hp 640 g10 password bios
Off topic, this thread is for the 640 g10 .Please read the rules before posting https://www.badcaps.net/forum/troubl...before-posting
hp 640 g10 password bios need help
Serial number: 5CD419CFHW
Attached both main and ec dump
Attached Filesif you find these attachements useful please consider making a small donation to the site
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CD419CFHW
Product #/SKU: 736K1AV
CT Number: PRVNV108JJI05N
Description: HP EliteBook 640 14 inch G10
BuildID: 23WWKRBZ602#SACQ#DACQ
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPfXguhKhkjhk8mEmVn7nVpDpTpnpqprqMqz.FY
MAC Address : 18:93:41:8D:0C:11
Hi, I need help with HP EliteBook 640 14 inch G10
S/N: 5CD3494JSW
Prod Id: 941U3EC#ABY
MB: DA0X8TMB8E0 REV.E
Bios has password, I did usual modifications to enter in MPM mode, it enters in MPM mode but when I try to load factory defaults it doesn't reset Administrator Password field, it stays at "Change Administrator Password". I can't reset Security to defaults because is asking for password.
I did try to downgrade bios version but can't find proper MFIT Tool, it was made with 16.1.27.2236
I attach main and EC backups, maybe someone with more experience can help me, thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
try this. same procedure at first boot apply factory defaults and exit.Hi, I need help with HP EliteBook 640 14 inch G10
S/N: 5CD3494JSW
thanks but id doesn't work, applying factory defaults it doesn't reset Admin Password. Also, I noticed that if I set up a Power-on password resetting to factory defaults in MPM mode it doesn't reset power-on pass too. I will read bios with power on pass and compare with original one to see where is stored power on pass maybe I'll figure out where Admin pass is stored.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
i think it needs vssstore cleaning. so that auto reset security settings.
thanks but id doesn't work, applying factory defaults it doesn't reset Admin Password. Also, I noticed that if I set up a Power-on password resetting to factory defaults in MPM mode it doesn't reset power-on pass too. I will read bios with power on pass and compare with original one to see where is stored power on pass maybe I'll figure out where Admin pass is stored.Comment
try this flash both
same procedure but try reformating first then use bcu to reset security settings to defaults. this doesn't have mac address so don't forget to input the mac in HBA in bcu.Attached Filesif you find these attachements useful please consider making a small donation to the site
your files brings laptop to a new level of sh*t. It makes identity data recovery and doesn't enter in MPM mode. Of course, BCU doesn't allow me to modify anything without password.
But thanks anyway for sharing your work.Attached Filesif you find these attachements useful please consider making a small donation to the site
Send to you, try !!Attached Filesif you find these attachements useful please consider making a small donation to the site
thank you. With your files laptop won't start (5xblinks caps lock), I cleaned ME but same thing, but ... with your EC file and and older version of bios (V75 ver.1.02.03) with clean ME I was able to put it in MPM mode and clear Admin password. Thanks again!
Now please help me with EC file from this post, same problem, data identity recovery and not entering in MPM mode:
https://www.badcaps.net/forum/troubl...rd#post3449845----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Congratulation
Hello everyone, how are you? I saw that you have already managed to help some people, and I have a problem here at the company, an HP 640 G10 notebook which they put a password on the BIOS and it only shows on the screen: "BIOS ADMINISTRATOR PASSWORD" Enter Password. I don't know how to solve it.
When you click F10, you go directly to the part that asks for the password.Comment
you have to read main and EC chipsets, post files here.Hello everyone, how are you? I saw that you have already managed to help some people, and I have a problem here at the company, an HP 640 G10 notebook which they put a password on the BIOS and it only shows on the screen: "BIOS ADMINISTRATOR PASSWORD" Enter Password. I don't know how to solve it.
When you click F10, you go directly to the part that asks for the password.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
I’m also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by ArkzGHey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
What I currently have available:
- Model: FA506NF (2021)
- BIOS chip: GD25LQ16 (16Mbit/2MB)
- Tools: CH341A programmer ready to use
Does anyone have either a clean 2MB .bin dump of this model,...-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
