Macbook 820-3115 missing 3V42_G3H
  • mon2
    • 14672
    Re: Macbook 820-3115 missing 3V42_G3H
    Good.
    Resistance to GND on L6995 (PP3V42_G3H_REG) ?
    • Nuld_
      • Jun 2022
      • 64
      Pin 2 on L6995 is someting about 135kohms, L6995 is still removed from the board.
      • mon2
        • 14672
        That is a much better resistance than before. If the other side of L6995 is also a high reading, then proceed to solder back L6995 so that it can perform its job.
        The voltage output of L6995 should be ~3v42 if all is well on this rail.
        • Nuld_
          • Jun 2022
          • 64
          The other side is reading O.L,
          so should be good i guess.
          • Nuld_
            • Jun 2022
            • 64
            Both Pins on L6995 are around 125k ohms now that L6995 is soldered back.
            Is it safe now to plug in the magsafe connector?
            • mon2
              • 14672
              I think it is. Do measure the output of the L6995 and it should be ~3v42 if all is well.
              • Nuld_
                • Jun 2022
                • 64
                Still reading nothing on L6995 and U6990 isn´t producing PP3V42_G3H.
                • Nuld_
                  • Jun 2022
                  • 64
                  And U7941 is now shorting again on Pin 1.
                  • mon2
                    • 14672
                    Confirm the input voltage to U6990, pin # 7 - measure @ D6990, pin # 3 (PPVIN_G3H_P3V42G3H).
                    • Nuld_
                      • Jun 2022
                      • 64
                      Pin 7 is reading 16,6V and Pin 3 is at 15,1V.
                      • mon2
                        • 14672
                        Are you using an official magsafe adapter ?
                        Remove all power, check the resistance to ground of L6995, pin #2. Be sure that L6995 inductor is soldered in properly and mating with the PCB pads.
                        • Nuld_
                          • Jun 2022
                          • 64
                          It reads around 3 ohms again. I guess it fried the U7941 again.
                          It´s not a official magsafe adapter but it worked with the samelogicboard in the past.
                          • mon2
                            • 14672
                            I would buy a Costco lot of U7941 devices from Aliexpress. Do ask if they are valid for macbook repairs but believe this is a fixed function device that should just operate as expected upon soldering. Silego has many programmable devices and you need special tools and IP to configure them otherwise.
                            Remove all power and check the resistance to ground of the 3 x outputs of this device (pin 4, 3 and 8).
                            What are the readings ?
                            • Nuld_
                              • Jun 2022
                              • 64
                              Pin 4 is at 15Mohms, Pin 3 is at 15,6Mohms and Pin 8 is at 15,6Mohms aswell.
                              • mon2
                                • 14672
                                The resistance is ok.
                                Very strange, yet this part dies.
                                What are the resistance readings to ground for the input pins 2, 6, 7 ?
                                Would not be a bad idea to source & replace U6990 (PM6640). If nothing else, you will have spare parts for future repairs.
                                • Nuld_
                                  • Jun 2022
                                  • 64
                                  Readings on U7941 are:
                                  Pin 1: 2,6 ohms
                                  Pin 2: 16.1 Mohms
                                  Pin 3: 16 Mohms
                                  Pin 4: 16 Mohms
                                  Pin 5: 2,5 ohms
                                  Pin 6: 676 ohms
                                  Pin 7: O.L
                                  Pin 8: 16 Mohms
                                  Readings on U6990:
                                  Pin 1: 1,2 Mohms
                                  Pin 2: O.L
                                  Pin 3: something around 2Mohms
                                  Pin 4: something around 2,2 Mohms
                                  Pin 5: 0,3 ohms
                                  Pin 6: 2,9 ohms
                                  Pin 7: something around 2,2 Mohms
                                  Pin 8: O.L
                                  Pin 9: 2,4 ohms
                                  Pin 10: 167k ohms
                                  • mon2
                                    • 14672
                                    Remove U7941 off the board.
                                    Does the low resistance disappear @ L6995, pin # 2 ?
                                    If yes, power up (without U7941) and confirm if the voltage @ L6995, pin # 2 = +3v42.
                                    • Nuld_
                                      • Jun 2022
                                      • 64
                                      Pin 2 of L6995 is reading 130,5k ohms
                                      Voltage is reading 0V.
                                      • Nuld_
                                        • Jun 2022
                                        • 64
                                        Uhm, now Greenlight is on with 3,4V on Pin 2 of L6995 without U7491 even attached.
                                        And U7200 is getting hot too.
                                        • Nuld_
                                          • Jun 2022
                                          • 64
                                          U7200 Ohm Readings:
                                          Pin 1: 115k
                                          Pin 2: 8,32k
                                          Pin 3: 383k
                                          Pin 4: 1M
                                          Pin 5: 3,92k
                                          Pin 6: 78,6k
                                          Pin 7: 3,1
                                          Pin 8: 1M
                                          Pin 9: O.L
                                          Pin 10: 43,4
                                          Pin 11: 3
                                          Pin 12: 106,5 k
                                          Pin 13: O.L
                                          Pin 14: 382k
                                          Pin 15: 0
                                          Pin 16: 4,5
                                          Pin 17: 37,5
                                          Pin 18: 800
                                          Pin 19: 106,7k
                                          Pin 20: 6,4
                                          Pin 21: 106k
                                          Pin 22: O.L
                                          Pin 23: 10k
                                          Pin 24: 6,2
                                          • Adogabriel100
                                            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                            by Adogabriel100
                                            Hey! This is a A1278 macbook 2011.
                                            Problem: Not turning on / No green light
                                            Im using by3200s charger.
                                            Voltajes:
                                            PPBUS_G3H = 12.26v
                                            SMC_RESET_L = 3.3v
                                            PP3V42_G3H = 3.42v
                                            U7000 =
                                            Pin 1 CHGR_AGATE = 0v
                                            Pin 2 CHRG_DCIN = 19v
                                            Pin 3 CHRG_ACIN = 4.6v
                                            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                            Pin 12 PP3V42_G3H = 3.42v
                                            Pin 13 CHRG_RST_L = 3.3V
                                            Pin 14 SMC_BC_ACOK = 0.8V
                                            Pin 19 PP5V1_CHRG_VDD = 5.05V
                                            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                            04-01-2024, 01:02 PM
                                          • envym
                                            by envym
                                            Hi everyone!
                                            06-27-2025, 08:54 AM
                                          • salopian
                                            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                            by salopian
                                            Hello. I would need some advice please.
                                            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                            I have already replaced the logic board with another...
                                            02-27-2021, 07:30 AM
                                          • mferna14
                                            Apple MacBook A1398 820-00138-A missing 5V
                                            by mferna14
                                            HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
                                            01-16-2023, 01:35 PM
                                          • fajfelek
                                            Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                                            by fajfelek
                                            Hello, First of all thanks you for reading this topic.
                                            I need your help with identify missing parts on trackpad logic board (661-18430).
                                            The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                                            Please help me with identity parts from blue and red area .
                                            06-15-2024, 01:41 PM
