Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
  • electronx
    • Jun 2025
    • unk
    I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
    1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
    According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
    If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid, or is it against the USB specification to use SuperSpeed Type-A for USB 3.2 Gen 2×2? (The specification table seems to suggest it’s possible, but I’m unsure.)
    USB 3.2 Gen 1×1 and Gen 2×1 Designs
    When reviewing designs for USB 3.2 Gen 1×1 and USB 3.2 Gen 2×1, I noticed the following:
    If the host is in DFP mode, a single-lane connection can directly be made using SuperSpeed+ (SS+) Type-A connectors. This setup is straightforward and doesn’t seem to require anything additional.
    However, if we want to use USB Type-C with these standards:
    A MUX is typically required for orientation switching.
    Additionally, a USB Power Delivery (USB PD) controller is often needed to handle the orientation, as well as the role selection (DFP, UFP, or DRD).
    USB 3.2 Gen 2×2 and USB4 Gen 3×2 Designs
    I couldn’t find clear reference designs for USB 3.2 Gen 2×2, USB4 Gen 3×2, or USB4 Gen 4×2.
    When using USB Type-C with these standards, is a MUX still required for orientation switching?
    These standards use 2 lanes, and USB Type-C connectors have pins for RX1, TX1, RX2, and TX2. If all these pins are fully connected via hardwiring, is orientation switching still necessary? Or can the connection work without a MUX?
    I’m particularly curious about how the orientation affects the use of RX1/TX1 and RX2/TX2 pins.
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • Junkrepair
    Meaning of "Not For New Designs"
    by Junkrepair
    Looking through listings of Aluminum Electrolytics at DigiKey, I see on some caps a Product Status of "Not For New Designs".
    I'm replacing some Sacon SZ series caps that have seemingly-impossible specs, meaning that it's hard to find product that meets the specs. Some of the ones that come closest have a status of "Not For New Designs". Can you give some insight about where this idea comes from and what it implies?
    06-24-2023, 12:34 PM
  • remtep
    Bios Chip orientation
    by remtep
    Can any one please help, Can you tell me the orientation of this Bios Chip I think it is black up or is it silver and black up. Plus it does not have a dot like the one on the board I am assuming it is were the cut out on the corner of the silver is....
    07-26-2021, 08:14 AM
  • jacobtc
    Component orientation on PS4 Pro
    by jacobtc
    Hi, just got done soldering of a broken HDMI port on a PS4 Pro, however while doing so I unfortunately knocked off a diode(?) on the board, I found it, however I am not sure of its orientation, and can't seem to find any pictures of it online. Can anyone help me out? Right now I just tacked it on to prevent it disappearing completely.
    Its marked "A"
    Pics: https://imgur.com/a/1ubbz3d
    07-10-2021, 09:38 AM
  • powerblackout
    820-00923-A No left side USB activity
    by powerblackout
    Board couldn't boot due to corrosion under UB090, stuck at 5v 20-30mah. After cleaning that up the board boots and charges, 20V on all 4 TB ports.
    Trackpad and keyboard currently don't work due to a failed battery swap that left gouges in the trackpad board exposing traces. Touch bar doesn't work either, haven't started troubleshooting that.
    USB devices aren't detected on the JB500 connector. any orientation, either of the ports. Tried known working flex connector. When using an ammeter I see no power flowing out to the USB device, when connected to J3300 5V 200mah goes...
    01-01-2023, 11:30 PM
