HP 840 g10 bios
  • minhdigital
    • Nov 2022
    • 765
    • Vietnam
    Originally posted by trunguntilyou
    Một vấn đề nữa, tôi đã thêm tất cả ID hệ thống để thoát khỏi chế độ sản xuất, nhưng bây giờ tôi gặp lỗi Thông tin sản phẩm
    MPM
    không hợp lệ. Thông tin sản phẩm sau đây được lập trình trong bo mạch hệ thống bị thiếu hoặc không hợp lệ
    Cirrus Discrete Amp Calibration Data
    Nhấn phím cách để tiếp tục hoặc "Y" để nhập thông tin còn thiếu
    Send to you
    • rex98
      • Feb 2023
      • 1293
      • Mandaue CEBU, Philippines
      MPM
      i don't know what you're saying, but the DMI is from your bios so it hould work USE bcu
      • trunguntilyou
        • Aug 2022
        • 362
        • Vietnam
        Originally posted by minhdigital
        Send to you
        I filled in all the information you sent and it was successful! Thank you very much,, but how did you get all the information?
        • trunguntilyou
          • Aug 2022
          • 362
          • Vietnam
          I think more information is needed
          3000000002000000536B0601D3350B00C08BDF3A4EF2D90117013728536C0601D3350B003044513C4EF2D9011701C428
          still thank you very much
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            after resetting bios factory default and security setting , just flash back original bios. no need to use BCU or MPM tool
            • quyet306
              • Oct 2014
              • 69
              • saigon
              #26
              anyone please help me unlock this bios HP ELITEBOOK 840 G10. thankyou
              SN: C2L339044Y
              • rex98
                • Feb 2023
                • 1293
                #27
                SN: C2L339044Y
                first boot press f10 reset bios to factory defaults (restart) 2nd boot reset security settings to defaults.
                Use BCU to fill these DMI info:
                Serial Number: C2L339044Y
                Product #/SKU: 86T52US#ABA
                CT Number: PRTUR00WBIF5TX
                Description: HP EliteBook 840 14 inch G10
                BuildID: 23WWWGBZ601#SABA#DABA
                Feature Byte: 476J6S6b7B7H7M7R7W7m7saBapaqauawb8bUbhcAfPguhKhkjhk8mEn7nVngpDpVpnpqprqMqkqz.3t
                • quyet306
                  • Oct 2014
                  • 69
                  • saigon
                  #28
                  Thank you it working
                  Can I ask where you got the DMI information?
                  • farouk_1994
                    • Mar 2021
                    • 399
                    • algeria
                    #29
                    Hello please need bios unlock for HP elitebook 840 G10
                    SN: 5CG3237HV1
                    • alfredposadas09
                      • Aug 2020
                      • 342
                      • Philippines
                      #30
                      SN: 5CG3237HV1
                      here is your unlocked file
                      1st boot go to bios (f10) perform factory default setup
                      • farouk_1994
                        • Mar 2021
                        • 399
                        • algeria
                        #31
                        your dump work for me like charm thank you sir
                        • farouk_1994
                          • Mar 2021
                          • 399
                          • algeria
                          #32
                          need another dump bios unlock for HP elitebook 840 G10
                          SN: 5CG3237G7Y​
                          • alfredposadas09
                            • Aug 2020
                            • 342
                            • Philippines
                            #33
                            SN: 5CG3237G7Y​
                            here is your 2nd file dont forget to perform this
                            • farouk_1994
                              • Mar 2021
                              • 399
                              • algeria
                              #34
                              Think's bro it's work
                              • lavie
                                • Aug 2015
                                • 90
                                • southafrica
                                #35
                                greetings family please help me remove absolute enable
                                SERIAL NUMBER / 5CG35006TC
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12362
                                  #36
                                  MMM
                                  • lavie
                                    • Aug 2015
                                    • 90
                                    • southafrica
                                    #37
                                    Originally posted by hoaca388
                                    MMM
                                    THANK YOU VER MUCH
                                    • vladprogressive
                                      • Oct 2023
                                      • 5
                                      • Italia
                                      #38
                                      Hello, I need Help with my Locked BIOS on HP Elitebook 840 G10.
                                      SN: 5CG3334N15
                                      PROD ID: 6V5Z4AV
                                      THANK YOU
                                      • alfredposadas09
                                        • Aug 2020
                                        • 342
                                        • Philippines
                                        #39
                                        SN: 5CG3334N15
                                        PROD ID: 6V5Z4AV
                                        THANK YOU
                                        very important steps:
                                        1. First boot go to bios setup (f10)
                                        2. Perform apply factory default setup
                                        3. FeedBack here if it works
                                          • 22035
                                          Does this apply to all models that have been unlocked this way.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • dchandler@lifetimeservice
                                            BIOS unlock or decrypt password for Asus S533F serial L6N0CV190141266
                                            by dchandler@lifetimeservice
                                            Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
                                            Current BIOS firmware version is X521FA-305
                                            Thank you!...
                                            07-02-2025, 11:32 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
