Questions about schematics/pcbs
  • mrkmpn
    • Apr 2022
    • 59
    My 1st question is regarding PCB markings:
    Some components marked on the PCB are prefixed with a 'p', so for example, rather than c101 it might be 'pc101', or r101 - 'pr101', etc... so what does the addition of the 'p' on these components indicate?
    My next question is regarding component values on the schematics:
    SC10U25V3MX-GP
    It looks like this capacitor is 10uf 25v, but I'm not sure what else is indicated here. What does "s" at the beginning, and the 3mx at the end indicate? I'm assuming that since everything in the schematics ends in "gp" that can be ignored.
    3D9R3-GP
    If I'm following things correctly, based on the boardview, this resistor on the board has 3.9 printed on top. (or would have to be 6.E). But from what I've read, the letter R is usually used to indicate a decimal (like 3R9). So I'm confused about the value above indicated on the schematic for this resistor.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: Questions about schematics/pcbs
    3D9R3-GP - 3.9ohm
    SC10U25V3MX-GP - 10u 25V
    • mon2
      • Dec 2019
      • 13995
      SC10U25V3MX-GP
      Yes, 10uf @ 25V capacitor. Very likely the p/n supplied by the vendor of the part used for the PCBA (PCB assembly). Probably an electrolytic or tantalum capacitor so will have a polarity. The above full part number should be linked to some vendor but could be buried in the many many many manufacturers in Asia.
      -GP = General Purpose
      3D9R3-GP
      As per above but since you have observed 3.9 = 3R9 (is the style we like to use for our product design as my eyes are not as they used to be. Steve Austin, astronaut... days are in the past so it is easy to miss out on the decimal place when we are cross checking the designs before prototypes are built).
      3R9 = 3.9 ohms.
      • mrkmpn
        • Apr 2022
        • 59
        3R9 = 3.9 ohms.
        Thanks for the reply, on the capacitor it is an 0805 size smd cap. I've tried searching the numbers on google, but all of the results are for other schematics from various manufacturers' boards using the same label for capacitors. This is the only component (so far) that I know needs to be replaced.
        I'm still confused on the resistor. Is 3D9 interchangeable with 3R9, and if so what is the next R and 3 for? I don't need to replace this resistor, I'm just trying to understand how to decode the information on the schematics for future situations where I might not be able to read the top of the resistor.
        • mon2
          • Dec 2019
          • 13995
          With experience, you will hunt these parts down like Dog the Bounty Hunter.
          Can you share a picture of the part? What is the body color?
          If it is flesh / cream color, then the part is an 0805 ceramic non-polarized capacitor. Check Samsung / Walsin brands, etc.
          If you see a '+' or band on the part, then it is polarized and ideally should be replaced with a similar. Pretty sure you are up against a generic ceramic cap in 0805 size.
          Check Mouser and Digikey for these.
          I have not seen 3D9 used but have seen 3R9 which may have started from Europe as a convention.
          • mrkmpn
            • Apr 2022
            • 59
            From what I've seen it does appear to be a ceramic capacitor. The one that's bad is burnt, but according to the schematics the two nearest capacitors are identical and don't appear to have any signs of polarization marks.
            Thanks again.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              could be the p is a certain part of the circuit . power supply maybe ..
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                P is in my knowledge PR power resistor and Power condensator PC. If I am wrong somebody please correct me.
                Regards
                Steve
                • mrkmpn
                  • Apr 2022
                  • 59
                  Regards
                  Steve
                  I finally found a list of abbreviations that that included the information.
                  PC :POWER CAPACITOR
                  PD :POWER DIODE
                  PL :POWER INDUCTOR
                  PQ :POWER TRANSISTOR
                  PR :POWER RESISTOR
                  PU :POWER INTEGRATED CIRCUIT
                  • mrkmpn
                    • Apr 2022
                    • 59
                    In case anyone else comes across this with questions about the component labels on schematics..., and because googling them showed results for schematics from multiple manufacturers, I thought I'd share this. I found the information on page 2 of the schematics... (noob mistake not looking there I guess)
                    Resistors:
                    The naming rule is value + R + size + tolerance
                    For the value, it can be read by the number before R. (R means resistor)
                    For the tolerance, it can be read from the last letter.
                    For the rating, we don't show on the symbol name.
                    For the size, R2=>0402, R3=>0603, R5=>0805,...
                    Rating, 0402=> 1/16W, 25v, 0603 => 1/16W, 75V, 0805 => 1/10W, 100V
                    Tolerance (J: 5%, F: 1%, D: 0.5%, B: 0.1, No letter means J)
                    For example: 33D3R5 = 33.3 Ohm / 0805 package 5% tolerance
                    1KR3F = 1K Ohm / 0603 package 1% tolerance
                    Capacitors:
                    The naming rule is
                    Capacitor type + value + rating + size + tolerance + material
                    SCD1U10V2MX-1
                    SC=> SMT Ceremic, TC=> POS cap or SP cap
                    D1U => 0.1uF
                    10V => the voltage rating is 10V
                    2=> 0402, 3=>0603, 5=>0805
                    M=>tolerance M, K, Z (M: +/-20, K: +/-10, Z: +80/
                    size (2=>0402, 3=>0603, 5=>0805, 6=>1206, 0=>1210)
                    X=> X7R/X5R, Y=> Y5V
                    -1 => symbol version, nonsense to EE characteristic
                    • tbsmith
                      • Sep 2016
                      • 12
                      Resistors:
                      Capacitors:
                      The naming rule is
                      SCD1U10V2MX-1
                      D1U => 0.1uF
                      Thanks, useful information!
                      • Popalwali
                        Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
                        by Popalwali
                        Hello Everyone,
                        I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
                        08-25-2024, 11:28 AM
                      • Techmanx
                        Schematics Download Site
                        by Techmanx
                        If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
                        06-28-2023, 12:08 PM
                      • snpulse3344
                        USB Audio Interface - Steinberg UR 12 or similar schematics
                        by snpulse3344
                        I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
                        03-01-2024, 01:07 PM
                      • sunofra78
                        iPhone 12 Pro Max Schematics
                        by sunofra78
                        Hi.
                        Does anyone have iPhone 12 Pro Max Schematics they can share? I have the board view through ZXW... but really need the schematics.
                        Thanks!...
                        07-14-2025, 01:56 AM
                      • JoSta
                        Can somebody explane notation in schematics
                        by JoSta
                        I have been checking schematics for my motherboard and have difficulties to understand it. I figured that i need to replace the component designated with PQB03 on the board. In the schematics I find two entries with different components, although they have almost similar specs. I could not find an explanation for the prefixes "G1G3@" or "G2@"
                        Can somebody help me?
                        07-08-2025, 12:05 PM
