Dell XPS 13 9365 - LA-D781P bios
  • Stunt
    • Oct 2019
    • 203
    • South Africa
    Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 627JHR2. Here it the original dump
  • J_PH
    • Dec 2022
    • 37
    • Chile
    Re: Dell XPS 13 9365 - LA-D781P bios
    Here Clean ME
    • Stunt
      • Oct 2019
      • 203
      • South Africa
      Originally posted by J_PH
      Here Clean ME
      Thanks man i will try it tomorrow and give you the feedback
      • Stunt
        • Oct 2019
        • 203
        • South Africa
        Here Clean ME
        Thanks man its working
        • nivirus2000
          • Apr 2017
          • 45
          XPS 13 9365 d781p
          i have a XPS 9365 keyboard lights up for 3 seconds then turns off. suspect bad bios.
          can someone help me clean it.
          thanks in advance
          • aboumohamed
            • Dec 2018
            • 258
            • algeria
            Re: XPS 13 9365 d781p
            1 tested ok
            أبو محمد abou-mohamed
            • nivirus2000
              • Apr 2017
              • 45
              Thank you
              • dst30648487
                • Jun 2016
                • UA
                Please need help clear me region Xps 13 9365..
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  Here's your Clean BIOS, give it a try.
                  Next time you can follow the steps in that Guide and do if by yourself.
                  https://www.badcaps.net/forum/showthread.php?t=88533
                  all donations are welcome,
                  • ajbernasko
                    • Mar 2022
                    • 229
                    • ghana
                    Please help me, this laptop turns on to backlight for 30 secs and off. please help me clean this file. Thank you
                    • pakistan
                      • Dec 2022
                      • 5
                      • PAKISTAN
                      Originally posted by j_ph
                      here clean me
                      thanks man its 2023 and its still working again thanks alot
                      • Lightcap
                        • Mar 2022
                        • 11
                        • United Kingdom
                        HI,
                        I have this problem also. What programmer would i need to read the bios chip, also i'm guessing the IC has to be removed from the board to read it.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Originally posted by Lightcap
                          HI,
                          Read the rules before posting:
                          BIOS guides, methods, resources and tools
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                          • mferna14
                            • Jun 2018
                            • 1046
                            Thank you BADCAPs for all the services & keeping BIOS request alive forever. All donated. Regards from Ontario, Canada
                            • mferna14
                              • Jun 2018
                              • 1046
                              Hi., can anyone help me clean this Dell XPS BIOS for me. The motherboard turn on, take the required amps 0.33 ~ 0.48amp). 3.3V $ 5v are all good. I get +VCC_CORE & +VCC_SA, but +VCC_GT is missing. & after about 20 sec approx. the motherboard stops working & CPU Cools down. I checked the voltages on Memory chips rail, all are fine. Maybe a cleanup might rectify this problem. Service Tag # 6TNZ4S2. Thanks in advance.
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                Here's your New BIOS, try it and let me know the results.
                                • mferna14
                                  • Jun 2018
                                  • 1046
                                  @ hardware1., you are so nice & fast too. I was just shutting down this evening, I will surely let you know tomorrow morning, Thank you very much.
                                  • mferna14
                                    • Jun 2018
                                    • 1046
                                    @ hardware1., This Bin files you send me did not make much difference, I guess there is something wrong with the motherboard which I will check. Thanks for all the help, I know your Bin files are working fine. Thank you very much
                                    • TipSerw
                                      • Jul 2022
                                      • 3
                                      • Polska
                                      Hi, I have a problem with cleaning ME Region for my Dell XPS 9365. There are errors in Flash Image Tool. Can you try to clean ME Region on my dump? There is problem with TPM error.
                                      • skazide
                                        • Jul 2015
                                        • 143
                                        • morocco
                                        when i tried to open mea .deleted by antivirus . i think your dump is infected
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
