Lenovo Ideapad 5 14ITL05 not powering on
  • tantr13
    • Jun 2024
    • 5
    • United States of America
    This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
    I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week the laptop just wouldn't start upon plugging it in. I tried following a previous post on here, but due to my lack of knowledge in the subject, I am lost as where to look next.
    I began by removing the back cover and exposing the internal components. I wanted to see if my PQB1, PQB2, and PQB13 MOSFETs were working properly, as suggested in the aforementioned post, as they handle providing voltage to the board from the USB bus. I recorded the following resistances between the sources, drains, and gates for each component:
    PQB1
    Source to Drain: 112.3 kΩ​ (5 -> 2)
    Source to Gate2: 118.3kΩ (5 -> 8)
    Source to Gate1: 8.04 MΩ (5 -> 1)
    Drain to Gate1: 1.3 MΩ (3 -> 1)
    Drain to Gate2: 1.6 MΩ (3 -> 8)
    PQB2
    Source to Drain: 2.85 kΩ (5 -> 2)
    Source to Gate2: 115.4 kΩ (5 -> 8)
    Source to Gate1: 74 kΩ (5 -> 1)
    Drain to Gate1: 7.2 MΩ (3 -> 1)
    Drain to Gate2: 219 kΩ (3 -> 8)
    PQB13
    Source to Drain: 300 kΩ
    Source to Gate: 190 kΩ
    Gate to Drain: 7.2 MΩ
    However, I had two concerns while doing this:
    1. How are the pins laid out for these components? I assumed that, starting from Pin 1, they would increment upwards counterclockwise. Meaning they would go 1, 2, 3, 4 descending on the left side, then 5, 6, 7, 8 ascending on the right side. Is this correct? I wasn't able to find a layout for these two MOSFETs (3635? GA1R3? for PQB1 and 36354 A1T24 for PQB2)
    2. Are the pins in the below pictures properly soldered? To my eye, it looks as if one pin on each component isn't connected to the board, as the solder seems to bubble up on the tip.
    3. My resistances kept fluctuating while measuring them. For example, the Source to Drain for PQB1 varied from as little as 70 kΩ to as large as 8 MΩ. Could this be due to my leads? They're the regular AMES leads-- rather large for SMD pins. I just ordered needle-point leads, so maybe should I try measuring these resistances again? I made sure the power was off for the entire process, and the battery is disconnected, so am I doing something wrong in how I am measuring it?
    Thank you for your time!
    tantr13 <3
  • mon2
    • Dec 2019
    • 14995
    Hi. Welcome. Before my nightly Netflix binge..
    1) try to find a schematic on this forum, if available and link the landing page (only).
    2) study the mosfet datasheet for the pinout. Often pins 1-2-3 (source) are tied together. Pin 4 is gate. Pins 5-6-7-8 (drain).
    pin # 1 is identified by a dot and is top left of the part. Count in a counter clockwise direction like the letter ‘U’.
    Double check and revise your table of measurements but they look to be low.
    Each measurement should hundreds of k ohms or even Megaohms. Low readings often means a defective mosfet.
    Do review the charger sticky above by piernov.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      These are dual N channel mosfets. Pin1 and pin8 are the two gates. Pin1 is where the dot is. Pin 8 is just above it. yes you count them counterclock wise. better to see datasheet for exact pinout. Both the gates should not buzz together in diode mode-so check that as well.
      The resistance readings seems ok. What about the voltage on these pins?
      • tantr13
        • Jun 2024
        • 5
        Hi mon2, thank you for your quick response! I received the needle-point multimeter probes and revised my measurements. It seems like PQB2 source to drain is still extremely low, hovering at ~2 kΩ.
        PQB1 PQB2
        S2-D1 (3-2) 0.0 Ω 0.0 Ω
        S2-D1 (4-2) 0.0 Ω 0.0 Ω
        S2-D1 (5-2) 313.8 kΩ 156.4 kΩ
        S2-G2 (3-6) 113.1 kΩ 2.86 kΩ
        S2-G2 (4-6) 112.8 kΩ 2.86 kΩ
        S2-G2 (5-6) 0.0 Ω 0.0 Ω
        S2-G1 (3-1) 7.67 MΩ 7.84 MΩ
        S2-G1 (4-1) 7.70 MΩ 7.72 MΩ
        S2-G1 (5-1) 7.55 MΩ 6.84 MΩ
        D1-G1 (2-1) 7.56 MΩ 7.37 MΩ
        D2-G1 (7-1) 7.52 MΩ 7.26 MΩ
        D1-G2 (2-6) 112.5 kΩ 2.85 kΩ
        D2-G2 (7-6) 0.0 Ω 0.0 Ω
        PQB13
        S-D (1-5) 131.2 kΩ
        S-D (2-5) 131.5 kΩ
        S-D (2-5) 21.9 kΩ
        S-G (1-4) 7.52 MΩ
        S-G (2-4) 7.51 MΩ
        S-G (3-4) 7.49 MΩ
        D-G (5-4) 10.4 MΩ
        Hi mcplslg123, thank you for your comments. I checked the diode voltage across pins 1 and 6, which according to the schematic are G1 and G2, respectively. There is no mention of pin 8.
        The readings I received are as follows:
        PQB1 PQB2
        G1-G2 (1-6) 1.152 V 1.173 V
        G2-G1 (6-1) 0.0 V 0.0 V
        Does this mean that PQB2 is defective, considering its source-to-gate and drain-to-gate resistances are extremely low? What are the next steps? I cannot find this exact part online.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          To mee,the mosfets dont appear defective. You are yet to share the voltage on all pins of PQB1/PQB2.Only adapter connected.
            Lenovo Yoga Slim 7 14ITL05 Notebook Specification for Upgrade or Repair
            This specification for the Lenovo Yoga Slim 7 14ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 7 14ITL05 boardview and Slim 7 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-07-2024, 05:00 AM
            Lenovo IdeaPad Flex 5 14ITL05 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad Flex 5 14ITL05 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 14ITL05 boardview and Flex 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 04:30 AM
            Lenovo IdeaPad IdeaPad 5 14ITL05 Notebook 5 Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad IdeaPad 5 14ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 14ITL05 boardview and IdeaPad 5 14ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 04:10 AM
          • mikkele86
            Luxman R-5045 - Needing help identifying component in AM/FM module
            by mikkele86
            hello.
            I came across this thing and im not sure what it is exactly, I have never seen such thing before.
            I know it gotta be some kind of diode with Drain, Source and Gate1 and gate2
            It resides in AM/FM module and im measuring 200ohm across D and S.
            04-19-2024, 03:05 PM
