Hi, I have this laptop that acts strange. If I try powering on, the power led, the numeric keypad light and the fans will turn on but the screen has no image. The fuse F2 near the lcd connector is blown, I tried to replace it with some similar fuses (1A) but it keeps blowing. I tested these mosfets with multimeter:
PQ201 drain 20v source 20v, gate 26v
PQ202 drain 20v source 20v, gate 26v
PQ5907 drain 20v, source and gate 0v (both shorted to ground too)
PQ5908 drain 0v shorted, source 0v shorted and gate 0v (connected to pin 33 of PU5901)
a lot of capacitors behind the cpu are shorted. thermal cam shows heat on the cpu shield
maybe the problem is in the backlight circuit? too bad I cannot find schemathics for this laptop.
any hint?
Boardview: https://www.badcaps.net/forum/showth...57#post1211357
Schematic: https://www.badcaps.net/forum/showth...08#post1242808
any hint?
