lenovo n500 bios dump
  • asliyucegsm
    • Jun 2011
    • 351
    • Turkiye
    my friend
    lenovo n500
    mainboard.JIWA3 LA-4212P
    REV.2.0
    Intel processor
    thanks
  • tomodachi
    • Apr 2012
    • 615
    • Turkey
    Re: lenovo n500 bios dump
    here my friend
    • deenx
      • Mar 2015
      • 4
      • Ukraine
      hey guys, did you managed to recover your lenovo n500?
      I have quite similar platform: lenovo g530 3000 with the same mobo flashed with incorrect bios rom.
      tomodachi posted wph file, but it's not dump. wph also contains some service information for flasher tool....
      anyway - did you recovered your bios by flashing chip using programmer either via crisis disk (or other similar disks)?
      Thanks in advance,
      Denys.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        backup old bios and try this
        Compal JIWA3 LA-4212P
        Im Back... sort of...
        • deenx
          • Mar 2015
          • 4
          • Ukraine
          Hi Guys,
          Thanks for the files, but I've already disassembled the laptop, soldered out flash and connected it to a Sivava Programmer (Willem) and programmed a correct bin from lenovo off site...
          This is the only thing worked for me.
          Trying to recover with Crisis disk (lots of various combination) - failed.
          Cheers,
          Denys.
          • deenx
            • Mar 2015
            • 4
            • Ukraine
            BTW, I have JIWA4 mobo..
            • mirjana
              • Jun 2015
              • 26
              • Serbia
              Hi! I have lenovo g530 (JIWA3 LA-4212P REV.2.0). After putting damaged ribbon cable for display (I didn't see that flat is damaged in first place) laptop keeps turning off. Just turn on led lights and cooler for few seconds, and turn off. I found that IC power chip (at least I think that is IC power chip) for that few sec was extremly hot. Mark of that chip is 'ene kb926qf -d3'. I think that must change. I need to know is cause or consequence? I hop you'll understand me and answer me Thanks
              • ibrahim_yas
                Banned
                • Nov 2015
                • 20
                • 86159159666
                • tamankar
                  • Oct 2013
                  • india
                  thank u
                  • chaker752000
                    • Mar 2016
                    • 48
                    • tunis
                    • dolunay79
                      • Oct 2016
                      • 18
                      • turkey
                      • mndmnd
                        • May 2010
                        • 6
                        • monishcompare
                          • Jan 2017
                          • 3
                          • india
                          thanks
                          • nhat_nam1986
                            • Jul 2015
                            • 4
                            • VIETNAM
                            This LA-4212P rev2.zip OK. Thanks SIR!! VGA Shared.
                            • Syed Wasiq Hussain
                              • Jul 2022
                              • 13
                              • Pakistan
                              Working bios thanks.
                              • AHmad_Salal
                                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                by AHmad_Salal
                                Hello all,
                                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                11-28-2023, 05:28 AM
                              • Ahari
                                by Ahari
                                I...
                                08-13-2025, 06:12 AM
                              • hyperwood
                                [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                by hyperwood
                                I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                āœ… What I need:
                                • A working 2MB BIOS dump
                                • Matching NM-E471 Rev. 2.0, e.g. JY575
                                06-25-2025, 02:28 PM
                              • mkdj
                                by mkdj
                                Dear all,
                                10-19-2025, 04:41 AM
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
