MacBook Pro A1286 Mid 2012 no power, no LED on the charger
  • mon2
    • Dec 2019
    • 14265
    Re: MacBook Pro A1286 Mid 2012 no power, no LED on the charger
    What is the voltage of PPVCORE_S0_GFX_REG ? (with LCD connected)
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      #62
      Mon2, with power on?
      • Gigabit2
        • Apr 2022
        • 264
        • United Kingdom
        #63
        Do you have a test point for PPVCORE_S0_GFX_REG?
        • mon2
          • Dec 2019
          • 14265
          Yes. See attached. Yes, with power on - need to see if the power rail for the GPU is working.
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            #65
            Measuring 0.89 on 20V mode, tested with C9861, C9862, C9863, C9864, all showing same
            • mon2
              • Dec 2019
              • 14265
              Voltage for this power rail is OK.
              What are the voltage readings for the following (with LCD & powered on)?
              LCD_PWR_EN
              PP3V3_S5_LCD
              PP3V3_SW_LCD
              See attached.
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                #67
                LCD_PWR_EN tested at R9094 showing .013 on 2V mode.
                PP3V3_S5_LCD tested at C9009 showing 3.31 on 20V mode.
                PP3V3_SW_LCD tested at C9002 showing 00.2 on 200m mode.
                • Gigabit2
                  • Apr 2022
                  • 264
                  • United Kingdom
                  #68
                  Hi mon2,
                  Hope you are having a nice weekend. When you get some time, please can you review the above. No hurry.
                  • mon2
                    • Dec 2019
                    • 14265
                    Hi. Do not have this board here but here is what I believe may be happening..
                    < just review as random thoughts in my head on this case >
                    1) this logic board is known to have GPU issues and was built with AMD & NVIDIA video chipsets. The AMD GPU was the flaky one and NVIDIA was apparently much improved with only a few faults.
                    2) there are assorted articles (by DOSDUDE) on how to disable a defective GPU use but do not believe this is your case since the HDMI external video is working OK. The chart on page
                    3) instead, suspecting the fault is with the video MUX (multiplexer) @ U9600. Think of the MUX has a multiple SPDT solid-state switches that route a group of signals from a single source to either position of 'A' = HDMI side or 'B' = LCD side.
                    4)
                    LCD_PWR_EN is created by N8 ball on U9600 BGA device.
                    5) U9600 is a Lattice FPGA = empty and blank chip if purchased new from Lattice Semiconductor and a JTAG programmer is used to reflash it with custom code (IP) to make it do the function you would like. From a brief review, DOSDUDE sells a single use license to bypass the MUX but you can Google for more information or even ping him - I believe that we contacted him a few years ago and he was very helpful and was working off donations back then. We did donate and just charged our customer for the fix & donation. That is our only experience with this model to date.
                    Believe an idea is to hunt down a donor board -> remove this U9600 and replace on this non-working board since the donor board will have a programmed FPGA device. Highly recommend to email DOSDUDE for advice with the summary of this thread. HDMI video works / LCD remains dark. Mention that the above LCD_PWR_EN is LOW and this is driven by the same Lattice FPGA acting like a MUX.
                    Respectively, if the HDMI half of this FPGA is working - is this FPGA considered defective ?
                    BANK7 of U9600 pins = INPUT from GPU
                    BANK0 of U9600 pins = LCD display output signals
                    But do review the assorted other muxes linked to the video flow on page 86 (Muxed Graphics Support) of the schematics.
                    Is there a defect here ?
                    Wait on more feedback from others and certainly ping DOSDUDE1 for his comments. He has at least one video on Youtube about the mux but do not believe it is your case - he mentioned about the loss of the power rail for the GPU which you have confirmed is ok @ 0v9. His case had 0v for the GPU power.
                    Will review more after a Costco run...
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      #70
                      Would anyone else care to assist? Thank you to @mon2 for all their help thus far
                      • mon2
                        • Dec 2019
                        • 14265
                        What is the power rating of your magsafe power supply that is being used for these tests ?
                        1) Given that this logic no longer posts if the LCD display is attached - the cable or display are strapping the motherboard.
                        2) In reviewing again, page 2 of the schematic, the logic flow is:
                        a) external video is driven by the NVIDIA GPU - if the external video is stable then the GPU is fine as you posted earlier
                        b) the GMUX @ U9600 takes input from the dedicated GPU (NVIDIA) or the INTEL internal video controller and routes it to the LCD connector @ J9000.
                        Post the voltage readings for the following:
                        PP1V2_S0_GMUX
                        PP1V8_S0_GMUX
                        PP3V3_S0_GMUX
                        PP3V3_S0_GMUX_R
                        PP3V3_S3_GMUX
                        GMUX_S3_PD_GND
                        ALL_SYS_PWRGD
                        LCD_BKLT_PWM (before R9704)
                        BKL_PWM (after R9704)
                        See attached for reference. You can measure at any of the highlighted parts for the respective power rail.
                        Confirm the resistance of resistor @ R9714. This resistor value is critical to configure the max current that the backlight power supply will support for the boosted power rail.
                        • Gigabit2
                          • Apr 2022
                          • 264
                          • United Kingdom
                          #72
                          Hi mon2,
                          It is 85W. Also used another adapter and a USB-C to MagSafe converter connected to an 85W supply and the same issue occurs.
                          PP1V2_S0_GMUX: 1.2V with 20V mode
                          PP1V8_S0_GMUX: 1.8V with 20V mode
                          PP3V3_S0_GMUX: 3.32V with 20V mode
                          PP3V3_S0_GMUX_R: 3.32V with 20V mode
                          PP3V3_S3_GMUX: 3.32V with 20V mode
                          GMUX_S3_PD_GND: 2.64V with 20V mode
                          ALL_SYS_PWRGD: 3.28V with 20V mode
                          LCD_BKLT_PWM (before R9704): 0.08 with 200m mode
                          BKL_PWM (after R9704): 0.08 with 200m mode
                          Resistance of resistor @ R9714: 16.1 with 200k mode
                          • mon2
                            • Dec 2019
                            • 14265
                            Post the voltage on each side of R9676.
                            • Gigabit2
                              • Apr 2022
                              • 264
                              • United Kingdom
                              #74
                              Pin 1: 3.32 with 20V mode
                              Pin 2: 00.5 with 200m mode
                              • mon2
                                • Dec 2019
                                • 14265
                                In the 2nd pic above, there are numerous resistors in the schematic.
                                Measure and post the voltage readings on each side of the resistors.
                                Be very careful as the parts are small.
                                From a similar thread on Louis' forum, the GMUX_S3_PD_GND value on your board is low as compared to another tech who reported 3v0.
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  • United Kingdom
                                  #76
                                  R9678
                                  Pin 1: 0.13 with 200m mode
                                  Pin 2: 2.65 with 20V mode
                                  R9671
                                  Pin 2: 2.64 with 20V mode
                                  R9672
                                  R9673
                                  Pin 1: 3.31 with 20V mode
                                  R9674
                                  R9675 - not present
                                  2.64 on one side with 20V mode, 0.00 on other (as expected with nothing present)
                                  • mon2
                                    • Dec 2019
                                    • 14265
                                    (from another forum so it is censored)
                                    is related to your case.
                                    If I understand the translation correctly, suggest is to reflash the mux at U9600.
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      • United Kingdom
                                      #78
                                      Hi @mon2, how would I go about doing this? Which tools would I need?
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        • United Kingdom
                                        #79
                                        @mon2, is there no issue with R9678? Not boosting to 3.32V, as other resistors are?
                                        • mon2
                                          • Dec 2019
                                          • 14265
                                          No, R9678 is ok but is an output enable signal from the mux chip by Lattice (U9600). The output is low.
                                          You will need a JTAG programmer. More details after some research on this topic.
                                          • SarcasticOP
                                            General question about MacBook power rails for repair.
                                            by SarcasticOP
                                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                            • PPBUS_G3H (12.6V-12.8V)
                                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                            • PP3V42_G3H (3.42V)
                                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                            • PPVRTC_G3H (3.3V)
                                              • This
                                            12-12-2024, 05:50 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • durchfall
                                            MacBook 2011 A1286 power cycle, no chime
                                            by durchfall
                                            I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                                            What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                                            01-11-2023, 05:56 AM
