hp 640 g10 password bios
  • its service
    • Feb 2021
    • 144
    • india
    Originally posted by rex98
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    here's your DMI:
    Serial Number: 5CD3459JD4
    Product #/SKU: 9F4G4PA#ACJ
    CT Number: PRVNR048JIS4WY
    Description: HP EliteBook 640 14 inch G10
    BuildID: 23WWKRBZ602#SACJ#DACJ
    Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nVpDpVpnpqprqMqz.3e
    MAC Address : D0:AD:08:9A:21:10​
    Thanks a lot sir, bios password removed
    • jbrane
      • Jun 2024
      • maroc
      INFORMATION NON VALIDE SUR HP ZBOOK FIREFLY 14 G9
      SN : 5CG31113GK
    • andrew25
      • Feb 2016
      • 223
      • Malawi
      hp 640 g10 password bios need help
      Serial number: 5CD419CFHW
      Attached both main and ec dump
      • rex98
        • Feb 2023
        • 1289
        • Mandaue CEBU, Philippines
        here's your DMI:
        Serial Number: 5CD419CFHW
        Product #/SKU: 736K1AV
        CT Number: PRVNV108JJI05N
        BuildID: 23WWKRBZ602#SACQ#DACQ
        Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPfXguhKhkjhk8mEmVn7nVpDpTpnpqprqMqz.FY
        MAC Address : 18:93:41:8D:0C:11
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          Hi, I need help with HP EliteBook 640 14 inch G10
          S/N: 5CD3494JSW
          Prod Id: 941U3EC#ABY
          MB: DA0X8TMB8E0 REV.E
          Bios has password, I did usual modifications to enter in MPM mode, it enters in MPM mode but when I try to load factory defaults it doesn't reset Administrator Password field, it stays at "Change Administrator Password". I can't reset Security to defaults because is asking for password.
          I did try to downgrade bios version but can't find proper MFIT Tool, it was made with 16.1.27.2236
          I attach main and EC backups, maybe someone with more experience can help me, thank you.
          • rex98
            • Feb 2023
            • 1289
            #26
            S/N: 5CD3494JSW
            try this. same procedure at first boot apply factory defaults and exit.
            • volinakis
              • Jan 2021
              • 2872
              • N/A
              #27
              thanks but id doesn't work, applying factory defaults it doesn't reset Admin Password. Also, I noticed that if I set up a Power-on password resetting to factory defaults in MPM mode it doesn't reset power-on pass too. I will read bios with power on pass and compare with original one to see where is stored power on pass maybe I'll figure out where Admin pass is stored.
                SMDFlea commented
                Editing a comment
                Compare the EC as well for changes
            • rex98
              • Feb 2023
              • 1289
              #28
              i think it needs vssstore cleaning. so that auto reset security settings.
              • rex98
                • Feb 2023
                • 1289
                #29
                try this flash both
                same procedure but try reformating first then use bcu to reset security settings to defaults. this doesn't have mac address so don't forget to input the mac in HBA in bcu.
                • volinakis
                  • Jan 2021
                  • 2872
                  • N/A
                  #30
                  try this flash both
                  if Admin pass is set can't use BCU to reset anything, it will ask for pass ...
                  • rex98
                    • Feb 2023
                    • 1289
                    #31
                    i tried just now on 845 g10. it works in this procedure the problem is just the cirrus calibration data so i input it and it works all.
                    • volinakis
                      • Jan 2021
                      • 2872
                      • N/A
                      #32
                      cirrus calibration data is just for laptop with touchscreen
                      • volinakis
                        • Jan 2021
                        • 2872
                        • N/A
                        #33
                        try this flash both
                        your files brings laptop to a new level of sh*t. It makes identity data recovery and doesn't enter in MPM mode. Of course, BCU doesn't allow me to modify anything without password.
                        But thanks anyway for sharing your work.
                        • rex98
                          • Feb 2023
                          • 1289
                          #34
                          opps my bad, maybe hoacca could solve this.
                          • minhdigital
                            • Nov 2022
                            • 764
                            • Vietnam
                            #35
                            Send to you, try !!
                            • volinakis
                              • Jan 2021
                              • 2872
                              • N/A
                              #36
                              Originally posted by minhdigital
                              Send to you, try !!
                              thank you. With your files laptop won't start (5xblinks caps lock), I cleaned ME but same thing, but ... with your EC file and and older version of bios (V75 ver.1.02.03) with clean ME I was able to put it in MPM mode and clear Admin password. Thanks again!
                              Now please help me with EC file from this post, same problem, data identity recovery and not entering in MPM mode:
                              https://www.badcaps.net/forum/troubl...rd#post3449845
                              • minhdigital
                                • Nov 2022
                                • 764
                                • Vietnam
                                #37
                                Congratulation
                                • andreybr
                                  • Sep 2024
                                  • Brasil
                                  #38
                                  Hello everyone, how are you? I saw that you have already managed to help some people, and I have a problem here at the company, an HP 640 G10 notebook which they put a password on the BIOS and it only shows on the screen: "BIOS ADMINISTRATOR PASSWORD" Enter Password. I don't know how to solve it.
                                  When you click F10, you go directly to the part that asks for the password.
                                  • volinakis
                                    • Jan 2021
                                    • 2872
                                    • N/A
                                    #39
                                    you have to read main and EC chipsets, post files here.
                                    • Sarowar
                                      • Sep 2024
                                      • 3
                                      • Bangladesh
                                      #40
                                      I cant change bois to factory setting its ask for password can you help me please
                                      • Buzzfuzz2k
                                        Bios password removal on a Unowhy dump
                                        by Buzzfuzz2k
                                        Hi Everyone,
                                        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                        the Computer is a Unowhy small pc
                                        N° UYM6524702229
                                        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                        My first attempt was to get the bios dump from windows...
                                        11-13-2023, 07:37 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • ArkzG
                                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                        by ArkzG
                                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                        What I currently have available:
                                        - Model: FA506NF (2021)
                                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                        - Tools: CH341A programmer ready to use
                                        Does anyone have either a clean 2MB .bin dump of this model,...
                                        09-26-2025, 09:34 PM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • outsider
                                        Panasonic FZ-G1 MK5 - BIOS password returning
                                        by outsider
                                        Hello
                                        I removed the BIOS password thanks to the help of one of the friends of this forum.
                                        https://www.badcaps.net/forum/troubl...61#post3637661
                                        The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                        06-17-2025, 12:51 AM
