Laptop only boots after bios reset?
  • gilly1984
    • Jun 2012
    • 751
    Got a lappy off ebay that needed the charging port resoldering.
    Did that and it worked fine, but upon shutting down the only way to boot it back up is to remove the battery, press power button, put battery back in and then press power button again and it will boot fine.
    When I got it I put a dual core cpu in it, this was before the charger arrived so I didnt test it before with the original cpu in it. Could this cause it?
    It also had vista installed but I put windows 7 on it instead, again, I didnt test it before the charger arrived. Could the wrong os cause it?
    I have never come accross the 2 above changes causing problems like this before so any help would be great.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Laptop only boots after bios reset?
    Mate why you are moving forward with guess work and not by making volt measurements to the points that mater ?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Hi Kiriakos GR perhaps gilly does not have a great experience of this laptop.
      Perhaps you can assist by telling him where to test and what result he should expect?
      Gilly does it charge the battery? does it work ok with only the battery?
      does it work with only the charger, or is it the type that has to have a battery in.
      • gilly1984
        • Jun 2012
        • 751
        I don't have the laptop to hand until tomorrow.
        the laptop works great when switched on. it works on battery and on ac. it charges the battery fine too. the only problem occurs when I shut it down, I have to reset the bios before it will switch on again.
        I will tinker tomorrow when I have it in my possession.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          One of the reasons that BIOS can hang on boot its due empty BIOS battery,
          check this too, or better replace it immediately with a new.
          • dj_ricoh
            • 2073
            • uk
            hello!
            I`m 100% that somebody work on that notebook and forgot the ac or battery connected.(yes someone made a short)
            why i`m saing this because i made this mistake to and touch the mb with wifi wires and guess what it will not power untill i reset the bios.
            i`ll be around with the progress on thisthread and prepare my notebook to so we can work together.
            P.s. mine its a Asus A55
            • coumcoum
              • Dec 2015
              • 36
              • algerie
              hello
              any solution pleas ?
              • String2016
                • Nov 2015
                • 2238
                • philippines
                does anyone have a solution on this i have the same issue
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Try switching the mb(with cmos battery installed) directly from kbc switching pin. Does it turns on this way??
                  • YG007
                    Asus BIOS How To Reset To Default Settings?
                    by YG007
                    Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                    I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                    06-05-2023, 08:22 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • llek100
                    HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
                    by llek100
                    Hello, sorry for the long post, I just wanted to include any details that might help.
                    A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
                    I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
                    So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
                    First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically...
                    09-18-2024, 09:15 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • Wahaz
                    by Wahaz
                    10-30-2023, 08:42 PM
