Help with Lenovo P52_20MA BIOS
    I've been refurbishing some P52 laptops and performed a BIOS update to which after it was completed, somehow created a POST loop (system configuration change Rebooting). Can't get into BIOS Settings or boot menu. It allows me to select them but just reboots.
    I have backed up the BIOS image, and tried some clean ME bios files from here hoping I would get some life back into it. No luck.
    I've tried to compare files with HEX editors and yeah it sees many differences but not sure what I am looking for.
    Can some wizard help here? If you can fix one file and if it works, maybe I can find what they did to get it going.
    I even tried to use the clean ME guide, but Win-RAID site is not working for me right now. However, not even sure it is an ME issue.
    If someone can help, that would be awesome! If needed the complete model # and Serial
    20MA-S25B1L PF-1L1S8V
    Oh yeah, I need to donate to contribute to the forum.
    Re: Help with Lenovo P52_20MA BIOS
    Here's your New BIOS, try it and let me know.
    all donations are welcome,
      Hardware1, you are a wizard!!!
      I'm assuming this BIOS you shared was just a clean ME version you had archived without repairing the file I had? Just trying to learn, not just expect someone else to always fix it for me.
      If so, it worked that's all that matters. However, I was just curious to know what the hell happened to the original BIOS during the update and what was damaged.
      Either way, thank you very much.
        Good to know that, You're Welcome.
        No, I have repaired your dump file by replacing the BIOS Region with the one with is provided by Lenovo, inserted your Windows key from the dump file then cleaning the ME Region.
          Good to know. The ME region would make sense as I tried the file on another unit that was exact as the first one and it worked on it as well. Feel better for not having to ask for help on the other two units. Replacing the BIOS region is a little higher expertise I don't have yet not to mention the proper software.
          However, now that you mentioned what you did, I guess the windows key will carry to the other laptop too, both activated so it wont matter.
          Funny thing is both laptops in BIOS report the same internal MAC address which I thought was hardware level and cannot be changed. Strange and learn something new everyday. At least the UUID was different between the two. Both are connected to the same network and no conflicts.
            Hello
            I have an issue with Lenovo P52_20MA it will not post with no video
            The bios is corrupt can it be repaired using Lenovo bios update
            Any help will be appreciated
            model 20ma s1mb00
            s/n pf 1dtnem
            original bios
              Originally posted by SMDFlea View Post
              Re: Lenovo P52 BIOS needed
              Another bios to try .
              good day sir. Is it possible to turn off computrace on my laptop Lenovo P52
                That should still be under warranty.
                Get Lenovo to fix it. BIOS is not supposed to get corrupt merely by shutting down while it's booting an OS. (if it was performing a BIOS update that's something else though)
                  yep, it's possible but follow the rules and post serial number.
                    of course
                    type 20ma-s0mt03 SN PF-1mrj6e pasword 12345
                      of course
                      remove password and read again bios chipset.
                        done
                          done
                          try this one
                            try this one
                            thank you very much volinakis.just tried your file but still computrace is activated
                              sorry, usually invalidating AbtState from VSS Store do the trick but I couldn't find it in your bios. however, I did find company name (ram**ll) in MFS area from ME and thought cleaning ME will solve the problem. You can use Lenovo DXE Patcher maybe will allow you to disable Absolute. https://www.badcaps.net/forum/showthread.php?t=87588
                                sorry to bother you, but is it possible to have computrace located in this small file
                                  I need remove this message "this computer is equipped with computrace lenovo p52
                                  this sn PF1FAZBA
                                    this sn PF1FAZBA
                                    I know this is a 32Mb file, but I believe you can still use Autopatcher to remove the password. From my experience, it also wipes the computrace as well. So if you add a password to your P52 (one you remember) and pull the BIOS image again, then run autopatcher to remove the password and computrace at the same time. You cannot run autopatcher without a supervisor password which is why I mention to add a password before proceeding.
                                      Hello
                                      can anyone help me with SVP, autopatcher did not run...
                                      Lenovo P52 20MA (S/N PF1MQ0ZW), Chip MX25L25673G
                                      can i see the password in the .bin file, so i can remove it manually?
