Please unlock bios HP Zbook Firefly 14 G9
  • Mehmet Korhan
    • May 2024
    • 31
    Here is my info, does anyone know how to remove SWAT lock? Says DeviceFreeze-3472
    HP ZBook Firefly 14 inch G9
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001​
      SMDFlea commented
      Editing a comment
      Thread merged with existing topic.
  • minhdigital
    • Nov 2022
    • 717
    • Vietnam
    #42
    SN: 5CG3014FGF
    M/B SPS: N22219-601
    WARPATH-MB-AVARY
    6050A3417601-MB-A01
    32MB DUMP ATTACHED
    Winbond 25Q256JVEN
    2217
    6146
    2C40001​
    Send to you
    • Mehmet Korhan
      • May 2024
      • 31
      Originally posted by minhdigital
      Send to you
      Hey! Thank you but it's still giving the same message. DeviceFreeze-3472
      Locks the screen and says it's been reported lost.
      • Concord2022
        • Aug 2022
        • 17
        • nigeria
        #44
        Pls remove password
        SN 5CG312OH52
        • b4rdock
          • Jun 2017
          • 95
          • usa
          #45
          please unlock this bios password plz
          SN: 5CG3282ZHK​
          • plk113
            • Nov 2022
            • 31
            • VietNam
            #46
            Try and Replay
            • b4rdock
              • Jun 2017
              • 95
              • usa
              #47
              Originally posted by plk113
              Try and Replay
              hi the laptop turn on and turn off i wait but never turn on again can check the files plz
              thanks
              • volinakis
                • Jan 2021
                • 2603
                • N/A
                #48
                SN: 5CG3282ZHK​
                use HP BCU to read DMI with original bios. (you'll find videos on youtube or guide here in this forum). Write the file I provided and at 1st boot enter bios setup with F10 and in MAIN tab reset bios to factory defaults. After that use again BCU to write DMI back.
                • Robert Pryor
                  • Mar 2025
                  Please, help me remove bios lock for HP Zbook Firefly 14 G9 with Serial# 5CG3161CFB
                  I am providing 2 bin files, one from each 25W256JVEN chip I found. One chip is located at the front and the other chip is located on the back of the motherboard.
                  I am not sure which files is needed, so I am providing both.
                  Thank you kindly.
                  I also faced the similar problem but now everything is good.
                  • b4rdock
                    • Jun 2017
                    • 95
                    • usa
                    #50
                    thanks but this dont work , laptop dont turn on
                    can check it again plz
                    • volinakis
                      • Jan 2021
                      • 2603
                      • N/A
                      #51
                      if doesn't turn on it means either you didn't solder chipsets properly or you didn't make good backups of bios chipsets.
                      • malangg
                        • Sep 2014
                        • 34
                        • United Kingdom
                        #52
                        Please unlock password and turn on mpm mode thanks in advance
                        here is all info
                        serial: 5CG31726H2
                        • b4rdock
                          • Jun 2017
                          • 95
                          • usa
                          #53
                          i try your advise to re-solder again the chips and still dont turn on friend i reprogram the original and video work bios original files its ok always read 3 times friend
                          question, i find these bios file and works remove password but i cant re install the OS because not detect the ssd maybe you can clear region me that will fix the problem ? or you recomend me unlock the original files ?
                          i attached here files if you can help me plz regards
                          • b4rdock
                            • Jun 2017
                            • 95
                            • usa
                            #54
                            this is main bios or ec bios ?
                            • laptopvn
                              • Mar 2022
                              • 12
                              • Việt Nam
                              #55
                              Please help me delete password.
                              SN: 5CG30613SV
                              • laptopvn
                                • Mar 2022
                                • 12
                                • Việt Nam
                                #56
                                Originally posted by qayyum786
                                Try again and make sure you follow the steps
                                I compared the file and changed as you did, but still can't reset DMI to remove password for HP G9-G10.
                                • rex98
                                  • Feb 2023
                                  • 1234
                                  • Mandaue CEBU, Philippines
                                  #57
                                  SN: 5CG30613SV
                                  here's your unlocked file
                                  first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                  use BCU
                                  dmi:
                                  Serial Number: 5CG30613SV
                                  Product #/SKU: 7Y1Y0UP#ABA
                                  CT Number: PQDHA00WBHN02C
                                  Description: HP ZBook Firefly 14 inch G9
                                  BuildID: 22WWWPAT602#SABA#DABA
                                  Feature Byte: 476J6S6b7B7M7R7U7W7m7saBaEapaqauawbUbhcAdpdqfPguhKhWhkjhk8mEmGn7nVngpDpVpppqqj.yB
                                  MAC Address : 7C:4D:8F:3A:B1:A6​
                                  • quyet306
                                    • Oct 2014
                                    • 62
                                    • saigon
                                    #58
                                    Please unlock my HP Zbook Firefly 14inch G9
                                    SN: 5CG3161H0D
                                    thankyou
