HP EliteBook 640 G9 Bios password
  • minhdigital
    • Nov 2022
    • 726
    • Vietnam
    #261
    Originally posted by ismaelstepheno
    THANK YOU MINHDIGITAL BUT STILL ASKING FOR BIOS ADMINISTRATOR WHEN RESTORE SECURITY SETTING I UPLOAD THE EC ROM TOO THANKS
    Try agan !
    • ismaelstepheno
      • Jun 2020
      • 226
      • UE
      #262
      thank you but still the same asking for password
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        #263
        Try
        At 1st boot press F10 and RESET BIOS to factory defaults​
        • ismaelstepheno
          • Jun 2020
          • 226
          • UE
          #264
          THANK YOU QAYYUM NOW I HAVE THE IC NPC998HA0BX SHORTED IT GETS VERY HOT I THINK IT IS THEREFORE HEATING THE MOTHERBOARD BY PROGRAMMING THE CHIP SEVERAL TIMES
          Click image for larger version  Name:	dataurl028948.png Views:	0 Size:	359 Bytes ID:	3496556ITS HEATING AND I HAVE TO CHANGE IT. DOES ANYONE KNOW IF IT IS PROGRAMMABLE OR IS PROGRAMMED AUTOMATICALLY BECAUSE THERE IS LITTLE INFORMATION ABOUT THIS IC THANKS TO ALL THE MEMBRES FOR YOUR HELP
          • PANDAREK
            • Oct 2024
            • 3
            • usa
            #265
            HP EliteBook 640 14 inch G9
            motherboard DAX8SFMB8B2 REV B
            SN 5CD311172Z2
            please disable absolute persistance​
            • kalya
              • Jun 2016
              • 15
              • od
              #266
              Try. SSD must be removed during
              • elmansouri
                • Jun 2016
                • 42
                • SENEGAL
                #267
                HELLO PLEASE NEED TO REMOVE PASSWORD FROM HP 640 G9 THANK YOU
                • peste
                  • Dec 2016
                  • 12294
                  • ROMANIA
                  #268
                  post the S/N, the motherboard model, etc.
                  • elmansouri
                    • Jun 2016
                    • 42
                    • SENEGAL
                    #269
                    5CD3472GMG
                    • elmansouri
                      • Jun 2016
                      • 42
                      • SENEGAL
                      #270
                      DA0X8SMB8H2 REV H
                      SerialNumber:5CD3472GMG
                      • m.sabry2110
                        • Oct 2017
                        • 129
                        • egypt
                        #271
                        DA0X8SMB8H2 REV H
                        try
                        • elmansouri
                          • Jun 2016
                          • 42
                          • SENEGAL
                          #272
                          Originally posted by m.sabry2110
                          try
                          THANK YOU FOR YOUR RESPONSE AND YOUR HELP BUT THE PASSWORD IS STILL THERE
                          • m.sabry2110
                            • Oct 2017
                            • 129
                            • egypt
                            #273
                            after flash mack restor factory and reflash original file agin
                            • elmansouri
                              • Jun 2016
                              • 42
                              • SENEGAL
                              #274
                              I followed your method and here is the result
                              • minhdigital
                                • Nov 2022
                                • 726
                                • Vietnam
                                #275
                                Send to you, try
                                • elmansouri
                                  • Jun 2016
                                  • 42
                                  • SENEGAL
                                  #276
                                  Originally posted by minhdigital
                                  Send to you, try
                                  THANK YOU FOR YOU HELP BRO THE PASSWORD IS ON WHEN A RESTORE ALL DEFAULT
                                  • PANDAREK
                                    • Oct 2024
                                    • 3
                                    • usa
                                    #277
                                    Absolute Persistence is inactive, but I can't update the BIOS to the latest version because the laptop freezes on the startup screen.
                                    • minhdigital
                                      • Nov 2022
                                      • 726
                                      • Vietnam
                                      #278
                                      SN 5CD311172Z2
                                      Send to you, try
                                      At 1st boot press F10 and RESET BIOS to factory defaults, save, restart After use HP BCU TOOL for MPM​
                                      • ranajee7750
                                        • Mar 2022
                                        • 11
                                        • pakistan
                                        #279
                                        HELLO SIR PLSS CAN U FIX ENDPOINT ERROR FIX ...I DO INSTAALED PATCH BBUTT NOT REMOVED PLSS FIX ENDPOINT ERROR THANKS
                                          • 20412
                                          Read the rules, type and post the laptop serial number...
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
