Try this file ....
Dell XPS 13 9365 - LA-D781P bios
Hey guys,
I am having difficulty repairing a Dell notebook, which has the following defect;
The keyboard keeps turning on and off but no video appears and the source consumption remains at 350 to 80 mA.
I believe it is the corrupted BIOS.
Can anyone help me by analyzing the BIOS?
Dell XPS 13 9365 2-in-1
Service Tag: 8VG41N2
Motherboard: BAZ80/CAZ80 LA-D781P REV 1.0Attached FilesComment
tryHey guys,
Motherboard: BAZ80/CAZ80 LA-D781P REV 1.0Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 5FB7ZM2.
Here it the original dumpAttached FilesComment
this file doesn't contain any st no. u can enter manually
try, and let me know.
https://www.badcaps.net/donateComment
First of all, I'm sorry for the delay in feedback. Unfortunately the bios didn't work. Now it stays for 2 seconds with the keyboard lighting on and then goes off, the consumption varies from 0.2 to 167 mAh.Comment
Hi, by me is 9365 (7gen) with same problem - kb backlight for few seconds and then off. Display test was without problem. I have found problem on PU801 (ISL95852) - no vcc_core. Ic was purchased from ali, soldered and laptop boots normally...BUT only with disconnected battery...with connected laptop freezes and makes BSODs.
Maybe ali ic was sht.
Now i have got another same mechanically smashed board soo i have changed this ic again and now works all fine
BTW super ulv "i7" in this laptop is really tragedy.Last edited by CornholioGSM; 08-12-2024, 05:46 PM.Comment
Hello everyone, can someone help me and clean or fix the bios for Dell XPS 13 9365 - LA-D781P? When I turn it on, it lights up the keyboard for about 4 seconds then turns off. Its service tag is H5BL2H2Attached FilesComment
XPS 13 9365 2-in-1
Service Tag: H5BL2H2
tryAttached FilesComment
Hi guys. i need help with a dell xps 13 9635 BIOS. . The customer said it went off while updating bios. so i guess it is the BIOS Region that is bad. not the ME Region, Because I have tried cleaning the ME region but its not coming on still. Maybe i did not do it right cus i am not familiar with working on Dell Bios. Here is my Backup bin file bellow. Can anyone help me fix it?
service tag: 8PQGZF2
s/n: 18970375502 ( not sure about the serial )Attached FilesLast edited by Tjaytony; 09-12-2024, 05:44 PM.Comment
XPS 13 9365 2-in-1Hi guys. i need help with a dell xps 13 9635 BIOS. . The customer said it went off while updating bios. so i guess it is the BIOS Region that is bad. not the ME Region, Because I have tried cleaning the ME region but its not coming on still. Maybe i did not do it right cus i am not familiar with working on Dell Bios. Here is my Backup bin file bellow. Can anyone help me fix it?
Service Tag: 8PQGZF2
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
