Questions about schematics/pcbs
  • mrkmpn
    • Apr 2022
    • 62
    My 1st question is regarding PCB markings:
    Some components marked on the PCB are prefixed with a 'p', so for example, rather than c101 it might be 'pc101', or r101 - 'pr101', etc... so what does the addition of the 'p' on these components indicate?
    My next question is regarding component values on the schematics:
    SC10U25V3MX-GP
    It looks like this capacitor is 10uf 25v, but I'm not sure what else is indicated here. What does "s" at the beginning, and the 3mx at the end indicate? I'm assuming that since everything in the schematics ends in "gp" that can be ignored.
    3D9R3-GP
    If I'm following things correctly, based on the boardview, this resistor on the board has 3.9 printed on top. (or would have to be 6.E). But from what I've read, the letter R is usually used to indicate a decimal (like 3R9). So I'm confused about the value above indicated on the schematic for this resistor.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Questions about schematics/pcbs
    3D9R3-GP - 3.9ohm
    SC10U25V3MX-GP - 10u 25V
    • mon2
      • 14659
      SC10U25V3MX-GP
      Yes, 10uf @ 25V capacitor. Very likely the p/n supplied by the vendor of the part used for the PCBA (PCB assembly). Probably an electrolytic or tantalum capacitor so will have a polarity. The above full part number should be linked to some vendor but could be buried in the many many many manufacturers in Asia.
      -GP = General Purpose
      3D9R3-GP
      As per above but since you have observed 3.9 = 3R9 (is the style we like to use for our product design as my eyes are not as they used to be. Steve Austin, astronaut... days are in the past so it is easy to miss out on the decimal place when we are cross checking the designs before prototypes are built).
      3R9 = 3.9 ohms.
      • mrkmpn
        • Apr 2022
        • 62
        3R9 = 3.9 ohms.
        Thanks for the reply, on the capacitor it is an 0805 size smd cap. I've tried searching the numbers on google, but all of the results are for other schematics from various manufacturers' boards using the same label for capacitors. This is the only component (so far) that I know needs to be replaced.
        I'm still confused on the resistor. Is 3D9 interchangeable with 3R9, and if so what is the next R and 3 for? I don't need to replace this resistor, I'm just trying to understand how to decode the information on the schematics for future situations where I might not be able to read the top of the resistor.
        • mon2
          • 14659
          With experience, you will hunt these parts down like Dog the Bounty Hunter.
          Can you share a picture of the part? What is the body color?
          If it is flesh / cream color, then the part is an 0805 ceramic non-polarized capacitor. Check Samsung / Walsin brands, etc.
          If you see a '+' or band on the part, then it is polarized and ideally should be replaced with a similar. Pretty sure you are up against a generic ceramic cap in 0805 size.
          Check Mouser and Digikey for these.
          I have not seen 3D9 used but have seen 3R9 which may have started from Europe as a convention.
          • mrkmpn
            • Apr 2022
            • 62
            From what I've seen it does appear to be a ceramic capacitor. The one that's bad is burnt, but according to the schematics the two nearest capacitors are identical and don't appear to have any signs of polarization marks.
            Thanks again.
            • petehall347
              • Jan 2015
              • 4440
              could be the p is a certain part of the circuit . power supply maybe ..
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                P is in my knowledge PR power resistor and Power condensator PC. If I am wrong somebody please correct me.
                Regards
                Steve
                • mrkmpn
                  • Apr 2022
                  • 62
                  Regards
                  Steve
                  I finally found a list of abbreviations that that included the information.
                  PC :POWER CAPACITOR
                  PD :POWER DIODE
                  PL :POWER INDUCTOR
                  PQ :POWER TRANSISTOR
                  PR :POWER RESISTOR
                  PU :POWER INTEGRATED CIRCUIT
                  • mrkmpn
                    • Apr 2022
                    • 62
                    In case anyone else comes across this with questions about the component labels on schematics..., and because googling them showed results for schematics from multiple manufacturers, I thought I'd share this. I found the information on page 2 of the schematics... (noob mistake not looking there I guess)
                    Resistors:
                    The naming rule is value + R + size + tolerance
                    For the value, it can be read by the number before R. (R means resistor)
                    For the tolerance, it can be read from the last letter.
                    For the rating, we don't show on the symbol name.
                    For the size, R2=>0402, R3=>0603, R5=>0805,...
                    Rating, 0402=> 1/16W, 25v, 0603 => 1/16W, 75V, 0805 => 1/10W, 100V
                    Tolerance (J: 5%, F: 1%, D: 0.5%, B: 0.1, No letter means J)
                    For example: 33D3R5 = 33.3 Ohm / 0805 package 5% tolerance
                    1KR3F = 1K Ohm / 0603 package 1% tolerance
                    Capacitors:
                    The naming rule is
                    Capacitor type + value + rating + size + tolerance + material
                    SCD1U10V2MX-1
                    SC=> SMT Ceremic, TC=> POS cap or SP cap
                    D1U => 0.1uF
                    10V => the voltage rating is 10V
                    2=> 0402, 3=>0603, 5=>0805
                    M=>tolerance M, K, Z (M: +/-20, K: +/-10, Z: +80/
                    size (2=>0402, 3=>0603, 5=>0805, 6=>1206, 0=>1210)
                    X=> X7R/X5R, Y=> Y5V
                    -1 => symbol version, nonsense to EE characteristic
                    • tbsmith
                      • Sep 2016
                      • 22
                      Resistors:
                      Capacitors:
                      The naming rule is
                      SCD1U10V2MX-1
                      D1U => 0.1uF
                      Thanks, useful information!
                      • studdy05
                        Bricked HP Probook 450 G7 Bios questions
                        by studdy05
                        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                        Ive got...
                        07-08-2025, 09:24 PM
                      • electronx
                        Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                        by electronx
                        I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                        1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                        According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                        If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                        06-26-2025, 03:27 AM
                      • UL161
                        Need Help Identifying Parts on a crossover and a few other newbie questions
                        by UL161
                        Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
                        1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
                        2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
                        09-29-2024, 03:17 PM
                      • cloghin
                        newbie questions
                        by cloghin
                        Apologies if I am asking the wrong questions , but not sure how else to start:
                        I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
                        * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
                        * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
                        09-26-2024, 11:48 AM
                      • KYBOSH
                        Samsung UN50TU8000 - Dead Panel Forensic Questions
                        by KYBOSH
                        I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                        When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                        When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                        Later I checked for shorts on the panel PCB boards but could not find anything.
                        When I took a look with the FLIR i noticed the 2 resistors...
                        08-10-2024, 08:39 AM
