Hi all, I am working on Hp 15-ca2003ca (MB DAG7BDMB8F0 REV:F). The problem was totally dead. Upon diagnostics, there was a burnt SY8286BRAC. I replaced it with another one. Now the WHITE LED on the DC-in jack glows & when the main battery is installed, the status of the LED changes to Orange. But when I press ON/OFF button, I see the power LED glows for a sec & then shuts off. Same happens when I press the ON/OFF button over again. I just put the Meter leads on the 3.3/5V coils & the meter shows that these both volts are generated & then in a sec. goes away. I re-programmed the BIOS too, no luck. There does not seem to be any short on the motherboard. Any repair tips will be greatly appreciated. Thanks in advance
Hp 15-ca2003ca DAG7BDMB8F0 turns on & shuts off
Re: Hp 15-ca2003ca DAG7BDMB8F0 turns on & shuts off
As usual thanks for the reply "mcplslg123". The AD_ID is "zero" volts. Out here I think it should be 3.3v. But the battery charges well & the DC-in jack LED glows both in WHITE & ORANGE. Once thing more I removed the 1.8V coil going to the CPU, & now it stays one for almost a minutes or so & then shuts down & then starts again by itself. & because of this status, the 3.3v chip gets very hot. Near the Audio Chip ALC3258-CG, the meter show 4 tiny ceramic caps shorts, the rail is of +5V_AVDD & +1.8V_AVDD, can't even tell where the component are location as there is NO marking on the board at all. I removed all 4 ceramic caps physically & tested them, all are ok but the lines is shorted. Boardview would surely help. What are these power rail for???Last edited by mferna14; 07-13-2022, 03:41 PM.Comment
When 1.8V coil is removed, vcore and gfx will not rise so mb will be in a boot loop trying to recover those rails. It seems something is wrong in cpu requirement and/or bad soc. Try mildly heating on the back side of SOC and put the 1.8V coil back. This will rule out dry solder joints under SOC. be careful not to overheat. I prefer heating around the soc and not directly on it.Comment
Nice Tips & troubleshooting techniques... You know very well how hard it is to re-flow the SOC, EVEN heat is required to balance the chip on all side or it will raise from one end. I will just try to do the sides of the chip. Maybe might help. Thanks will try it & inform you...Last edited by mferna14; 07-15-2022, 02:48 PM.Comment
Please don't randomly reflow SoC. Do you have proper output (3.3V) on pin 17 of the changed SY8286BRAC? Also post resistance to ground on that rail (+3VPCU). Since you mentioned that this IC is overheating, that not necessarily means that the IC is damaged, but something is overloading it, which could be a short or low resistance on the +3VPCU line.
Perhaps this leads to nowhere, but it's worth checking before reflowing or doing something that extreme.
Here is picture of the IC pinout to avoid losing time searching for pin 17.I don't provide help for people using CH341A and a clip.Comment
I prefer reflowing the soc in my bga station. that never damages the chip and rules out dry ball joints. Dry ball joints under soc is frequent and common problems in most of the 4th gen onwards soc. It can be done with a heat gun purely for testing purpose but heating around the soc and not directly on it. This never damages a SOC.
It is worth paying attention to @danieldecko's suggestionComment
Thanks for the help "DanielDacko" & "mcplslg123"., The voltage on Pin 17 of chip SY8286BRAC is 3.3v which seems to be right. Yes I was not going to do the re-flow UNLESS & UNTIL very nesessary, because when I removed the 1.8V coil, still the chip SY8286BRAC was turning hot when the motherboard was turned ON for a while, assuming that before the SoC some other component might be shorted. The resistence from GND to both the coils 3.3v is 4.2Kohms & the 5V coils is 11.52Kohms respectively. It's looks like the resistence is not right on the 3.3V rail. Beside this nothing is getting hot. If I inject continous 3.3V, where should I attach hot wire to? As before I mentioned that near the audio chip ALC3258, 4 tiny ceramic caps (assuming 10u 6.3V) are showing shorted. Removed all 4 of them but that rail still shows shorted. I think the rail is of +5V_AVDD & +1.8V_AVDD. Since no boardview & no marking of any component on the motherboard, cannot confirm this.Last edited by mferna14; 07-16-2022, 12:24 PM.Comment
Don't inject voltage yet. What is the voltage and resistance on 1.8V coil? If you suspect that +5V_AVDD and +1.8V_AVDD are shorted, try removing ALC3258 (can't believe that no boardview exists with this chip or any kind of datasheet with pinout) and see if the short is gone. This is logical step because they both go to the ALC3258 on pins 20 and 40. I know it is PITA to do this, but without boardview, there isn't much to do. Do you have lab psu?I don't provide help for people using CH341A and a clip.Comment
Thanks DanielDacko, there is voltage like any normal motherboard 1.8v & goes away within 3 ~5 seconds. Same happens with the 3.3V & 5V., meaning all voltage are generating normal till it reach the shorted component & then reset again. I did removed the ALC3258, the short was still present. Wish I had the boardview, even NO component markings on the motherboard???? How rude hp can be (:- Just figuring out by hit & try method. The resistence between the GND & 1.8V coil is 35ohms which might be ok for this type of SoC. Yes I do have a bench PS.Comment
If you can confirm short on pins 20 and 40, inject 1V on those rails to see what heats up.I don't provide help for people using CH341A and a clip.Comment
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM -
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
by mnciks11Hello guys, i need your help fellow brothers
Im diagnosing a Lenovo G80-50 laptop
ACLU3/ACLU4
Rev : 1.0
when you press the power button, the LED power light turns On and quickly shuts down, no display, fan spins a sec and stop. I haven’t seen any short so far.
PU908 (CPU POWER CORE CHIP) is getting hot the moment you press the power button, the laptop turns off very fast, i changed PU908, still im getting same problem, on output side of the 2 cpu power supply coil i get 1.6v and then goes away as soon as the laptop turns off, still the... -
by ZixuTechSeems like we are dealing with a case of a corrupted BIOS after Intel Driver software attempted to flash the bios (haven't seen that before). The customer reported seeing a BIOS message while the screen was flickering during the Intel Display Driver installation. This was while the BIOS WRITE lock jumper was in place. Resulting in Loop restarting.
Afterwards, the customer attempted flashing BIOS via USB stick, resulting now in turning and immediately shutting down unit NUC8I7HNK4.
Under the thermal cam, I can see that the CPU is initiating a heat signature for a second...-
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
- Loading...
