Apple MacBook A1398 820-00138-A missing 5V
  • mferna14
    • Jun 2018
    • 1046
    HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is missing too. Any tips what portion should I be checking next for the voltages. Thanks in advance.
  • reformatt
    • Feb 2020
    • 1495
    Re: Apple MacBook A1398 820-00138-A missing 5V
    PM_SLP_S5 is right at the beginning of the power sequence, so any S4 or later rails are irrelevant. Troubleshoot with the sequence on LogiWiki
    https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
    Check all coils for shorts, especially the 1.05V rail for the PCH.
    • mferna14
      • Jun 2018
      • 1046
      Thanks "reformatt", appreciate your reply. I did some deep troubleshooting, hopefully today might get some answers. Thanks for the tips & will surely go through this sequence.
      • mferna14
        • Jun 2018
        • 1046
        @reformatt, Sequencely trouble shooted & found that PP3V3_SUS is not present at all. Zero Volts out here. But PPDCIN_G3H 20V is perfect & present. Now I have to see from where is PP3V3_SUS generated, should be 3.3v on this rail. Any tips will be greatly apprecaited. Thanks
        • reformatt
          • Feb 2020
          • 1495
          PP3V3_SUS is switched by Q8020 and enabled by PM_SLP_SUS_L. Check the resistance of that rail to ground, and at L7630 as well. PM_SLP_SUS_L is derived from the PCH, and these have a tendency to die in the A1398.
          • mferna14
            • Jun 2018
            • 1046
            I was checking with a know good Logic Board & observed that PM_SLP_SUS_L on the defective one is missing. Q8002 pin 5 should be 3.3v in order to enble Q8020 & then PP3V3_SUS will be present, I think PCH is defective as this signal is directly coming from the PCH. Hopefully I have one to replace. First, I will just re-flow it, many of times it happens, & due to heat solder goes dry. Will let you know. Thanks
            • reformatt
              • Feb 2020
              • 1495
              Reflowing the PCH is a bit drastic, and would be my last avenue, not the first. Check the pre-requisites for PM_SLP_S5_L from the power seqeunce.
              My main thought re the PCH is they are usually shorted and it saves time to rule it out.
              • mferna14
                • Jun 2018
                • 1046
                You are 100% RIGHT @reformatt!!! Before I could do any re-flow on any chip, what I did was I totally removed Q8020 & then checked PM_SLP_SUS_L on Q8002 pin 5. & guess what, it started to appear from nowhere??? Now I knew something was wrong between Q8002 pins 3 & 4 & Q8020 pin 3 & 4/7. Q8020 pin 4/7 was getting the PP3V3_S5 volts normally. So I knew 100% that this logic board has a defective Q8020 SIA413DJ. I got a donor for an older 820-2915-A board. Replaced it & all is working like charms & PP3V3_SUS came back. Once again thanks for all the help you offered & we together were able to revive the smiley Mac Logo once again. Pls. inform me once thing more, is the BIOS different on all these models? Because I put in this board's BIOS in another working logic board & it did not give any dsplay though it turned on. Even though I did change the serial # & in UEFI Tool program all was valid & then I did an Intel CleanMe, but this did not work on a 100% working logic board. Then I put back all the Originals ones in the respective boards & the logic board worked 100% fine. Did you ever see this???
                • reformatt
                  • Feb 2020
                  • 1495
                  Good stuff. A rule I was taught years ago is that the likelihood of a component causing a fault is inversely proportional to the number of legs (or pads now) it has. The more legs/pads, the less likely it is to be the fault. Although BGA's have altered that a bit these days.
                  Have to use a donor BIOS from the same board number (i.e. another 820-00138). There are many variants of the A1398 so you can't just go off that. A board will still boot with a dirty ME, just albeit much slower.
                  • mferna14
                    • Jun 2018
                    • 1046
                    Do you know the variants of the A1398 that have to be replaced or changed?? might as well learn this too if you can pass on this knowledge. Thanks
