2022 Zephyrus G14 GA402RK BIOS + IC
  • Madokami
    • Oct 2023
    • 6
    I have a G14 GA402RK that I (stupidly) changed the wrong settings on and now does not post. I changed the SOC power and the Above 4G MIMO limit.
    The device fans will ramp up and down as the temp rises, and the keyboard lights up, but the nothing else happens. It also powers up when plugged into the AC power but not USB or battery power. All of this makes me think it still works, I just need to slap a new BIOS on it.
    I tried identifying the IC with a CH341A programmer, but I could only find the GPU BIOS. I also read somewhere on this forum that Asus has used multi-IC BIOS solutions in the past, which makes this more fun for a newbie like me.
    Attached are pictures of the board, and the code behind the RAM slots which I think identifies the motherboard. If anyone can help me identify the BIOS IC and how to burn the new image on it if it's not a standard 8 pin IC, I would be very appreciative. Any and all help would be appreciated actually.
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    Re: 2022 Zephyrus G14 GA402RK BIOS + IC
    there are 3 eeproms on your board, I think one from the left is Bios chipset - the middle is VBios and on the right is TBT. Take a clear photo of the code on chipset.
    • Madokami
      • Oct 2023
      • 6
      The one on the left is 24512A P21A02 and the one on the right is 24512A P21A03. Middle one is GD PJ2133, and is the one I got the gpu info from.
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        yep, not bios chipset any of them. Maybe is on back of the motherboard, I will search on net.
        Edit: can't get a clear image but i think that's the one
        • Madokami
          • Oct 2023
          • 6
          Yep, that's it. Winbond 74m25jweiq. I don't think the alligator clips will be able to grab this and I don't think I have the skill to desolder it. Is there any advice or a different method of reading/writing that you can recommend?
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            nope, just remove it and read with adapter. Attention, is 1,8V chipset. See if you have some jumpers around ram slots to reset it, if you say you only changed something in settings.
            • Madokami
              • Oct 2023
              • 6
              There are no jumpers on the motherboard, which is why I was looking to rewrite the BIOS. Removing the battery for an extended period did not help either. It would be nice if there were contacts on the board I could short to clear CMOS, but I don't see any and don't know enough to start poking around without guidance.
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                sorry, I don't have clear images of your motherboard to start looking for reset pads.
                Remove CMOS battery and hold power button for 30s to drain all current left in capacitors, maybe it will reset bios.
                • Madokami
                  • Oct 2023
                  • 6
                  Unfortunately there's no cmos battery. I've tried removing the battery and letting it sit overnight, and that did not work. Here is a picture of the back side if that will help.
                  • Akstorm02
                    • Apr 2025
                    • 3
                    • Algeria
                    Hey ! Did you find a bios image ? If you did I'm having similar issues if you can send me the bios image it would be very nice i have asus g14 ga402rk Ryzen 9 6900hs and rx6800s 2022
                    • GigElectron
                      • Apr 2020
                      • 4
                      Hi there. Please note that you are missing RTQ5132GQWF (chip marked as 0H=). It is an integrated power management IC suitable for general DDR5 SODIMM and UDIMM applications. I hope this helps.
                      • pizrat
                        • Jul 2025
                        • 4
                        Originally posted by fallbelow
                        i bricked my bios using the smokeless umaf tool and trying to tighten ram timings. i purchased a ch341a programmer and made the mistake of not backing up my bios before flashing the stock bios on the chip. i tried injecting my serial and all in the bios and then flashing but now the hdd light just blinks when powering on and nothing else. ill attach the firmware i flashed to the chip and the default i added it to. also the chip is a winbond W74M25JWEIQ. my serial is N2NRKD019645059
                        I know I'm reviving a zombie topic, but did you ever get your bios working again? I bought a GA402RK online that's exhibiting the same symptoms. When attempting to power on, the HDD blinks once then waits about 5-8 seconds, then blinks again and just loops like this. It doesn't matter if it's plugged in to wall power or running off of battery. I tried disconnecting all peripherals and the SSD to see if it acts differently but it doesn't. Any advice or help would be greatly appreciated!
                          SMDFlea commented
                          Editing a comment
                          Moved from GA402RJ topic to GA402RK
                      • peste
                        • Dec 2016
                        • 13747
                        • ROMANIA
                        post S/N, full name and model, motherboard model, ,etc.
                        post the contents of the bios chip even if it is corrupted..
                        Post a picture of the QR code near the ram slot, or scan it yourself and post what it says.
                        • hichamhb
                          • Jun 2019
                          • 94
                          • morocco
                          HI . i want to repair this bios ( no display )
                          Model: Asus ROG Zephyrus G14
                          SN : N3NRKD011930106
                          Motherboard: mb ga402rk ddr5x16 r2.2
                            SMDFlea commented
                            Editing a comment
                        • shiyab
                          • Sep 2023
                          • 1647
                          • india
                          hi try
                          • pizrat
                            • Jul 2025
                            • 4
                            Sorry for the delay. Here's the information:
                            • SN: N7NRKD02370427C
                            • Asus Zephyrus G14 (Model: GA402R)
                            • GA402RJ-G14.R96700
                            • Motherboard Model: GA402RK R2.1
                            Attached pictures are of the Model Number sticker, Serial Number Sticker, Motherboard Model and Revision, and QR code next to RAM slot. I checked voltages and have 20v on the main rail where I should. I checked for shorts and couldn't find any with a thermal camera and with a multimeter. I've tried swapping hardware out. Doesn't matter if it's powered by battery, charger, or thunderbolt. I've tried holding the power button for 30-60 seconds to reset the EC. No matter what I try, the laptop will only flash the HDD status light every 7-10 seconds. Fans never spin up and no keyboard or display backlights come on. My NVME drive has an LED status light that DOES come on during boot but goes out when the laptop starts it's boot cycle all over again. It's acting like it's attempting to boot and gets to a certain point in the process before resetting again. I'm hoping it just needs a new BIOS at this point. I can measure 20v going all the way to the mosfets right before the CPU and GPU but nothing is coming out of them. Thank you in advance for any and all help. I'm really banging my head trying to fix this laptop.
                            • shiyab
                              • Sep 2023
                              • 1647
                              • india
                              hi try
                              • hichamhb
                                • Jun 2019
                                • 94
                                • morocco
                                Originally posted by shiyab
                                hi try
                                thank you so much
                                • pizrat
                                  • Jul 2025
                                  • 4
                                  hi try
                                  Thank you! Unfortunately, I tried it and there's still no change with my issue. I fear I may have a problem with the EC chip or something else that's flying under the radar :/
                                  • ub6ib969
                                    • Jul 2010
                                    • 201
                                    hi, unit powers on, no post no caps lock.
                                    SN : N3NRKD02100319b
                                    thanks in advance.
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • evilgenius31
                                      Zephyrus G14 GA401QH-211 Bios missing serial number
                                      by evilgenius31
                                      Hi All,
                                      I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
                                      Serial: M4NRKD01530915H
                                      Thanks in advance!...
                                      11-10-2025, 03:58 PM
                                    • BlackVisor
                                      How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                      by BlackVisor
                                      RedmiBook Pro 1542022 6800H
                                      SKU: TM2113-39463
                                      Model Number: RMA2204-AB
                                      CMIIT ID: 2022AP1835
                                      SN: 39463/22WD01355
                                      BIOS version: RMARB5B0P1010 20230628
                                      1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                      2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                      3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                      01-14-2024, 06:35 AM
                                    • Akstorm02
                                      Asus ga402rk-5w bios
                                      by Akstorm02
                                      Hello! I'm in desperate need right now if you can help me i would be very thankful. My laptop which is the same as the one you mentioned;ga402rk-5w,SN:N8NRKD002088342. has stopped working for no reason and after troubleshooting the hardware i came to the conclusion that the problem is in the bios i think i have a corrupted bios the laptop turns on but it doesn't boot or get to the bios even. I need a complete bios image to flash into the bios chip and hope for the best that it turns on. I didn't have an idea this could actually happen that's why i didn't take any back up of my bios when i first...
                                      04-06-2025, 07:25 AM
