Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 627JHR2. Here it the original dump
Dell XPS 13 9365 - LA-D781P bios
Re: Dell XPS 13 9365 - LA-D781P bios
Here Clean MEAttached FilesPremium supporters get full download access and other benefits.
XPS 13 9365 d781p
i have a XPS 9365 keyboard lights up for 3 seconds then turns off. suspect bad bios.
can someone help me clean it.
thanks in advanceAttached FilesPremium supporters get full download access and other benefits.
Re: XPS 13 9365 d781p
1 tested ok
أبو محمد abou-mohamedAttached FilesPremium supporters get full download access and other benefits.
Please need help clear me region Xps 13 9365..Attached FilesPremium supporters get full download access and other benefits.
Here's your Clean BIOS, give it a try.
Next time you can follow the steps in that Guide and do if by yourself.
https://www.badcaps.net/forum/showthread.php?t=88533Attached FilesPremium supporters get full download access and other benefits.
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Please help me, this laptop turns on to backlight for 30 secs and off. please help me clean this file. Thank youAttached FilesPremium supporters get full download access and other benefits.
Read the rules before posting:
BIOS guides, methods, resources and tools
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hi., can anyone help me clean this Dell XPS BIOS for me. The motherboard turn on, take the required amps 0.33 ~ 0.48amp). 3.3V $ 5v are all good. I get +VCC_CORE & +VCC_SA, but +VCC_GT is missing. & after about 20 sec approx. the motherboard stops working & CPU Cools down. I checked the voltages on Memory chips rail, all are fine. Maybe a cleanup might rectify this problem. Service Tag # 6TNZ4S2. Thanks in advance.Attached FilesPremium supporters get full download access and other benefits.
Here's your New BIOS, try it and let me know the results.Hi., can anyone help me clean this Dell XPS BIOS for me. The motherboard turn on, take the required amps 0.33 ~ 0.48amp). 3.3V $ 5v are all good. I get +VCC_CORE & +VCC_SA, but +VCC_GT is missing. & after about 20 sec approx. the motherboard stops working & CPU Cools down. I checked the voltages on Memory chips rail, all are fine. Maybe a cleanup might rectify this problem. Service Tag # 6TNZ4S2. Thanks in advance.Attached FilesPremium supporters get full download access and other benefits.
@ hardware1., This Bin files you send me did not make much difference, I guess there is something wrong with the motherboard which I will check. Thanks for all the help, I know your Bin files are working fine. Thank you very muchComment
Hi, I have a problem with cleaning ME Region for my Dell XPS 9365. There are errors in Flash Image Tool. Can you try to clean ME Region on my dump? There is problem with TPM error.Attached FilesPremium supporters get full download access and other benefits.
when i tried to open mea .deleted by antivirus . i think your dump is infectedComment
Channel: BIOS Requests ONLY!
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
