Surface Pro 5/6 Touch Issue
  • iprotech
    • Nov 2019
    • usa
    Started with a surface pro 5 repair with battery not fully disconnected and ended with dead touch. Tested with a new touch module and new cable and there still is no touch.
    Measured touch power rails 1v8 and 5v, both are present.
    From schematics and boardview it seems like everything happens over SPI, the i2c is NC
    The MOSI goes directly to the CPU through a 10ohm resistor
    MISO also goes to CPU through a 10 ohm resistor but also goes through some buffer/level converter chip (VC125) for SPI sniff im guessing for panel brightness level.
    I do not have a scope, ive relaced vc125 still no touch. The conductive tape on the touch board is making good contact with metal of panel.
    Is the SPI bus on the CPU blown?
  • mon2
    • 14894
    Test each line of the SPI lines using diode mode.
    Remove all power (!)
    Meter in diode mode. Red meter probe to ground.
    Black meter probe to test point.
    Post each measurement.
    • iprotech
      • Nov 2019
      • usa
      MOSI and MISO both 0.556 with red on ground
      Looks good
      • mon2
        • 14894
        Yes. Also check the SPI CS line which should also be present for this interface.
        • iprotech
          • Nov 2019
          • usa
          All lines were good, I ordered a second surface and killed the touch seemingly after removing the touch board. I kept the lcd fully connected and only unplugged the fpc after power was removed. When I tested it after disassembly it was working in UEFI, after removing touch board touch was dead again. Upon installing windows and updating all drivers touch reappeared. The original surface still has a touch issue. I did not get a chance to do a full windows reinstall. Im trying to figure out how to reinstall the firmware/bios and Ive read about the ME issue. Leaving me pretty confused.
          • Prott
            Surface Pro 4/5 - no touch after LCD change
            by Prott
            I have a question that's driving me a bit nuts recently.
            Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
            - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
            - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
            01-25-2023, 12:42 PM
            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
            09-06-2024, 08:10 PM
            Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
