Hp 15 la-d707p not power on .
  • lapfix
    • Mar 2020
    • 2719
    • my workshop
    Hello friends .
    I've got this lap la-d707p motherboard (With GPU) that is not starting. I have no power/charging LED on the connector when plugging the power charger.
    I tested PQ202 and PQ203 the first 2 mosfet but i got only 19v at the drain of PQ202...
    no short to GND at all coils , pq202 / pq 203 are not shorted.
    Consumption is 0 amp. Gate of PQ 202 = 0v
    BQ2472A requirements :
    pin 20 vcc = 19v ok
    pin 6 acdet =2.6v ok
    pin 16 regn = 6v ok
    pin 5 acok = 0v !! must be 3v
    no 3vl at pr214 , no 3vl at pu2.
    Troubleshooting :
    i desolder pq203 , i got 24v at gate of pq202 , inject 19v at the pq203 ( non soldered) i got my 3vl ; acok = 3v...power on the lab work .
    i changed pq 203 still same behaviour...what i must verify too !
    thank you
  • mon2
    • Dec 2019
    • 14098
    Re: Hp 15 la-d707p not power on .
    Remove all power. Measure the resistance across the same 2x DCin mosfets.
    Review the other threads here for more details.
    Post the measurements of each mosfet check.
    • lapfix
      • Mar 2020
      • 2719
      • my workshop
      Thank you mon2.
      PQ 202 :
      Source/drain = 17.84mohm
      Gate /source = 10.76mohm
      Gate/drain = 18.87mohm
      PQ 203 .
      Source/drain = 21.34mohm
      Gate /source = 10.61mohm
      Gate/drain = 22.51mohm
      Yes i had reviw many threads but not the same issue
      • mon2
        • Dec 2019
        • 14098
        Resistance is fine on the mosfets.
        1) What is the voltage of BTST pin # 17 (PU201) ?
        2) Confirm the resistance on PR209 (~4k).
        3) Confirm that PR209 is connected to the source pins (1-2-3) of PQ203 and also connected to pin # 3 (PU201). This feedback pin (CMSRC) is important.
        4) What is the voltage of CMSRC pin # 3 ?
        5) If ACDRV is turned off, there may be a violation of one of the conditions for this charger IC. Confirm that the current sense leg of the circuit is working properly.
        Measure the resistance from each side of the current sense resistor back to the charger IC. The traces must not be damaged or missing.
        6) As a quick test, remove PR208 (4k resistor). Power up again.
        What is the voltage of ACDRV at the pin # 4 (PU201) ?
        • lapfix
          • Mar 2020
          • 2719
          • my workshop
          Ok
          pin 17 = BTST = 5.93v
          PR209 = 4.11kohm
          PR209 connectevity is confirmed.
          pin 3 = CMSRC = 3.8mv
          the current sense continiuty with pin 1/2 of pu 201 is ok.
          PR208 = 4.11kohm...removed = not power on.
          Pin 4 = ACDRV = 0v.
          a violation of one of the conditions for this charger IC...i think yes because 3vl who supply acok is missing
          • mon2
            • Dec 2019
            • 14098
            The pull-up voltage of +3VL is only on after the 2 x DCin mosfets are enabled (CLR) = +19.5VB
            Is mosfet @ PQ201 stuffed on your logic board ? If yes, remove it for testing.
            • lapfix
              • Mar 2020
              • 2719
              • my workshop
              yes i know the 3vl and his supply ( pu2 ).
              pq201 not stuffed.
              • mon2
                • Dec 2019
                • 14098
                Replace PC213 on REGN with any value you can find but no lower than 1uf (6v or higher rated cap).
                • lapfix
                  • Mar 2020
                  • 2719
                  • my workshop
                  Why you have a doubt about it , btw i change it with same one from a donar board and same issue
                  • mon2
                    • Dec 2019
                    • 14098
                    The REGN pin is linked to the charge (boost) circuit used for the ACDRV pin.
                    This was a suggestion from Tiger (TI FAE):
                    https://e2e.ti.com/support/power-man...acdrv-question
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Battery discharge FET is not shorted or leaky??
                      • lapfix
                        • Mar 2020
                        • 2719
                        • my workshop
                        @mon2 = i change pc213 and pu201 from a working motherboard...still same issue...o believe that pb is somewhere else.
                        @mcplslg..tthank you my friend...teste PQ205/206 with diode mode not shorted...i will desoldered for a good measurement = leaky or not
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          PQ204 is battery discharge fet and not PQ205/6.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Try replacing PC208/209/210 with exact same value.
                            • lapfix
                              • Mar 2020
                              • 2719
                              • my workshop
                              Thank you mcplslg.
                              remplace it with the same from a donar board , same behaviour.
                              PQ 204 is OK tested with diode mode.
                              Notice : when i plug the cahrger ( from power supply ) the amp rise from 0.000 amp to 0.035 amp than 0.000 than 0.009...etc
                              I tested all the mosfets at this motherboard with diode mode all is Ok.
                              Any other suggestion !
                              • mon2
                                • Dec 2019
                                • 14098
                                What is the voltage of ADP_ID ?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  What about post#14??
                                  • mon2
                                    • Dec 2019
                                    • 14098
                                    @mcplslg123,
                                    Thank you mcplslg.
                                    • lapfix
                                      • Mar 2020
                                      • 2719
                                      • my workshop
                                      Yes i verify this from first and nothing unusual.
                                      pin 75= 0.655v
                                      as i said before , when charger plug in there's consumption but soon return to 0 amp...so i think that there's a leacky mosfet/capacator somewher...tht's complicates my research.
                                      • mon2
                                        • Dec 2019
                                        • 14098
                                        Measure the resistance to ground of each and every coil on the logic board.
                                        Check for any low resistance readings. Post any low readings to confirm.
                                        Confirm that the traces from the charger IC pins ACN (1) / ACP (2) reach the current sense resistor @ PR203.
                                        • gpx
                                          HP 250 G5 (LA-D704P with a Core i7-6500U) won't POST
                                          by gpx
                                          Hi everyone, I am hoping for a little help with an HP 250 G5 with motherboard LA-D704P with a Core i7-6500U. I am new to board repair but keen to learn.
                                          I am sorry this post is quite long but I was trying to systematically work my way through things.
                                          I don't know the history of the board – I bought it as part of a job lot.
                                          I have attached a number of photos of both sides of the board. I cannot seem to find a schematic or boardview online.
                                          When plugged in to DC power the power LED lights and the battery seems to charge. It will not...
                                          06-18-2021, 10:39 AM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • vpower
                                          Almost dead Lenovo V15-ADA 82C7
                                          by vpower
                                          Hi, I have this laptop that acts strange. If I try powering on, the power led, the numeric keypad light and the fans will turn on but the screen has no image. The fuse F2 near the lcd connector is blown, I tried to replace it with some similar fuses (1A) but it keeps blowing. I tested these mosfets with multimeter:
                                          PQ201 drain 20v source 20v, gate 26v
                                          PQ202 drain 20v source 20v, gate 26v
                                          PQ5907 drain 20v, source and gate 0v (both shorted to ground too)
                                          PQ5908 drain 0v shorted, source 0v shorted and gate 0v (connected to pin 33 of PU5901)
                                          a lot of capacitors behind...
                                          03-10-2023, 02:39 PM
                                        • tantr13
                                          Lenovo Ideapad 5 14ITL05 not powering on
                                          by tantr13
                                          This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
                                          I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week...
                                          06-28-2024, 06:28 PM
