Galaxy Note Pro 12.2 screen flickering,battery connector resolder or?
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys.I guess I'm unlucky user who has this same issue like many are.
    At start it didn't not start to flicker but immediately when battery reaches around 50 % screen starts to flicker (mostly when touching with finger) and then usually if it happens like 50x reboots.
    I did not noticed it happens when is battery like 70-100% charged.
    There are many possible solutions, if there is any,butI really don't have no one to resolder the battery connector,but then again if the battery is bad ofc that won't help.
    There is a picture of the tape put above the battery so don't know if I would try that.
    https://www.youtube.com/watch?v=I7G9SmpVfh8
    Here are some possible solutions:
    https://forums.androidcentral.com/sa...-problems.html
    https://forum.xda-developers.com/t/s...olved.3320711/
    https://forum.xda-developers.com/t/q...ckers.2835337/
    So what you guys think,would resoldering battery connector help?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Galaxy Note Pro 12.2 screen flickering,battery connector resolder or?
    My guess is that your battery is really old an despite it saying you have 50% battery life, there's not enough amps to drive the screen/hw/OS so it constantly crashes.
    I don't think resoldering will help since it's an 8 year old battery. I think you are better off replacing it like below.
    https://www.ifixit.com/Guide/Samsung...lacement/98666
    --- begin sig file ---
    --- end sig file ---
    • paparazzo79
      • Dec 2018
      • 303
      • Bosnia
      The people made posts on same issue for battery 2-3 years old only.
      Check the date of posts.
      People had the same issues after 2-3 years only.
      I don't think this is not an option, it is possible ofc,but then again I purchased to Galaxy Tab S which is 8 year old tablet and no issues with battery at all.
      Check the date of posts on forumxda and androidcentral.
      • diif
        • Feb 2014
        • 6978
        • England
        I'd replace the battery before soldering the connector.
        • paparazzo79
          • Dec 2018
          • 303
          • Bosnia
          I agree.
          You sure I can find one selling on e-bay?
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • silver60618
            Macbook Pro A1990 - Battery not detected after connector torn off
            by silver60618
            Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
            Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
            11-12-2025, 06:36 PM
          • TheDando
            MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
            by TheDando
            Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
            10-28-2024, 06:59 PM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • guruji
            samsung galaxy book 3 np940xfg battery charge
            by guruji
            hello
            I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
            my...
            08-14-2025, 08:12 AM
