MacBook 2011 A1286 power cycle, no chime
  • durchfall
    • Dec 2022
    • 13
    • Czech Republic
    I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
    What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds, power light glows, no chime, then fans stop spinning for about 5 seconds, then they spin up for 10 seconds and this cycle just repeats. If I start it without RAM, fans stay spinning indefinitely and it does beep as it should. Both CPU and PCH are getting warm. I checked for shorts, couldn't find any. There is no visible corrosion on the board. I measured voltages, all measurements were done with battery disconncted, here are the results:
    PPBUS_G3H 12.6V
    PPVIN_S5_HS_COMPUTING_ISNS 12.6V
    PPVIN_S5_HS_GPU_ISNS 12.6V
    PPVIN_S5_HS_OTHER_ISNS 12.6V
    PPDCIN_G3H 16.5V when fan spins 16.2 when fan doesn't spin, battery disconnected
    PP3V42_G3H 3.48V
    PPVRTC_G3H 3.35V
    PP5V_S5 5V
    PP5V_SUS 5V
    PP5V_S3 5V
    PP5V_S0 5V
    PP3V3_S4 3.35V
    PP3V3_SUS 3.35V
    PP3V3_S5 3.35V
    PP3V3_S3 3.35V
    PP3V3_S0 3.35V
    PP3V3_T29 3.35V
    PP1V05_T29 1.03V
    PP15V_T29 0.5V not shorted (84kOhm)
    PP1V8_S0 1.8V
    PP1V8_S0_CPU_VCCPLL_R 1.8V
    PP1V5_S3 1.5V
    PP1V5_S3RS0_CPUDDR 1.5V
    PP1V5_S0 1.5V
    PPVTTDDR_S3 0.75V
    PP0V75_S0_DDRVTT 0.75V
    PP1V2_S0 1.2V
    PP1V05_SUS 1.05V
    PP1V05_S0 1.05V
    PP3V3_S0GPU 3.35V
    PP1V8_GPUIFPX 1.8V
    PP1V8_S0GPU_ISNS 1.8V
    PP1V5_GPU_REG 1.5V
    PP1V5_S0GPU_ISNS 1.5V
    PP1V0_S0GPU 1V
    PP1V0_S0GPU_ISNS 1V
    PPVCORE_GPU 1.1V
    PPVCORE_S0_CPU 1.15V
    PPVCORE_S0_AXG 0V no short, should just mean it's not getting far enough in POST
    PP1V5_S3_CPU_VCCDQ 1.5V
    PP1V05_S0_CPU_VCCPQE 1.05V
    PPVCCSA_S0_REG 0.8V
    PPVP_FW 12.65V
    PP3V3_FW_FWPHY 3.35V
    PP1V0_FW_FWPHY 1V
    PPBUS_SW_BKL 0V no short, probably just doesn't get far enough to initialize backlight
    PP3V3_ENET 3.35V
    PP1V2_ENET 1.2V
    ALL_SYS_PWRGOOD 3.3V
    SMC_RESET_L 3.47V
    Some more info: This machine used to belong to an ex colleague who left it at work, so I decided to take it. I installed macOS on a different machine, deleted radeon kexts and enabled screen sharing. I swapped the drive into it, let it boot up with a blank screen, remoted into it and wrote NVRAM parameters to enable IGP. It did work just fine after that. Then I decided to upgrade RAM, so I did and when I powered it on afterwards, it started doing the power cycle loop thing. As I already said, a repair canter physically removed both the GPU and VRAM. They didn't clean up, pads still had solder balls and a ton of flux. So I cleaned the pads with some solder wick and used alcohol to get rid of the old flux. No change, still power cycling. So I left it do its power cycle thing, after about 10 minutes it suddenly chimed and started right up. So I shut it down, upgraded RAM, turned it on and after about 10 minutes of power cycling, it started. But the next day it wouldn't start even after two hours. I tried desoldering R8911 to disable GPU power completely, that changed nothing. So I ran a bodge wire to reenable GPU power, again, no change. The machine did originally start even in SMC bypass mode btw, in the brief time it worked. It started even in normal mode. I'm not a board repair technician, I'm just trying to fix this thing for fun, but I'm already at my wits' end. Do you have any idea what could be wrong with it? All voltages seem to be there, the machine should live, but it doesn't. Thank you very much for any help.
  • durchfall
    • Dec 2022
    • 13
    • Czech Republic
    Re: MacBook 2011 A1286 power cycle, no chime
    No ideas? Is there a mistake in my post that nobody comments? Not enough/too much information? I'd like to fix this thing, but it cost me nothing and I'm not willing to put any money into it, so getting it fixed professionally is not an option. So if I can't fix it myself, in the trash it goes unfortunately.
    • mon2
      • 14693
      What is the 820-xxxx number on your logic board?
      What is the voltage to ground of PLT_RESET_L ?
      • durchfall
        • Dec 2022
        • 13
        • Czech Republic
        820-2915-A. PLT_RESET_L is 3.35V.
        • mon2
          • 14693
          What is the voltage to ground of PLT_RST_CPU_BUF_L ?
          • reformatt
            • Feb 2020
            • 1528
            https://www.cmizapper.com/products/t...gpukiller.html
            • durchfall
              • Dec 2022
              • 13
              • Czech Republic
              PLT_RST_CPU_BUF_L is 1.05V
              • durchfall
                • Dec 2022
                • 13
                • Czech Republic
                reformatt, this is way more than I'm willing to invest in this machine, I got it for free after all. Besides, would it even help me? It worked fine with just an NVRAM variable to switch to IGP, it started doing this after RAM upgrade.
                • mon2
                  • 14693
                  There are many SMBUS interfaces / sensors onboard. It almost sounds like that the logic board is attempting to ping some device(s) and then eventually timing out
                  Measure the voltage to ground of each and every SMBUS SCL / SDA line to be sure they are not stuck. Each should be at the voltage applied by the local pull-up resistor as SMBUS is an open-drain specification.
                  Just a thought.
                  • durchfall
                    • Dec 2022
                    • 13
                    • Czech Republic
                    Will give that a try and post my results.
                    Any idea why it doesn't start in SMC bypass mode at all? Fans just twitch once and then you can hear a ticking sound from the board, almost like short circuit protection kicking in.
                    Could it ba a problem that the GPU and VRAM have been physically removed from the board? But it worked in this state before...
                    Is there a way of doing NVRAM reset by shorting pads or something? Wanted to try NVRAM reset, but the machine doesn't respond to command option P R.
                    • dellxps15
                      • Feb 2014
                      • 1598
                      • italy
                      if 5v s4 goes up and down multiple times then it's bios problem, otherwise it some other component.
                      have here 2 same board with same syntom; one has visible big corrosion all over it and the other has multiple repair attempt. another one had manual gmux soldering and now poer on but no video.
                      firse check if 5v s4 come multiple times or just once. ( u need good multimeter to spot the spike).
                      • durchfall
                        • Dec 2022
                        • 13
                        • Czech Republic
                        dellxps15, do you mean PP5V_S4_P18V5S5? That's 0V. We might be onto something.
                        • durchfall
                          • Dec 2022
                          • 13
                          • Czech Republic
                          Never mind, I had J5800 unplugged, after plugging it back in I get PP5V_S4_P18V5S5 and 18.5V boost just fine. It doesn't seem to be jumping, but I don't own a good multimeter, so no way to truly check I suppose.
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            p5vs3_vsw L7220 for spike.
                            • durchfall
                              • Dec 2022
                              • 13
                              • Czech Republic
                              I don't see a spike. It just goes from 0 to 5V, then to 0V again when fans stop, 5V when fans start and this repeats. But like I said, not sure if my crappy multimeter could detect a spike. I have a slightly better multimeter at home, can try that on Monday.
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                some problem with cpu... volt on cpu is 1,15 , but drop to 0.75 ( around) after board power on correctly.
                                bios is ok and all pads are fine ? tried programming bios ( just in case) with a working one ?
                                probably board has bios string to bypass dedicated vga. with a pram maybe it start booting ( with black screen) and do chime, but after that u need to solve vga problem.
                                • durchfall
                                  • Dec 2022
                                  • 13
                                  • Czech Republic
                                  CPU vcore stays at 1.15V even without memory, but does beep. Shouldn't that mean the CPU is ok?
                                  BIOS chip area looks fine, no visible corrosion. I did not ty programming the BIOS, don't I need an image with cleared ME region and modified for my serial number? Sorry if this question is dumb, I've only ever flashed BIOS chips on PCs.
                                  Yes, I wrote this into NVRAM nvram fa4ce28d-b62f-4c99-9cc3-6815686e30f9:gpu-power-prefs=%01%00%00%00. That's all I did as the GPU chip is removed from the board and it did work just fine after this, only after RAM upgrade it started with this issue, first starting after about 10 minutes, now doesn't start at all. Is writing this into NVRAM not enough? Could it boot (to a black screen, but I can VNC in) after NVRAM reset? But how do I reset NVRAM, it doesn't respond to command+option+P+R.
                                  • durchfall
                                    • Dec 2022
                                    • 13
                                    • Czech Republic
                                    Just did some continuity checks for good measure, all pins of the BIOS chip are connected where they should be.
                                    • durchfall
                                      • Dec 2022
                                      • 13
                                      • Czech Republic
                                      Tried flashing the BIOS, tried two different images I found online. It didn't help, the machine acts the same way it did before, so probably not a BIOS issue.
                                      I kinda have a feeling the main symptom I should diagnose is no power in SMC bypass, just a small twitch from the fans, ticking sound from the board.
                                      • resistor83
                                        Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
                                        by resistor83
                                        Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
                                        I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
                                        I thought it was a screen problem but after changing it the problem remains.
                                        What could I do?
                                        09-14-2023, 12:38 PM
                                      • coolshrimp
                                        Apple MacBook Pro 15" 2011 - A1286 (820- 2563) - Board View And Schematics Request
                                        by coolshrimp
                                        I'm hoping to find "Apple MacBook Pro 15" 2011 - A1286 (820- 2563) - Board View And Schematics"
                                        I have a dead one in front of me that was previously repaired I'm trying to revive it.
                                        Thanks,
                                        10-24-2022, 03:55 AM
                                      • resistor83
                                        Macbook pro 15" 2011 A1286 stuttering and slow
                                        by resistor83
                                        hi all, I have a problem with my macbook pro 15 inch, late 2011 with SSD, AMD Radeon HD 6770M dedicated video card and Intel HD 3000 integrated card.
                                        I use the computer occasionally at home and a few weeks ago I noticed that the battery was charging very slowly, I changed the power supply with a new original one and the problem remains. I also changed the battery to a compatible one and the problem persists. Now for a few days I have also noticed that the computer after a few minutes from starting it jerks and becomes very slow. However, this problem arises in several ways:
                                        02-09-2023, 03:19 AM
                                      • meraklinetx
                                        Asus Z97-a power cycle, no boot no cpu voltage
                                        by meraklinetx
                                        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                        05-10-2023, 06:08 AM
                                      • marce002
                                        A1286 820-2915b chime ok, but no image no bklight
                                        by marce002
                                        Hello
                                        I have this a1286 with minor water damage, after cleaned ISL area turns on and chimes , load os but: no image no backlight.... LCD_PWR_EN is 0vol ..
                                        I have done gmux bypass to many a1286s with gpu issues, so though this would be the case. routed jumpers to avoid the gpu and removed resistor r8911 as usual to disable ati gpu... but still no LCD_PWR_EN signal...
                                        what can be going on to not have LCD_PWR_EN enabled? i do have 3.3v in pin 4 at lcd connector but not pins 2,3, because u9000 is not enabled by this missing LCD_PWR_EN
                                        thanks in...
                                        05-13-2022, 03:25 PM
