Asus ga402rk-5w bios
  • Akstorm02
    • Apr 2025
    • Algeria
    Hello! I'm in desperate need right now if you can help me i would be very thankful. My laptop which is the same as the one you mentioned;ga402rk-5w,SN:N8NRKD002088342. has stopped working for no reason and after troubleshooting the hardware i came to the conclusion that the problem is in the bios i think i have a corrupted bios the laptop turns on but it doesn't boot or get to the bios even. I need a complete bios image to flash into the bios chip and hope for the best that it turns on. I didn't have an idea this could actually happen that's why i didn't take any back up of my bios when i first bought the laptop. If anyone can help send their bios image as soon as possible it would be a great help.
  • Akstorm02
    • Apr 2025
    • Algeria
    This is a picture to further identify my system specification ( Ryzen 9 6900hs rx6800s if this information is helpful)
    • hoaca388
      Badcaps
      • Jan 2022
      • 12392
      In repairing and restoring bios, keeping the original bios is the most important. So upload the original bios even if it is broken.
        • 22077
        Post a picture of the QR code or barcode sticker on the motherboard
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • Newmultifail
          Asus g750jx Bios turns off after 30 minutes
          by Newmultifail
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
          I should mention that the bios update did not help.
          backup i sn...
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
          12-19-2024, 03:41 PM
