HP 840 g10 bios
i don't know what you're saying, but the DMI is from your bios so it hould work USE bcuMột vấn đề nữa, tôi đã thêm tất cả ID hệ thống để thoát khỏi chế độ sản xuất, nhưng bây giờ tôi gặp lỗi Thông tin sản phẩmMPMkhông hợp lệ. Thông tin sản phẩm sau đây được lập trình trong bo mạch hệ thống bị thiếu hoặc không hợp lệ
Cirrus Discrete Amp Calibration Data
Nhấn phím cách để tiếp tục hoặc "Y" để nhập thông tin còn thiếuComment
I think more information is needed
3000000002000000536B0601D3350B00C08BDF3A4EF2D90117013728536C0601D3350B003044513C4EF2D9011701C428
still thank you very much
anyone please help me unlock this bios HP ELITEBOOK 840 G10. thankyou
SN: C2L339044YAttached FilesComment
first boot press f10 reset bios to factory defaults (restart) 2nd boot reset security settings to defaults.
Use BCU to fill these DMI info:
Serial Number: C2L339044Y
Product #/SKU: 86T52US#ABA
CT Number: PRTUR00WBIF5TX
Description: HP EliteBook 840 14 inch G10
BuildID: 23WWWGBZ601#SABA#DABA
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBapaqauawb8bUbhcAfPguhKhkjhk8mEn7nVngpDpVpnpqprqMqkqz.3t
Thank you it working
Can I ask where you got the DMI information?Comment
Hello please need bios unlock for HP elitebook 840 G10
SN: 5CG3237HV1Attached FilesComment
here is your unlocked file
1st boot go to bios (f10) perform factory default setupAttached FilesComment
need another dump bios unlock for HP elitebook 840 G10
SN: 5CG3237G7YAttached FilesComment
here is your 2nd file dont forget to perform this
greetings family please help me remove absolute enable
SERIAL NUMBER / 5CG35006TCAttached FilesComment
MMMAttached Files↵
https://www.badcaps.net/donateComment
Hello, I need Help with my Locked BIOS on HP Elitebook 840 G10.
SN: 5CG3334N15
PROD ID: 6V5Z4AV
THANK YOUAttached FilesComment
very important steps:
1. First boot go to bios setup (f10)
2. Perform apply factory default setup
3. FeedBack here if it worksAttached FilesComment
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
Asus S533F serial L6N0CV190141266
Current BIOS firmware version is X521FA-305
Thank you!...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
