MacBook Pro A1286 Mid 2012 no power, no LED on the charger
  • Gigabit2
    • Apr 2022
    • 264
    • United Kingdom
    #41
    Re: MacBook Pro A1286 Mid 2012 no power, no LED on the charger
    Okay I was able to find another cable separate from a display, connected it and powered on. Chimed and video showing on external monitor.
    • mon2
      • Dec 2019
      • 14247
      Ok. But I meant to ask if the laptop LCD has a removeable cable - if yes, consider to remove this cable and attach to the logic board only.
      This is to confirm if there is a possible short in the LCD cable.
      With the LCD connected, measure the voltages on the LCD connector J9000.
      Post the readings.
      Do confirm that the following EMI filters are still present and not broken:
      L9010
      L9011
      Voltage readings of:
      LVDS_DDC_CLK ?
      LVDS_DDC_DATA ?
      • Gigabit2
        • Apr 2022
        • 264
        • United Kingdom
        #43
        Post the readings.
        L9010
        L9011
        LVDS_DDC_CLK ?
        LVDS_DDC_DATA ?
        Hi mon2,
        No I could not remove the cable from this LCD but I had a spare LVDS cable that I connected to the logic board without any LCD connected. And I heard chime and saw video on external monitor connected by HDMI.
        L9010 showing .000 on 2V mode on all pins. L9011 showing .000 on 2V mode on all pins.
        LVDS_DDC_CLK showing .000 on 2V mode.
        LVDS_DDC_DATA showing .000 on 2V mode.
        • mon2
          • Dec 2019
          • 14247
          Voltage on pins 2&3 of lcd connector?
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            #45
            Showing .002 on 2V mode.
            • mon2
              • Dec 2019
              • 14247
              So the LCD is not being powered which explains why it is dark & no video.
              See attached. Measure and post the readings for the power rail regulator for the LCD.
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                #47
                LCD_PWR_EN on R9094 measured .012 on 2V mode.
                PP3V3_S5_LCD on C9009 measured 3.32 on 20V mode.
                PP3V3_SW_LCD on C9002 measured 00.5 on 200m mode, .000 on 2V mode.
                • mon2
                  • Dec 2019
                  • 14247
                  What is the voltage of PP3V3_S0_DDC_LCD (measure @ R9010 / R9011 - pin # 1).
                  Power down and remove the LCD - what is the voltage for the above 2 lines without the LCD attached ?
                  • Gigabit2
                    • Apr 2022
                    • 264
                    • United Kingdom
                    #49
                    PP3V3_S0_DDC_LCD measured at R9010 showing 3.3V with 20V mode.
                    LVDS_DDC_CLK showing 3.3V with 20V mode, without LCD connected.
                    LVDS_DDC_DATA showing 3.26V with 20V mode, without LCD connected.
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      #50
                      Sorry might have misunderstood before.
                      LVDS_DDC_CLK showing 3.3V with 20V mode, with LCD connected.
                      LVDS_DDC_DATA showing 3.26V with 20V mode, with LCD connected.
                      Before I was showing resistance to ground with machine power removed.
                      • Gigabit2
                        • Apr 2022
                        • 264
                        • United Kingdom
                        #51
                        Something interesting I did find by accident.
                        R9678 on pin 2 showing 2.64 on 20V mode. Pin 1 on R9678 showing .012 on 2V mode. With power on and LCD connected.
                        • Gigabit2
                          • Apr 2022
                          • 264
                          • United Kingdom
                          #52
                          Hi mon2, is the above at all useful?
                          • mon2
                            • Dec 2019
                            • 14247
                            Remove all power. Meter in lowest resistance scale.
                            Measure the resistance to ground of each pin on the lcd connector with the lcd connected.
                            If the meter shows '1' or 'OL' then use the next higher resistance scale till the resistance value is measured.
                            Post the readings. The list from yesterday does not make sense since it on the voltage scale.
                            • Gigabit2
                              • Apr 2022
                              • 264
                              • United Kingdom
                              #54
                              Pin 1: 01.2 on 200 scale
                              Pin 2: 1.952 on 2k scale
                              Pin 3: 1.952 on 2k scale
                              Pin 4: .0743 on 2k scale
                              Pin 6: .661 on 2k scale
                              Pin 7: 1.811 on 2k scale
                              Pin 8: 1.815 on 2k scale
                              Pin 9: 1.739 on 2k scale
                              Pin 10: 0.01 on 2k scale
                              Pin 11: .462 on 2k scale
                              Pin 12: .462 on 2k scale
                              Pin 14: .461 on 2k scale
                              Pin 15: .461 on 2k scale
                              Pin 17: .462 on 2k scale
                              Pin 18: .463 on 2k scale
                              Pin 20: .462 on 2k scale
                              Pin 21: .464 on 2k scale
                              Pin 23: .462 on 2k scale
                              Pin 24: .469 on 2k scale
                              Pin 26: .461 on 2k scale
                              Pin 27: .463 on 2k scale
                              Pin 29: .463 on 2k scale
                              Pin 30: .913 on 2k scale
                              Pin 31: shows 1. on every scale up to 2M
                              Pin 32: shows 1. on every scale up to 2M
                              Pin 33: shows 1. on every scale up to 2M
                              Pin 34: shows 1. on every scale up to 2M
                              Pin 35: shows 1. on every scale up to 2M
                              Pin 36: 1.418 on 2k scale
                              Pin 38: 0.705 on 2K scale
                              Pin 39: 0.705 on 2K scale
                              Pin 40: 0.705 on 2K scale
                              • mon2
                                • Dec 2019
                                • 14247
                                this looks to be low. can you lower your meter scale to 200 ohms and measure this rail again ?
                                Is this 74R3 = 74.3 ohms to ground ?
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  • United Kingdom
                                  #56
                                  Showing 1 on 200 ohms. Measured again on 2k scale and showing .307.
                                  • mon2
                                    • Dec 2019
                                    • 14247
                                    Ok. Ignore for now.
                                    Pin 30 is showing a different reading than pin 29 on the LCD connector.
                                    Can you measure @ L9011 - pins 4 & 1 ? What are the readings at this junction ?
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      • United Kingdom
                                      #58
                                      Pin 1: .461 on 2k mode
                                      Pin 4: .461 on 2k mode
                                      • mon2
                                        • Dec 2019
                                        • 14247
                                        Now check again AFTER this part so pins 3 & 2. What are the readings ?
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          • United Kingdom
                                          #60
                                          Pin 2: .459 on 2k mode
                                          Pin 3: .461 on 2k mode
                                          • SarcasticOP
                                            General question about MacBook power rails for repair.
                                            by SarcasticOP
                                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                            • PPBUS_G3H (12.6V-12.8V)
                                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                            • PP3V42_G3H (3.42V)
                                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                            • PPVRTC_G3H (3.3V)
                                              • This
                                            12-12-2024, 05:50 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • durchfall
                                            MacBook 2011 A1286 power cycle, no chime
                                            by durchfall
                                            I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                                            What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                                            01-11-2023, 05:56 AM
