IdeaPad 5 15ALC05 bios please!
  • volinakis
    • Jan 2021
    • 2872
    • N/A
    #141
    Originally posted by azazazaz
    Hi!
    This time I used NeoProgrammer. Hope it is fine.
    no, is not. I told you to do more readings and compare them, open 2 readings in HxD and use Compare function.
    • azazazaz
      • Sep 2024
      • 11
      • singapore
      #142
      Hi !
      Just a question. Do i need to plug in the bios coin battery? Cos I have unplug both the main battery and bio battery.
      • volinakis
        • Jan 2021
        • 2872
        • N/A
        #143
        Hi !
        no
        • azazazaz
          • Sep 2024
          • 11
          • singapore
          #144
          no
          Hope this is ok .. thank you
          • azazazaz
            • Sep 2024
            • 11
            • singapore
            #145
            bump
            • hoaca388
              Badcaps
              • Jan 2022
              • 12268
              #146
              bump
              ideapad 5-15ALC05 Laptop - Type 82LN
              • azazazaz
                • Sep 2024
                • 11
                • singapore
                #147
                Hi hoaca388
                Serial is PF2X5P8J
                Model : Lenovo Ideapad 5 15ALC05
                MO : PF9XB1530160
                MTM : 82LN00EMSB
                S/N : PF2X5P8J​
                Thank you !
                • Artuha
                  • Mar 2018
                  • 30
                  • Latvia
                  #148
                  Lenovo IdeaPad 5 15ALC05
                  NM-D701
                  MTM: 82LN00M7PB
                  SN: PF3LRYL1
                  Please repair BIOS no display
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12268
                    #149
                    NM-D701
                    MTM: 82LN00M7PB
                    SN: PF3LRYL1
                    ideapad 5-15ALC05 Laptop - Type 82LN​
                    • Artuha
                      • Mar 2018
                      • 30
                      • Latvia
                      #150
                      NM-D701
                      MTM: 82LN00M7PB
                      SN: PF3LRYL1
                      Please repair BIOS no display​
                      Previous bios dump was not correct, please repair this one original from device
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12268
                        #151
                        NM-D701
                        MTM: 82LN00M7PB
                        SN: PF3LRYL1
                        • djharold
                          • Aug 2015
                          • 245
                          • COLOMBIA
                          #152
                          Re: IdeePad 5 15ALC05 bios please!
                          Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                          thanks so much, work for me
                          • hardware1
                            • Sep 2021
                            • 2946
                            • N/A
                            #153
                            You're welcome
                            all donations are welcome,
                            • ITWizzard22
                              • Nov 2023
                              • 7
                              Lenovo ideapad 5-15ALC05 Laptop - Type 82LN
                              I've tried one of the BIOS files here but still not booting, I assume I need DMI info or something.
                              I've attached my BIOS below, could someone please try fix this for me?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                #155
                                Check hardware issues.
                                • ITWizzard22
                                  • Nov 2023
                                  • 7
                                  The laptop was turning on fine but I believe I switched it off during a BIOS update. I've removed everything from the board and it still doesn't turn on. (Power light comes on, fans don't spin and no display).
                                  Did the BIOS look fine to you is that why you've recommended that?
                                  Edit Chip Model - w74m12jwssiq
                                  • ITWizzard22
                                    • Nov 2023
                                    • 7
                                    Bump.
                                    I really need this done, if you guys don't want to do it could you teach me how?
                                    • peste
                                      • 13422
                                      • ROMANIA
                                      #158
                                      Bump.
                                      you have everything you need for the post#11
                                      https://www.badcaps.net/forum/troubl...hlight=15ALC05
                                      • ITWizzard22
                                        • Nov 2023
                                        • 7
                                        I copied my DMI info as described for an ideapad in post # 55 here. Didn't solve the issue but I guess I'll try the flex BIOS if you think that'll work.
                                        • pziembowski
                                          • Jul 2016
                                          • 29
                                          • Poland
                                          #160
                                          I need help to recover bad bios - probably died during update. MB is HS553 NM-D701 Rev 1.0. SN: PF3LGY04
                                          Original dump below
                                          Thank you!​
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            Lenovo IdeaPad 5 15ALC05 Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 5 15ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ALC05 boardview and 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 04:30 AM
                                            Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
