Dell g5 se 5505
  • DangerDude
    • Sep 2024
    • 6
    I erased the original contents (all FFs) of the bios file, since I thought it was garbage. However, the files I downloaded from this thread are all 16,384 Kb, where I need it for 8 Mb. How do you get this file to write to the chip if the size is too large?
      • 21048
      What is the part number on the 8MB chip.
      • DangerDude
        • Sep 2024
        • 6
        GigaDevice
        25Q80CSIG
        UE 9979
        AJ 2044
          • 21048
          GigaDevice
          25Q80CSIG
          UE 9979
          AJ 2044
          The 25Q80CSIG is 8 Mega bits , not Mega Bytes. 8 Mega bits is 1MB (Mega Bytes) . You have made a mistake there and erased the wrong chip. The golden rule of bios programming is to always make a good backup. If you didn`t make one then you`ll need to find,or someone to post that 1MB dump to flash back to that chip. Post a picture of the area on the board where that chip is.
          • DangerDude
            • Sep 2024
            • 6
            If you didn`t make one then you`ll need to find, or have someone post the 1MB dump to flash back to that chip. Post a picture of the area on the board the location of the chip.​
            Apparently the Winbond W25Q128FWSQ 128M-bit (16MB) chip is the correct bios. I did take the motherboard to a local computer shop that wrongly indicated that the GigaDevice GD25Q80CSIG chip on the other side of the motherboard was the correct chip (see image). Coincidently, another GigaDevice 25Q80CTIG (8M-bit) chip is located near the Winbond chip on the front side of the motherboard. Thank you for clarifying the correct chip and size for me. Any help to revive the bios for the GD25Q80CSIG will be greatly appreciated.
            • kezza87
              • May 2020
              • 5
              #26
              Hi, Please can you help with this Bios. Need the Latest or Clean Bios. I am getting black screen, New LCD and getting error lights (2 Amber Light 7 White Lights error code)
              Service Tag - JL72W93
              Thank you
              • volinakis
                • Jan 2021
                • 2741
                • N/A
                #27
                Thank you
                Try
                • kezza87
                  • May 2020
                  • 5
                  #28
                  Originally posted by volinakis
                  Try
                  Thank you. The Bios seems to work but still no display just a black screen. DELL self test works and screen flashes different colours but will not boot and still shoes error. I was hoping latest Bios from DELL would fix the issue. was release a few days ago.
                  • volinakis
                    • Jan 2021
                    • 2741
                    • N/A
                    #29
                    bios image is extracted from latest bios update (1.24.0) with your DMI in it. Your backup is 1.15.0, try this version of bios extracted from update.
                    • kezza87
                      • May 2020
                      • 5
                      #30
                      Working. Thank you very much for your help.
                      • volinakis
                        • Jan 2021
                        • 2741
                        • N/A
                        #31
                        you are welcome
                        • DangerDude
                          • Sep 2024
                          • 6
                          Recently used a Selek MLK AMD 19802-1 FGRDN$JA to confirm that that the GD25Q8OCSIG (8M-bit) chip is blank. I've attached the backup bios from my motherboard (Selek MLK AMD 19802-1 FGRDN$LA) to see if anyone could create a clean bios from the latest bios update (1.24.0). Thank you.
                          Service Tag: 7ZWDF63​
                          • shiyab
                            • Sep 2023
                            • 1503
                            • india
                            #33
                            hi try
                            • DangerDude
                              • Sep 2024
                              • 6
                              Thank you, shiyab for the bios file you sent me. Works perfectly.
                              • kaseak
                                • Nov 2021
                                • 9
                                #35
                                hi i need a bios for my dell g5 5505
                                G5 5505
                                System BIOS : 1.20.0
                                Service Tag: B826C63
                                Version :
                                Build 4400.16 UEFI ROM
                                ​is restarting on dell logo
                                • shiyab
                                  • Sep 2023
                                  • 1503
                                  • india
                                  #36
                                  G5 5505
                                  Version :
                                  hi try
                                  • kaseak
                                    • Nov 2021
                                    • 9
                                    #37
                                    hi shiyab i try but same thing i will leave the ariginal file , the problem is rebooting after dell logo
                                    • shiyab
                                      • Sep 2023
                                      • 1503
                                      • india
                                      #38
                                      It's canfom bios check hardware
                                      • kaseak
                                        • Nov 2021
                                        • 9
                                        #39
                                        thanks any clue what can be ? it look like everything work
                                        • shiyab
                                          • Sep 2023
                                          • 1503
                                          • india
                                          #40
                                          chip
                                          • lalle-
                                            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                            by lalle-
                                            Hello!
                                            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                            08-11-2024, 02:01 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
