Macbook 820-3115 missing 3V42_G3H
  • mon2
    • 14672
    Re: Macbook 820-3115 missing 3V42_G3H
    Pin 10 = 0.7 ohms to ground ?
    To me, U7600 is defective.
    • Nuld_
      • Jun 2022
      • 64
      Removed U7600 the part itself was reading 10,8Mohms on Pin 10.
      On the logicboard Pin 10 is at 1 Ohms.
      • mon2
        • 14672
        So with U7600 removed, pin 10 on the logic board is ~1 ohms to ground ?
        What is left on the logic board that is mating with pin # 10 pad of U7600 on the logic board ?
        Someone is causing this rail to sink.
        Is L7630 still onboard or on a single leg ?
        • Nuld_
          • Jun 2022
          • 64
          Yes L7630 is still completely onboard.
          C7630 is mating with pin 10.
          • mon2
            • 14672
            Lift up one leg of L7630 OR remove current sense resistor R7640 (may be easier). Will need patience and flux to heat up this area since the inductor is able to support 20A of current. If indeed it is the inductor then this leads to the CPU which I believe will be the CPU causing this short event. Confirm it.
            • Nuld_
              • Jun 2022
              • 64
              I´ve removed R7640, the readings on the board are:
              Pin 1: O.L
              Pin 2: 0,7 Ohms
              Pin 3: O.L
              Pin 4: O.L
              • mon2
                • 14672
                Not at my computer but pin #2 is towards the CPU ?
                The CPU appears to be shorted. Wait on advice from others but CPU is very likely damaged from this reading.
                • Nuld_
                  • Jun 2022
                  • 64
                  Yup it is towards the CPU, I guess I will have to focus now on the other defective Logic Board. Nevertheless thanks a lot for your help
                  • Adogabriel100
                    Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                    by Adogabriel100
                    Hey! This is a A1278 macbook 2011.
                    Problem: Not turning on / No green light
                    Im using by3200s charger.
                    Voltajes:
                    PPBUS_G3H = 12.26v
                    SMC_RESET_L = 3.3v
                    PP3V42_G3H = 3.42v
                    U7000 =
                    Pin 1 CHGR_AGATE = 0v
                    Pin 2 CHRG_DCIN = 19v
                    Pin 3 CHRG_ACIN = 4.6v
                    Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                    Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                    Pin 12 PP3V42_G3H = 3.42v
                    Pin 13 CHRG_RST_L = 3.3V
                    Pin 14 SMC_BC_ACOK = 0.8V
                    Pin 19 PP5V1_CHRG_VDD = 5.05V
                    Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                    04-01-2024, 01:02 PM
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • salopian
                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                    by salopian
                    Hello. I would need some advice please.
                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                    I have already replaced the logic board with another...
                    02-27-2021, 07:30 AM
                  • mferna14
                    Apple MacBook A1398 820-00138-A missing 5V
                    by mferna14
                    HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
                    01-16-2023, 01:35 PM
                  • fajfelek
                    Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                    by fajfelek
                    Hello, First of all thanks you for reading this topic.
                    I need your help with identify missing parts on trackpad logic board (661-18430).
                    The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                    Please help me with identity parts from blue and red area .
                    06-15-2024, 01:41 PM
