Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
+ More Options
Posts
  • fajfelek
    • Nov 2014
    • 5
    • Poland
    Hello, First of all thanks you for reading this topic.
    I need your help with identify missing parts on trackpad logic board (661-18430).
    The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
    Please help me with identity parts from blue and red area .
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Diod mode:
    94,4kohm
    0.380mhom
    0.506mohm
    • fajfelek
      • Nov 2014
      • 5
      • Poland
      Thank you. I used 2x470K 201 resistors (blue area), resoldered resistor in red area and trackpad back to life
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        • briztech
          identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
          by briztech
          Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
          07-25-2024, 06:18 AM
        • Vliegenier04
          Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
          by Vliegenier04
          Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
          I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
          Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
          06-16-2025, 12:03 PM
        • jkruns
          M1 A2338 screen and touchbar issues after cleaning up liquid damage
          by jkruns
          This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
          My patient is an A2338 Macbook Pro M1 (late 2020).
          It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
          04-22-2024, 06:45 AM
        • BMCappelletti
          Macbook Air A1466 EMC 3178 missing power and liquid damaged
          by BMCappelletti
          Hi everyone.
          Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
          Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
          04-15-2024, 01:24 PM
        • edugimeno
          Help me identify the missing component... Sound to light circuit
          by edugimeno
          hI there!
          Im trying to help a friend repairing a large, real-sized short-circuit robot.
          This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
          Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
          What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
          So I bought a simple 2X30W amplifier to feed the loudspeaker...
          02-14-2024, 10:23 AM
