Asus ux482e bios?
  • fredo
    • Aug 2016
    • 72
    • syria
    Re: Asus ux482e bios?
    Please remove the password
    • peste
      • Dec 2016
      • 12244
      • ROMANIA
      read..
      try..
      • karojandro
        • Aug 2017
        • 11
        • Spain
        Good night.
        Could you help me with this bios?
        The PC only turns on the fire LED but it doesn't turn on.
        thank you.​
        Number Serial: M9N0V11X23237E
        • peste
          • Dec 2016
          • 12244
          • ROMANIA
          Originally posted by karojandro
          Good night.
          thank you.​
          you have the bios at post #8
          • karojandro
            • Aug 2017
            • 11
            • Spain
            Good night.
            thank you.
            Thanks.
            I tried but it doesn't work.
            • b@w
              • Mar 2020
              • 31
              • ind
              #26
              Any one please help to repair this bios...
              MAINBOARD : UX482EGR R3.0
              SN : M9N0CV13H892374
              • hoaca388
                Badcaps
                • Jan 2022
                • 11164
                • Viet Nam
                #27
                Where is your original file ?
                Any donations to Badcaps are welcome. Become a Badcaps supporter >>>>> click this link to donate <<<<< Thank you to all the supporters. -- -------------------------------------------------------------------------------------------------------------------------------------------------------------
                • b@w
                  • Mar 2020
                  • 31
                  • ind
                  #28
                  this my file
                  • danito
                    • Jun 2016
                    • 842
                    • Romania
                    #29
                    this my file
                    try
                    • b@w
                      • Mar 2020
                      • 31
                      • ind
                      #30
                      Originally posted by danito
                      try
                      Thank for Help Danito.....the laptop is not responding, but the power light is on... no change after waiting more than 15 minutes... any suggestions?
                      thanks
                      • volinakis
                        • Jan 2021
                        • 2621
                        • N/A
                        #31
                        thanks
                        your bios backup shows another serial and ME is configured so I doubt that's your backup. Anyway, try this.
                          • 20300
                          thanks
                          If Volinakis bios doesn`t work post a picture of the square white QR code next to the fan connector,like the ones at posts 5 and 9
                          • Yeti
                            • Oct 2022
                            • 14
                            Hi, im also having an issue trying to remove the password.
                            I have used the AMI Aptio tool to create a backup of the bios, but need help from here. i have used HxD to find the area between AMITSEsetup and NVAR but it is blank.
                            the serial number is M3N0CV18M783129
                            the model number on the QR code is ux482eg
                            thanks for your help
                            • volinakis
                              • Jan 2021
                              • 2621
                              • N/A
                              #34
                              blank?
                              • Yeti
                                • Oct 2022
                                • 14
                                Originally posted by volinakis
                                blank?
                                Oh i must have found a different part that had the same but was blank.
                                I tried the section you found and XOR it then converted it to ascii but it came out as garbage. see attached.
                                also there were not enough characters, so i added 0s. what am i doing wrong
                                • Yeti
                                  • Oct 2022
                                  • 14
                                  The bios you need is the same as you have on the QR code sticker at post #9 UX482EA .The bios at post #10 is an F1 Asus service bios,you can`t get any better than that.Possibly an EC or hardware problem,don`t know
                                  Hi SMDFlea,
                                  I have a UX482EG that im trying to get the bios password so i can change the boot priority to usb. what is the F1 service bios?
                                  Thanks.
                                  • volinakis
                                    • Jan 2021
                                    • 2621
                                    • N/A
                                    #37
                                    password can't be found on this model, only removed by editing bios backup and write bios chipset with a programmer
                                    • Yeti
                                      • Oct 2022
                                      • 14
                                      I have a programmer, but i don't know how to edit the bios, can you help me with that?
                                        • 20300
                                        So go ahead and post your backup. The F1 bios is provided to asus service centres. Your could use that but you will lose your DMI (serial number,windows key) ,and could lead to other problems such as the SSD not being detected or the keyboard backlight not working (if it has a backlit keyboard).
                                        • Yeti
                                          • Oct 2022
                                          • 14
                                          Ok, thanks for explaining that. I have posted my backup in comment #33.
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • lrouw84
                                            by lrouw84
                                            Hi there,
                                            01-28-2023, 01:31 PM
                                          • DynaxSC
                                            by DynaxSC
                                            06-14-2024, 03:49 PM
