Help with Lenovo P52_20MA BIOS
  • OntarioTL
    • Feb 2022
    • 45
    I've been refurbishing some P52 laptops and performed a BIOS update to which after it was completed, somehow created a POST loop (system configuration change Rebooting). Can't get into BIOS Settings or boot menu. It allows me to select them but just reboots.
    I have backed up the BIOS image, and tried some clean ME bios files from here hoping I would get some life back into it. No luck.
    I've tried to compare files with HEX editors and yeah it sees many differences but not sure what I am looking for.
    Can some wizard help here? If you can fix one file and if it works, maybe I can find what they did to get it going.
    I even tried to use the clean ME guide, but Win-RAID site is not working for me right now. However, not even sure it is an ME issue.
    If someone can help, that would be awesome! If needed the complete model # and Serial
    20MA-S25B1L PF-1L1S8V
    Oh yeah, I need to donate to contribute to the forum.
  • hardware1
    • Sep 2021
    • 2887
    • N/A
    Re: Help with Lenovo P52_20MA BIOS
    Here's your New BIOS, try it and let me know.
    all donations are welcome,
    • OntarioTL
      • Feb 2022
      • 45
      Hardware1, you are a wizard!!!
      I'm assuming this BIOS you shared was just a clean ME version you had archived without repairing the file I had? Just trying to learn, not just expect someone else to always fix it for me.
      If so, it worked that's all that matters. However, I was just curious to know what the hell happened to the original BIOS during the update and what was damaged.
      Either way, thank you very much.
      • hardware1
        • Sep 2021
        • 2887
        • N/A
        Good to know that, You're Welcome.
        No, I have repaired your dump file by replacing the BIOS Region with the one with is provided by Lenovo, inserted your Windows key from the dump file then cleaning the ME Region.
        • OntarioTL
          • Feb 2022
          • 45
          Good to know. The ME region would make sense as I tried the file on another unit that was exact as the first one and it worked on it as well. Feel better for not having to ask for help on the other two units. Replacing the BIOS region is a little higher expertise I don't have yet not to mention the proper software.
          However, now that you mentioned what you did, I guess the windows key will carry to the other laptop too, both activated so it wont matter.
          Funny thing is both laptops in BIOS report the same internal MAC address which I thought was hardware level and cannot be changed. Strange and learn something new everyday. At least the UUID was different between the two. Both are connected to the same network and no conflicts.
          • big G
            • Nov 2020
            • 20
            Hello
            I have an issue with Lenovo P52_20MA it will not post with no video
            The bios is corrupt can it be repaired using Lenovo bios update
            Any help will be appreciated
            model 20ma s1mb00
            s/n pf 1dtnem
            original bios
            P52 20MA PF1DTNEM.zip
            • SHONE984
              • Mar 2022
              • 33
              • stockholm
              Originally posted by SMDFlea
              Re: Lenovo P52 BIOS needed
              Another bios to try .
              good day sir. Is it possible to turn off computrace on my laptop Lenovo P52
              • SHONE984
                • Mar 2022
                • 33
                • stockholm
                That should still be under warranty.
                Get Lenovo to fix it. BIOS is not supposed to get corrupt merely by shutting down while it's booting an OS. (if it was performing a BIOS update that's something else though)
                • volinakis
                  • Jan 2021
                  • 2610
                  • N/A
                  yep, it's possible but follow the rules and post serial number.
                  • SHONE984
                    • Mar 2022
                    • 33
                    • stockholm
                    of course
                    type 20ma-s0mt03 SN PF-1mrj6e pasword 12345
                    • volinakis
                      • Jan 2021
                      • 2610
                      • N/A
                      of course
                      remove password and read again bios chipset.
                      • SHONE984
                        • Mar 2022
                        • 33
                        • stockholm
                        done
                        • volinakis
                          • Jan 2021
                          • 2610
                          • N/A
                          done
                          try this one
                          • SHONE984
                            • Mar 2022
                            • 33
                            • stockholm
                            try this one
                            thank you very much volinakis.just tried your file but still computrace is activated
                            • volinakis
                              • Jan 2021
                              • 2610
                              • N/A
                              sorry, usually invalidating AbtState from VSS Store do the trick but I couldn't find it in your bios. however, I did find company name (ram**ll) in MFS area from ME and thought cleaning ME will solve the problem. You can use Lenovo DXE Patcher maybe will allow you to disable Absolute. https://www.badcaps.net/forum/showthread.php?t=87588
                              • SHONE984
                                • Mar 2022
                                • 33
                                • stockholm
                                sorry to bother you, but is it possible to have computrace located in this small file
                                • compuline
                                  • Jun 2023
                                  • 30
                                  • egypt
                                  I need remove this message "this computer is equipped with computrace lenovo p52
                                • compuline
                                  • Jun 2023
                                  • 30
                                  • egypt
                                  this sn PF1FAZBA
                                  • OntarioTL
                                    • Feb 2022
                                    • 45
                                    this sn PF1FAZBA
                                    I know this is a 32Mb file, but I believe you can still use Autopatcher to remove the password. From my experience, it also wipes the computrace as well. So if you add a password to your P52 (one you remember) and pull the BIOS image again, then run autopatcher to remove the password and computrace at the same time. You cannot run autopatcher without a supervisor password which is why I mention to add a password before proceeding.
                                    • XXS
                                      • Jan 2024
                                      • 4
                                      Hello
                                      can anyone help me with SVP, autopatcher did not run...
                                      Lenovo P52 20MA (S/N PF1MQ0ZW), Chip MX25L25673G​
                                      can i see the password in the .bin file, so i can remove it manually?
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • grimacelord
                                        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                        by grimacelord
                                        Hello there.
                                        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                        History:
                                        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                        I searched for this error online and discovered...
                                        03-15-2023, 03:29 PM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • 1g0r
                                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                        by 1g0r
                                        First, the data in brief:
                                        Manufacturer: Lenovo
                                        Model: ThinkPad L15 G3 21C3-0016GE
                                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                        IC Bios 1: MX77L25650F
                                        IC Bios 2​: MX25L25673G
                                        EC Chip: NPCX997KAABX
                                        So far I've been a silent reader, but now I need your help
                                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                        01-18-2025, 02:39 AM
                                      • abhorsen
                                        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                        by abhorsen
                                        Hey guys,
                                        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                        07-06-2023, 10:22 AM
