Dell XPS 9310 LA-J144P REV 1.0 bios fix
  • Markus1741
    • Sep 2020
    • 976
    • N/A
    Originally posted by ibo
    XPS 13 9310
    service tag H1V9893
    hangs on bios dell logo
    Clear ME please
    Hello try this ME Clean File from your original bios good luck ....
    • kamkooltech
      kamkooltech
      • Jun 2019
      • 132
      • nigeria
      dell xps 9310
      s/t:J8HMZD3
      The problem is showing display colors test not booting, i download the extracted file from dell and merged it, it only freeze on dell logo,
      i need patch file, just any solutions to help me
      thank you bosses
        • 22209
        Originally posted by kamkooltech
        dell xps 9310
        s/t:J8HMZD3
        thank you bosses
        Every bios posted in this thread has the same problem and none of the fixed bios have worked. Disconnect the battery then remove the SSD and see if it will boot any further, give it a few minutes.
        • kamkooltech
          kamkooltech
          • Jun 2019
          • 132
          • nigeria
          ok, will try it boss
          • docenciarz
            • Feb 2016
            • Bytom
            hello guys, can you repair bios for me ? stuck on logo dell and nothing.
            Service Tag : 8MTZ9K3
              • 22209
              https://www.badcaps.net/forum/troubl...66#post3700866
              • Markus1741
                • Sep 2020
                • 976
                • N/A
                #27
                Hello you can try this file good luck ....
                • iTec
                  • Oct 2017
                  • 32
                  Good evening, everyone. I have XPS 9310 LA-J144P Rev 2. S/N: 1N8N3M3
                  The unit with original file was doing loops on logo (After Update). I've flashed this file that I have found here (I think), and it's the only one that worked.
                  This file works after couple of reboots but takes me to BIOS GUI. NO SSD Detected, and the issue isn't the hardware, it's the BIOS file itself, because i've had a very similar issue with LA-L882 in the past with the same issue. Good is the file that i got from somewhere online...Bad is the original file. I'd really appreciate it if someone could help. Many thanks!
                  • Markus1741
                    • Sep 2020
                    • 976
                    • N/A
                    #29
                    Hello you can try this file ...
                    • iTec
                      • Oct 2017
                      • 32
                      I appreciate the reply, sir. The machine didn't power on with the file above.
                      • Markus1741
                        • Sep 2020
                        • 976
                        • N/A
                        #31
                        It's a shame to hear it didn't work, but Dell XPS 9310 are difficult candidates when something goes wrong with the BIOS.
                        Just try that one again, otherwise I don't know what to do.
                        Feedback is always nice.
                        it's the only way to improve.
                        • iTec
                          • Oct 2017
                          • 32
                          Sir, thanks again for trying. The file above gave display, but freezes on logo. I appreciate you trying.
                          • sopik78
                            • Nov 2013
                            • 520
                            • Czech Republic
                            #33
                            I'm asking for help with cleaning the ME BIOS from a Dell XPS 13 9310.
                            • Motherboard P/N: La-J144p
                            • Service Tag (ST): 9ZS1FK3
                            • Express Service Code (EX): 21754453251
                            After powering on, the Dell logo is displayed for a long time, then it boots, but the CPU is only running at its minimum frequency.
                            Thank you very much.
                            • LBTT1121
                              • Nov 2024
                              • 1223
                              • Việt Nam
                              #34
                              try and feedback
                              • sopik78
                                • Nov 2013
                                • 520
                                • Czech Republic
                                #35
                                Thank you very much, but it's behaving the same way. The problem is probably elsewhere.
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • mikeybass
                                  by mikeybass
                                  04-23-2025, 04:30 PM
                                • capoplays
                                  Help with BIOS update on Dell G15 5515 after chip replacement
                                  by capoplays
                                  Hey everyone,
                                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                  When I check the BIOS using the F12 menu Flash...
                                  10-24-2025, 06:53 AM
                                • Akhlz001
                                  by Akhlz001
                                  09-20-2025, 07:15 PM
                                • Sathsul
                                  Dell Latitude 5431 issues with dumping bios
                                  by Sathsul
                                  So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                  The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                  However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                  10-28-2025, 07:49 AM
