Please unlock bios HP Zbook Firefly 14 G9
  • Mehmet Korhan
    • May 2024
    • 31
    Here is my info, does anyone know how to remove SWAT lock? Says DeviceFreeze-3472
    HP ZBook Firefly 14 inch G9
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001​
      SMDFlea commented
      Editing a comment
      Thread merged with existing topic.
  • minhdigital
    • Nov 2022
    • 765
    • Vietnam
    #42
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001​
    Send to you
    • Mehmet Korhan
      • May 2024
      • 31
      Originally posted by minhdigital
      Send to you
      Hey! Thank you but it's still giving the same message. DeviceFreeze-3472
      Locks the screen and says it's been reported lost.
      • Concord2022
        • Aug 2022
        • 17
        • nigeria
        #44
        Pls remove password
        SN 5CG312OH52
        • b4rdock
          • Jun 2017
          • 106
          • usa
          #45
          please unlock this bios password plz
          SN: 5CG3282ZHK​
          • plk113
            • Nov 2022
            • 32
            • VietNam
            #46
            Try and Replay
            • b4rdock
              • Jun 2017
              • 106
              • usa
              #47
              Originally posted by plk113
              Try and Replay
              hi the laptop turn on and turn off i wait but never turn on again can check the files plz
              thanks
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                #48
                SN: 5CG3282ZHK​
                use HP BCU to read DMI with original bios. (you'll find videos on youtube or guide here in this forum). Write the file I provided and at 1st boot enter bios setup with F10 and in MAIN tab reset bios to factory defaults. After that use again BCU to write DMI back.
                • Robert Pryor
                  • Mar 2025
                  Please, help me remove bios lock for HP Zbook Firefly 14 G9 with Serial# 5CG3161CFB
                  I am providing 2 bin files, one from each 25W256JVEN chip I found. One chip is located at the front and the other chip is located on the back of the motherboard.
                  I am not sure which files is needed, so I am providing both.
                  Thank you kindly.
                  I also faced the similar problem but now everything is good.
                  • b4rdock
                    • Jun 2017
                    • 106
                    • usa
                    #50
                    thanks but this dont work , laptop dont turn on
                    can check it again plz
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      #51
                      if doesn't turn on it means either you didn't solder chipsets properly or you didn't make good backups of bios chipsets.
                      • malangg
                        • Sep 2014
                        • 34
                        • United Kingdom
                        #52
                        Please unlock password and turn on mpm mode thanks in advance
                        here is all info
                        serial: 5CG31726H2
                        • b4rdock
                          • Jun 2017
                          • 106
                          • usa
                          #53
                          i try your advise to re-solder again the chips and still dont turn on friend i reprogram the original and video work bios original files its ok always read 3 times friend
                          question, i find these bios file and works remove password but i cant re install the OS because not detect the ssd maybe you can clear region me that will fix the problem ? or you recomend me unlock the original files ?
                          i attached here files if you can help me plz regards
                          • b4rdock
                            • Jun 2017
                            • 106
                            • usa
                            #54
                            this is main bios or ec bios ?
                            • laptopvn
                              • Mar 2022
                              • 12
                              • Việt Nam
                              #55
                              Please help me delete password.
                              SN: 5CG30613SV
                              • laptopvn
                                • Mar 2022
                                • 12
                                • Việt Nam
                                #56
                                Originally posted by qayyum786
                                Try again and make sure you follow the steps
                                I compared the file and changed as you did, but still can't reset DMI to remove password for HP G9-G10.
                                • rex98
                                  • Feb 2023
                                  • 1293
                                  • Mandaue CEBU, Philippines
                                  #57
                                  SN: 5CG30613SV
                                  here's your unlocked file
                                  first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                  use BCU
                                  dmi:
                                  Serial Number: 5CG30613SV
                                  Product #/SKU: 7Y1Y0UP#ABA
                                  CT Number: PQDHA00WBHN02C
                                  Description: HP ZBook Firefly 14 inch G9
                                  BuildID: 22WWWPAT602#SABA#DABA
                                  Feature Byte: 476J6S6b7B7M7R7U7W7m7saBaEapaqauawbUbhcAdpdqfPguhKhWhkjhk8mEmGn7nVngpDpVpppqqj.yB
                                  MAC Address : 7C:4D:8F:3A:B1:A6​
                                  • quyet306
                                    • Oct 2014
                                    • 69
                                    • saigon
                                    #58
                                    Please unlock my HP Zbook Firefly 14inch G9
                                    SN: 5CG3161H0D
                                    thankyou
                                    • Anden Gris
                                      • Jul 2025
                                      • Costa Rica
                                      #59
                                      Hi, I'd like to reopen this thread. I have the same model, but when I log in with F10, the first thing it asks for is the administrator password, and there's no reset option. Three attempts and it freezes.
                                      HP ZBook Firefly 14-inch G9 Mobile Workstation PC
                                      SKU Number 74Z93UP#ABA
                                      System Board CT Number PRJKE00WBHZ0K7
                                      Is there any other way to reset it? Thanks for the reply.
                                      • peste
                                        • Dec 2016
                                        • 13691
                                        • ROMANIA
                                        #60
                                        not...
                                        • zlr8r
                                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                          by zlr8r
                                          Greetings
                                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                          Serial Number: 5CG3202C16
                                          Product #/SKU: 739P0AV
                                          CT Number: PRTUE00WBI30YX
                                          Description: HP ZBook Firefly 14 inch G10
                                          BuildID: 23WWWGAZ602#SABU#DABU
                                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                          MAC address not found.
                                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                          10-28-2025, 01:56 PM
                                          HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • CeeEee4
                                          HP ZBOOK FIREFLY 14 G10 A (AMD) Corrupt BIOS
                                          by CeeEee4
                                          Hello
                                          I have an HP ZBOOK FIREFLY 14 G10 A (AMD) model with HP Blink Error 2-2 (Main area DXE of BIOS has become corrupted and no binary recovery image available.) I have tried BIOS recovery USB but it didnt work.
                                          Tried using a "clean" bin extracted from the HP softpaq but laptop would not even respond to power button, although it had white LED on DC jack.
                                          Here is back up of the BIOS, hope somebody can help. Thanks
                                          09-16-2025, 09:07 AM
                                        • Andrew Bower
                                          BIOS Unlock for HP zbook studio x360 g5
                                          by Andrew Bower
                                          I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                          That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                          12-04-2024, 05:55 PM
