Please unlock bios HP Zbook Firefly 14 G9
    Here is my info, does anyone know how to remove SWAT lock? Says DeviceFreeze-3472
    HP ZBook Firefly 14 inch G9
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001
      SMDFlea commented
      Editing a comment
      Thread merged with existing topic.
    #42
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001
    Send to you
      Originally posted by minhdigital View Post
      Send to you
      Hey! Thank you but it's still giving the same message. DeviceFreeze-3472
      Locks the screen and says it's been reported lost.
        Pls remove password
        SN 5CG312OH52
          please unlock this bios password plz
          SN: 5CG3282ZHK
            Try and Replay
              Originally posted by plk113 View Post
              Try and Replay
              hi the laptop turn on and turn off i wait but never turn on again can check the files plz
              thanks
                SN: 5CG3282ZHK
                use HP BCU to read DMI with original bios. (you'll find videos on youtube or guide here in this forum). Write the file I provided and at 1st boot enter bios setup with F10 and in MAIN tab reset bios to factory defaults. After that use again BCU to write DMI back.
                  Please, help me remove bios lock for HP Zbook Firefly 14 G9 with Serial# 5CG3161CFB
                  I am providing 2 bin files, one from each 25W256JVEN chip I found. One chip is located at the front and the other chip is located on the back of the motherboard.
                  I am not sure which files is needed, so I am providing both.
                  Thank you kindly.
                  I also faced the similar problem but now everything is good.
                    thanks but this dont work , laptop dont turn on
                    can check it again plz
                      if doesn't turn on it means either you didn't solder chipsets properly or you didn't make good backups of bios chipsets.
                        Please unlock password and turn on mpm mode thanks in advance
                        here is all info
                        serial: 5CG31726H2
                          i try your advise to re-solder again the chips and still dont turn on friend i reprogram the original and video work bios original files its ok always read 3 times friend
                          question, i find these bios file and works remove password but i cant re install the OS because not detect the ssd maybe you can clear region me that will fix the problem ? or you recomend me unlock the original files ?
                          i attached here files if you can help me plz regards
                            this is main bios or ec bios ?
