan 2021
                    • 30
                    • Viet Nam
                    #170
                    Originally posted by kouider
                    Try and report
                    TKS BRO.STILL THE SAME. BLINK 3 LONG 2 SHORTKS BRO.STILL THE SAME. BLINK 3 LONG 2 SHORT
                    • quyet306
                      • Oct 2014
                      • 65
                      • saigon
                      #171
                      Managed to solve the issue. I modified your EC.bin provided in post # 120 and cleared NVRAM ActiveRegn.
                      This time, instead of the EC recovery screen, it threw the "Entering MPM" and was able to F10.
                      Password now gone. You are a legend rex98.
                      Probably best to verify attached before use.
                      hi bro. can i ask how to modify EC in case? i have HP G9 12th same problem. thankyou
                        • Jun 2025
                        • 10
                        Sorry for the late reply.. do a search in EC for ActiveRegn, it will have "Nvram" before it. clear from the words ActiveRegn to the end of the data (when it starts back to a block of FF)
                        i have since found a youtube video by Borvi Tech called "Hp EliteBook 840 G8 Bios Unlock Step by Step 100% Free" where he shows graphically how to do it about 22 minutes into the video on a G8.
                        be sure to get a back up bin copy first, not sure what other ramifications this procedure has.
                        • black0hackers
                          • Jul 2020
                          • 367
                          i do like that on 640 g11, after clear nvram on EC laptop no display on
                          • bbcc
                            • Aug 2024
                            • 16
                            • pakistan
                            #174
                            plz if someone have 840 g10 motherboard can tell me this resistance value
                            • peste
                              peste commented
                              Editing a comment
                              post in the main section here is the "bios only requests" section..this post will be deleted....
                          • nafienew
                            • Aug 2014
                            • 92
                            • up
                            #175
                            pleas need remove password
                            elitebook 840 g10
                            sn 5CG4194CT4
                              • 21241
                              elitebook 840 g10
                              sn 5CG4194CT4
                              Read this post and the following 8 after that https://www.badcaps.net/forum/troubl...67#post3656067 ,then unlock it yourself.
                              • zuping.guan
                                • Sep 2016
                                • 16
                                #177
                                Originally posted by Bios Cracker
                                Try and Update.
                                Serial Number: C2L34606QZ
                                Product #/SKU: 9C8A0UC#ABA
                                CT Number: PRTUK00WBIH0ER
                                Description: HP EliteBook 840 14 inch G10
                                BuildID: 23WWWGBZ602#SABA#DABA
                                Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPfXguhKhkjhk8mEn7nVngpDpFpVpnpqprqMqkqz.5G
                                MAC Address: 64:4E7:53:62:1F
                                its working
                                • Bzubairu
                                  • Aug 2023
                                  • 9
                                  • Nigeria
                                  #178
                                  Please my hp 840 g10 is asking for bios respond code.
                                  S/n - 5CG4262D0Q
                                  Board no - WARG-MV-TRIPOD 6050A3452701-MB-A01
                                  I ATTACHED THE MAIN BIOS FILE
                                  • antturo
                                    • Aug 2025
                                    • 3
                                    • France
                                    #179
                                    I have a HP EliteBook 845 G10 and I have 2 issues :
                                    - first one : in red at start system is booting in manufacturing program mode but I filled every ID in BIOS
                                    - second one : I'm getting Cirrus Discrete Amp Calibration Data error and I don't know how to fix it (image attached )
                                    serial number: 5CG43026XZ
                                    • peste
                                      peste commented
                                      Editing a comment
                                      post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                    • peste
                                      peste commented
                                      Editing a comment
                                      just post everywhere, stay here and wait for a response
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • dchandler@lifetimeservice
                                    BIOS unlock or decrypt password for Asus S533F serial L6N0CV190141266
                                    by dchandler@lifetimeservice
                                    Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
                                    Current BIOS firmware version is X521FA-305
                                    Thank you!...
                                    07-02-2025, 11:32 AM
                                  • salim5566
                                    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                    by salim5566
                                    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                    06-26-2025, 03:25 PM
