MacBook Pro A1286 Mid 2012 no power, no LED on the charger
  • Gigabit2
    • Apr 2022
    • 264
    • United Kingdom
    Got a MacBook Pro A1286 15 here, mid 2012. Doesn't power on and no LED on the charger.
    Looks like some possible liquid damage on the keyboard but board looks okay from a visual inspection.
    Can somebody please kindly help me in diagnosing this one?
  • mon2
    • Dec 2019
    • 14229
    Re: MacBook Pro A1286 Mid 2012 no power, no LED on the charger
    1) Post the 820-xxxx from the logic board.
    2) Are you using a known good and original power adapter for this unit ?
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      Hi mon2 once again
      1. 820-3330-B
      2. Yes - and verified working with another laptop
      • mon2
        • Dec 2019
        • 14229
        Hi.
        See attached. Post the voltage readings for these points with the external power adapter attached.
        • Gigabit2
          • Apr 2022
          • 264
          • United Kingdom
          Hi mon2,
          Great news, I replaced the MagSafe DC in board and system now turning on with bong!
          Sadly, no backlight on the display - have shined light from phone and can see screen, so looks like backlight issue once again?
          Can you help?
          • mon2
            • Dec 2019
            • 14229
            Check fuse @ F8400 - measure the voltage on each side.
            Measure and post the readings of:
            EDP_BKLT_EN
            BKLT_EN_R
            BKLT_SCL
            BKLT_SDA
            PPVOUT_S0_LCDBKLT
            If PPVOUT_S0_LCDBKLT is low and not 25++ volts then remove all power.
            Meter in resistance mode. Check the resistance to ground of PPVOUT_S0_LCDBKLT (L8420, pin # 2).
            • Gigabit2
              • Apr 2022
              • 264
              • United Kingdom
              Hi mon2,
              I cannot see a F8400 fuse on my boardview here.
              I cannot see any references to the components you reference, can you provide some guidance?
              I am using schematic and boardview from: https://www.badcaps.net/forum/showpo...40&postcount=6
              • mon2
                • Dec 2019
                • 14229
                Revised list:
                Check fuse @ F9700- measure the voltage on each side.
                BKL_EN
                BKL_SCL
                BKL_SDA
                PPVOUT_SW_LCDBKLT
                Meter in resistance mode. Check the resistance to ground of PPVOUT_S0_LCDBKLT (D9701).
                • Gigabit2
                  • Apr 2022
                  • 264
                  • United Kingdom
                  F9700 showing 12.5V on one side, 0V on other.
                  Have checked continuity on fuse and no continuity, other side of the fuse is showing as 0.05V to ground so I think this fuse is blown?
                  BKL_EN: 0V on all modes
                  BKL_SCL: 3.3V
                  BKL_SDA: 3.3V
                  PPVOUT_SW_LCDBKLT: .015 on 2V mode
                  • mon2
                    • Dec 2019
                    • 14229
                    Agree - the fuse looks to be blown and should be replaced. Then test again.
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      New fuse ordered, is there any temporary check I can do safely before it arrives to verify? Can I bridge the connection?
                      • Gigabit2
                        • Apr 2022
                        • 264
                        • United Kingdom
                        mon2, D9701 PPVOUT_S0_LCDBKLT showing 00.3 to ground on 200m mode.
                        • mon2
                          • Dec 2019
                          • 14229
                          The fuse is there to prevent an excessive current spike. While tempting, I would wait for the fuse (order some spares) to arrive.
                          The D9701 resistance to ground is not good. Can you use a higher scale on the meter and measure again ? If indeed you are seeing a low resistance like 0 ohms then you have a short.
                          Consider to desolder D9701 and then measure the resistance to ground again of PPVOUT_S0_LCDBKLT. What is the resistance ?
                          The idea is to isolate the 2 legs of the circuit (left / right side) to determine where is the short. The short may be in one of the caps to the right side of D9701.
                          If after removing D9701, you still have a low resistance to ground then remove both caps @ C9797 & C9799 and measure again. If required, remove C9796. Measure again.
                          • Gigabit2
                            • Apr 2022
                            • 264
                            • United Kingdom
                            Thanks mon2, fuses ordered as advised. I will fit with hot air when they arrive, old fuse already removed.
                            I will try the D9701 steps when new fuse fitted.
                            I wonder if the display caused a short, is there any way I can test the screen without causing it to short again?
                            • mon2
                              • Dec 2019
                              • 14229
                              You can try to fix the short without the fuse.
                              Remove the display and check the resistance to ground of the backlight rail. It should not be as low as you have posted.
                              This must be repaired first else the fuse will blow again.
                              Remove the lcd, check the resistance.
                              Then remove the diode and check again.
                              • Gigabit2
                                • Apr 2022
                                • 264
                                • United Kingdom
                                Hi mon2,
                                I replaced the backlight fuse F9700 and showing good continuity. Laptop turning on and backlight now working! Booted successfully as well.
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  • United Kingdom
                                  Should I still do the D9701 steps?
                                  • mon2
                                    • Dec 2019
                                    • 14229
                                    No - I think you are good to go ?
                                    The other tests were only if the backlight still failed to turn on.
                                    Well done !
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      • United Kingdom
                                      Oh no! @mon2
                                      It booted into recovery for reinstall then screen suddenly went black.
                                      Now, powers on with green light on charger but no bong and screen is black. Indicator light on the front of the machine is solid white. Fans spinning
                                      What next?
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        • United Kingdom
                                        Continuity on backlight fuse still looking good so hasn't shorted.
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • durchfall
                                          MacBook 2011 A1286 power cycle, no chime
                                          by durchfall
                                          I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                                          What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                                          01-11-2023, 05:56 AM
