repair my surface pro 4 because my touch is not working
  • fugo5
    • Apr 2023
    • 6
    i tried the last 3 days to repair my surface pro 4 because my touch is not working.
    I think i tried all the different possibilities from here. Thanks to all of you.
    I have a few last questions.
    1. Is it possible to repair the touch with special bios ?
    2. How can i get my own bios ?
    3. I dont find my ime 11.0.11.1006 to download, only for money.
    4. I put all edited bios on a bootable usb stick and start it, something happend but the problem is the same, no working touch.
    I will very thankful for an answer.
    Excuse me for my bad english. (60+)
    Surface pro 4 i5 8GB 256 GB.
    • 20932
    Re: repair my surface pro 4 because my touch is not working
    Is the laptop bootable into windows,have you tried installing any updates.
    • fugo5
      • Apr 2023
      • 6
      thanks for your fast repond.
      Yes its bootable into winows. All updates are installed. It works fine but without touch
      • fugo5
        • Apr 2023
        • 6
        Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
        after a looong search i think i found the right bin file and i modified it for my surface pro 4.
        I take it on a bootable usb stick and run it.
        My touch still not working. What do i wrong !?
        Anyone an idea.
          • 20932
          Anyone an idea.
          Post your original unmodified backup
          • fugo5
            • Apr 2023
            • 6
            Hello SMDflea,
            thanks for your answer.
            I have no oriinal bios. I dont now how to get it. Need i a spi prorammer ? Is an USB programmer possible?
            i tried it with fptw64 at cmd. But it failed.
            At my uefi IMe is 11.0.11.1006. I found a similar bios and i modified it like here discribed.
            Now the bios looks like the picture in an other post. But if i use it at a bootable Stick something installed (change). But the touch not working
            Maybe its a Hardware mistake. Then i stop my and your efforts.
            Thanks a lot.
            My device Surface pro 4 i5 8 GB 256 GB
            Firmware
            System uefi 109.3748.768
            SAM Controller 103.1837.257
            Intel Management Engine 11.0.11.1006
            Touch Firmware 1.51.149.106.104.36
            System Embedded Controller 103.2851.256
            Infineon dTPM 5.62.31262
            • fugo5
              • Apr 2023
              • 6
              maybe its possible to look at my modified bin file above a last time.
              My surface pro 4 i5 8GB 256 GB 1724. The touch is still not working.
              My IME is 11.0.11.1006. Whats the different between this file and an original bios ?
              Is it the serial nr. of my device ? I tried to change the serial nr. by hex editor. But no working touch.
              I only wanna know it.
              Thanks a lot.
              Thanks a lot for your answer.
              • ahmypc
                • Oct 2013
                • 78
                • Turkey
                I have that same problem. The original bios was damaged during the update. Surface ME device cannot start and update. I can't open bios file with FIT.
                • Cerberuska
                  • Mar 2022
                  • 21
                  Only with an SPI programmer.
                  I used my serial programmer and I have BIOS, but its saying it doesn't not contain contain Intel Engine Firmware. Nor ISHC.
                  Any suggestion what I need to do with this BIOS. Serial Number are correct.
                  Thank you
                  It is winbond 25Q128 Flash Contain
                    • 20932
                    Thank you
                    Try this one.
                    And if it doesn`t work:
                    https://www.badcaps.net/forum/showthread.php?t=104153
                    *You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
                    EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
                    • Cerberuska
                      • Mar 2022
                      • 21
                      Try this one.
                      Thank you very much,
                      I appreciate your time
                      I will keep you posted
                      • Cerberuska
                        • Mar 2022
                        • 21
                        Try this one.
                        I did it, I program BIOS, all good except touch, I Restore, update, no touch and only still Failed Update on ME, needs to restart and it is same after restart and for Touch same, need restart and after restart its need restart. See pictures. If I can program directly the fw I would do it, but looks like there is no way. Maybe MS doing this to increase sell for new tablets...
                        • jozlar
                          • Mar 2022
                          • 59
                          • tbilisi
                          I did everything, the touch screen works and there is no more code. Put in the old one and I will help you.
                          • anjelics
                            • Sep 2014
                            • 15
                            • Romania
                            Jozlar, can you help me with this BIOS? touchscreen not working, I try to modify bios like in link but no result. This is original BIOS
                            • Gabriel Lucas
                              microsoft surface pro 5 touch screen not working
                              by Gabriel Lucas
                              Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
                              02-18-2025, 09:24 AM
                            • obelix24
                              Macbook Air 2020 (a2179) - touch id not working
                              by obelix24
                              Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                              I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                              02-09-2025, 12:57 PM
                            • iprotech
                              Surface Pro 5/6 Touch Issue
                              by iprotech
                              Started with a surface pro 5 repair with battery not fully disconnected and ended with dead touch. Tested with a new touch module and new cable and there still is no touch.
                              Measured touch power rails 1v8 and 5v, both are present.
                              From schematics and boardview it seems like everything happens over SPI, the i2c is NC
                              The MOSI goes directly to the CPU through a 10ohm resistor
                              MISO also goes to CPU through a 10 ohm resistor but also goes through some buffer/level converter chip (VC125) for SPI sniff im guessing for panel brightness level.
                              I do not have a scope,...
                              05-01-2024, 12:54 PM
                            • Thedan55
                              Surface pro 5 no touch
                              by Thedan55
                              I have a surface pro 5 that the customer tried replacing battery on their own.
                              They destroyed the display fpc connector, WiFi antenna and cracked the screen.
                              l've replaced the connector and got display back up but no touch. Replaced the digitiser board with 2 others still no touch. Replaced the screen 3 times still no touch
                              The digi connector on the board is perfect from what l've tested and l've also replaced both flex cables too.
                              Anyone got any ideas? Thanks...
                              08-26-2024, 11:39 AM
                              Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                              This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 08:47 AM
