Dell E5440 no display output on monitor and VGA BUT works on HDMI!
  • Andreasbest
    • Aug 2014
    • 1153
    • Hellas ( Greece )
    Hello!
    I received s E5440 with small water damage, cleaned it with isopropelene and looks like new.
    The problem is that there is no display on integrated screen neither on VGA output but works great through HDMI.
    Any ideas?
    Schematics and boardview attached, thank you in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell E5440 no display output on monitor and VGA BUT works on HDMI!
    Why not include the measurement on lvds/edp connector pins??
    • Andreasbest
      • Aug 2014
      • 1153
      • Hellas ( Greece )
      Because of the water dage not sure from where you want me to start, i'll do it asap.
      • Andreasbest
        • Aug 2014
        • 1153
        • Hellas ( Greece )
        Hello!
        Sorry for the delay but had other important tasks to complete, now i have it back to the bench.
        The voltages at JLVDS1 are:
        pin2 3.3v
        pin8 3.3v
        pin9 13.5v
        pin14 3.3v
        pin35 3.3v
        pin36 3.3v
        Just to mention the specific laptop has integrated touch screen!
          • 20763
          Originally posted by Andreasbest
          Hello!
          Any ideas?
          Where was the water damage,post a picture of the area.
          • Andreasbest
            • Aug 2014
            • 1153
            • Hellas ( Greece )
            The area right under U38 and left of the connector JTP1
            Attached 2 magnified pictures and 1 with the whole area.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Did you checked RTD2136S requirements. If you have this controller, replace it if you dont want to troubleshoot.
              • Andreasbest
                • Aug 2014
                • 1153
                • Hellas ( Greece )
                I'm not sure if i understand, the problem is on this controller and needs replacement?
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 487
                  • somewhere in europe
                  did you try another screen, voltages on pins 12, 38, 39/40? did you measure pin 9/10/11 with power cable only connected? do you have no display ouput on internal screen at all? is bkl there? or no bkl, but picture?
                  • Andreasbest
                    • Aug 2014
                    • 1153
                    • Hellas ( Greece )
                    No i haven't tried another screen
                    Voltages only on the pins i mention
                    All measurements only with power cable connected
                    No display at all, total black no picture (as far the touch glass allows me to see)
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 487
                      check for requirements for voltages on pin 38, 39/40
                      • Andreasbest
                        • Aug 2014
                        • 1153
                        • Hellas ( Greece )
                        What do you mean "check for requirements"?
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 487
                          follow the circuits and measure the ics/smd components (reverse). check for enable signals/inputs and outputs
                          • Andreasbest
                            • Aug 2014
                            • 1153
                            • Hellas ( Greece )
                            Unfortunately i'm not that expert in repairing circuits, can you please be more specific?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Cannot say without measurements but this controller often fails. So you can try replacing it.
                                • 20763
                                Check all the resistors (resistance in ohms) and blackened caps.Ive highlighted the ones that look bad to me in the picture.Most of them might be ok if you touch them up with a bit of flux and solder
                                • Andreasbest
                                  • Aug 2014
                                  • 1153
                                  • Hellas ( Greece )
                                  Do you want to provide you some measurements to make sure it's faulty or not?
                                  I don't have this controller and i must order it.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1153
                                    • Hellas ( Greece )
                                    bump
                                      • 20763
                                      bump
                                      Go ahead and buy some,they`re quite cheap.
                                      • DanPoka
                                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                        by DanPoka
                                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                        02-15-2025, 05:05 AM
                                      • TheQuentincc
                                        Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                                        by TheQuentincc
                                        I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                                        06-26-2025, 01:44 PM
                                      • Jesus Coder
                                        Issues Reviving Old Dell 2408WFPb Monitor
                                        by Jesus Coder
                                        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                        06-25-2023, 02:33 PM
                                      • CapLeaker
                                        Dell ATX PSU won’t start, but forcing it works fine?
                                        by CapLeaker
                                        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                        10-28-2024, 06:59 PM
                                      • Borse2008
                                        Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                        by Borse2008
                                        Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                        I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                        • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                        • There’s
                                        07-15-2025, 04:55 AM
