IdeaPad 5 15ALC05 bios please!
    • 21662
    Originally posted by pziembowski
    I need help to recover bad bios - probably died during update. MB is HS553 NM-D701 Rev 1.0. SN: PF3LGY04
    Original dump below
    Thank you!​
    Thread merged. Post the Model Type
    • pziembowski
      • Jul 2016
      • 29
      • Poland
      #162
      I can't find the type At the bottom of the housing, in addition to the serial number, I also have: MO: PF9XB23327187 and MTM: 82LN00REPB​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        #163
        ideapad 5-15ALC05 Laptop - Type 82LN
        • pziembowski
          • Jul 2016
          • 29
          • Poland
          #164
          Bios revived the laptop - thank you. It will start without the matrix backlight though. Is it possible that bios it is not fully functional for my notebook?
            • 21662
            Is it working ok with HDMI ?
            • pziembowski
              • Jul 2016
              • 29
              • Poland
              #166
              Yes, it works fine on hdmi.
              Edit: found a faulty fuse. It seems that everything is ok with the bios. Thanks again​
              • Andreas Engholm
                • Dec 2024
                • Sweden
                #167
                HI I am new in hear and have a problem with my board its an lenovo ideapad 5 with Ryzen 7 16g ram and it has HS553NMD701 on the board. The problem I am having is that I upgraded this computer to this moderboard and i dont have the MTM number or serial number and its also the Chinese version of the bios H2CN36WW
                and Im in sweden and would like to get the European Bios if this is possible? Can this be fixed. The laptop is working in general. Thanks for your help!
                • fleshtoha84
                  • Feb 2025
                  • Украина
                  #168
                  Добрый день, нет картинки IdeaPad 5 15ALC05 , что осталось на картинке MO:PF9XB2717102 MTM:82LN.......A S/N:PF3YXF1S
                  English - Good afternoon, there is no picture of IdeaPad 5 15ALC05, what is left in the picture MO:PF9XB2717102 MTM:82LN.....A S/N:PF3YXF1S​
                  • peste
                    • 13422
                    • ROMANIA
                    #169
                    I don't understand, what's your problem?? What do you need??
                    • fleshtoha84
                      • Feb 2025
                      • Украина
                      #170
                      Ноутбук включается, не выводит изображения на экран, подозреваю проблему с биосом
                        • 21662
                        Post in english or you will get no help ! .I have sent you a private message, i suggest you read it.
                        • fleshtoha84
                          • Feb 2025
                          • Украина
                          #172
                          Good afternoon, the laptop does not display images on the display, I suspect a BIOS problem IdeaPad 5 15ALC05 MO:PF9XB2717102 MTM:82LN.......AS/N:PF3YXF1S
                          • peste
                            • 13422
                            • ROMANIA
                            #173
                            you have everything you need at post #11
                            https://www.badcaps.net/forum/troubl...en#post3561021
                            • Artuha
                              • Mar 2018
                              • 30
                              • Latvia
                              #174
                              Please repair BIOS. No backlight, two beeps, keyboard not working
                              Model: IdeaPad 5 15ALC05-82LN
                              S/N: PF41ESZ7
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                #175
                                S/N: PF41ESZ7
                                • freenlnl
                                  • May 2014
                                  • 30
                                  • The netherlands
                                  #176
                                  Need bios due to no display attached original Bios and sn .
                                  Model. IdeaPad 5 15ALC05
                                  Motherboard HS553 NM-D701 REV 1.0
                                  Sn : PF3FW9LF
                                    • 21662
                                    Sn : PF3FW9LF
                                    Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                    • freenlnl
                                      • May 2014
                                      • 30
                                      • The netherlands
                                      #178
                                      Thanks , wiill do
                                      • walt777666
                                        • Apr 2025
                                        • us
                                        #179
                                        hello guys,
                                        i need a bios for my IdeaPad 5 15ALC05 Type 82LN​
                                        sn: PF30TFEF
                                        i add the bios dump too,
                                        pls guys help me.
                                        • peste
                                          • 13422
                                          • ROMANIA
                                          #180
                                          Originally posted by walt777666
                                          hello guys,
                                          sn: PF30TFEF
                                          pls guys help me.
                                          you have everything you need at post #11...
                                          https://www.badcaps.net/forum/troubl...hlight=15ALC05
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            Lenovo IdeaPad 5 15ALC05 Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 5 15ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ALC05 boardview and 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 04:30 AM
                                            Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 15ALC05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 15ALC05 boardview and Flex 5 15ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
