Dell XPS 13 9365 - LA-D781P bios
Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is J8M2NQ2. Here is the original dump
Attached FilesComment
Service Tag: J8M2NQ2​Attached Files↵
​https://www.badcaps.net/donateComment
Hi Guys, can you help me for remove my bios password
Dell XPS 13 9365 2-in-1 (P71G)
Help me pleaseAttached FilesComment
Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 2-in- LA-D781P. 1 REV 1 0 (A00 ) 2017-04-22 i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 3X6KQV2 Here it the original dump​Attached FilesComment
Hi guys can somebody help me fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is JKHS7H2. Here it the original dumpAttached FilesComment
tpm device not detected issue plz hellp meAttached FilesComment
Hello
Would you please help me with a clean/working bios for dell XPS 13 9365
Laptop has no display , processor warm .
i attached backup
ST is no longer visible on the cover.Attached FilesComment
Please i need bios file for dell state the info down:
Have tried the thread that i found here but there not working for me
Original file one would start for some while and show amber light at the power led and then off
please help on my backup attached:
Dell XPS 13 9365
Board number :BAZ80/CAZ80 LA-D781P Rev:1.0(A00)
Service/Tag : JCD4FH2Attached FilesComment
hi have DELL XPS 13 9365 Problem is power on than off hara is bios file can any one fix for me thanks ST- 16V0VT2 LA--D781PAttached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
