IdeaPad 5 15ALC05 bios please!
  • okimo
    • Dec 2012
    • 11
    • Srbija
    #81
    Re: IdeePad 5 15ALC05 bios please!
    Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
    Thanks a lot.
    It works
    • StormCrow
      • Nov 2015
      • 6
      Hi guys. Got a Lenovo Ideapad 5 15ALC05 with black screen, caps lock flashing after a failed BIOS update
      S/N: R914E6VV
      Have attached original BIOS dump - hoping someone can generate a working file for me?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12272
        #83
        S/N: R914E6VV
        Laptop Flex 5-15ALC05 (ideapad) - Loại 82HV
        • StormCrow
          • Nov 2015
          • 6
          Thank you very much. The laptop now powers on, but with a LCD issue (graphics flickering all over the place) - works okay on an external monitor... Any suggestions?
          • hoaca388
            Badcaps
            • Jan 2022
            • 12272
            #85
            Check LCD cable
            • StormCrow
              • Nov 2015
              • 6
              Check LCD cable
              No it was a BIOS issue still - I managed to solve it by booting into Medicat on an external USB (external graphics worked) and updating the BIOS again from within Windows... Still got a slight flicker on the screen but I think that's refresh rate settings or similar... Thank you very much for your help
              • dzagorski
                • May 2024
                • 4
                • Poland
                #87
                Hello... I have problem with Lenovo Ideapad 5, 15ALC05. I'm disconnect battery and now is black screen, esc, caps and numlock are on, and power blinking. I need help with bios. on this link is my dump oryginal bios... Could You help me ?
                MO: PF9XB2616086
                MTM: 82LN00M9PB
                Last edited by SMDFlea; 05-21-2024, 12:45 PM. Reason: Read the rules,no external links
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12272
                  #88
                  MO: PF9XB2616086
                  MTM: 82LN00M9PB
                  Serial number ?
                  • dzagorski
                    • May 2024
                    • 4
                    • Poland
                    #89
                    Serial number ?
                    S/N: PF3TYV8A
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12272
                      #90
                      S/N: PF3TYV8A
                      Laptop Ideapad 5-15ALC05 - Loại 82LN
                      • a7x
                        • Jun 2024
                        • Spain
                        #91
                        Hi!
                        I have a black screen, power off button blinking and caps and num block blincking .
                        I just dumped my BIOS.
                        Serial Number: PF3KZYAB
                        Can anyone help me please?
                        • peste
                          • Dec 2016
                          • 13436
                          • ROMANIA
                          #92
                          Originally posted by a7x
                          Hi!
                          try post #55..
                          • thesumate
                            • Jun 2024
                            • 11
                            Hello, i'm very new to all this. I also have this laptop "Lenovo IdeaPad 5 15ALC05" wich doesn't boot (screen is black). What do I have to do to flash that bios chip? I don't know anything about all that and would be happy for some information or resources (:
                            "Winbond 74W12JWSIQ"
                            is this the bios chip? The 'W' could also be an 'M' I think.
                          • thesumate
                            • Jun 2024
                            • 11
                            Okay, thanks so I'll have to get such a programmer. Is this the bios chip? It says "Windbond 74M12JWSIQ 2112". I don't have that programmer yet but I already downloaded its software. I couldn't find this chip there. Is there another chip on the other side of the board so I have to take the laptop apart? Or is it the right one?
                            Click image for larger versionName:	image.pngViews:	0Size:	7.94 MBID:	3290329
                            • thesumate
                              • Jun 2024
                              • 11
                              Ok, so on the front of the mb there is nothing but this one chip that looks like it could be a bios chip. Since this is all over this laptop model, does anyone know where its located? The back of the motherboard also has some sort of shield on it and I dont really want to unscrew it and take that shield off.
                              EDIT:
                              I removed the board now and also looked on the underside under the shield thingy for possible bios chips but there weren't any chips at all. The only one that looks like it is the one from earlier called "Windbond 74M12JWSIQ 2112"
                              • peste
                                • Dec 2016
                                • 13436
                                • ROMANIA
                                #96
                                EDIT:
                                Winbond 74M12JWSIQ is the bios chip...
                                • thesumate
                                  • Jun 2024
                                  • 11
                                  Ok perfect. But I can't find this chip in the software for the spi programmer. This chip isn't listed there. What do to? Or do I have to get another program?
                                    SMDFlea commented
                                    Editing a comment
                                    Choose W25Q128FW manually from the chip list
                                • peste
                                  • Dec 2016
                                  • 13436
                                  • ROMANIA
                                  #98
                                  use one of these programs.. if you can't find it, get a chip from the database equivalent to what you have in your laptop..
                                  don't forget to make a copy of the original bios before writing with new content..
                                  https://www.badcaps.net/forum/showpo...6&postcount=10
                                  https://www.badcaps.net/forum/showpo...postcount=7​
                                  • thesumate
                                    • Jun 2024
                                    • 11
                                    Alright thank you very much!!
                                    "get a chip from the database equivalent to what you have in your laptop", so do I have to look for a chip that's available in the software with the same properties as here:
                                    https://www.winbond.com/hq/product/c...artNo=W74M12JW
                                    • peste
                                      • Dec 2016
                                      • 13436
                                      • ROMANIA
                                      #100
                                      yes..yes.. but try the two programs, maybe you have the chip there..
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                        Lenovo IdeaPad 5 15ALC05 Notebook 5 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 5 15ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ALC05 boardview and 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 04:30 AM
                                        Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
