820-00840-A CD3215 short
  • powerblackout
    • Feb 2018
    • 109
    Is the CD3215 chip bad if it has pp3v3_upc_xb_ldo at 2.6v and 5.5ohm resistance? I removed C3208 and the ROM chip and the short did not go away. Just checking before I remove the CD3215.
    Meter shows board is pulling 5V 330mA
  • mon2
    • Dec 2019
    • 14209
    Re: 820-00840-A CD3215 short
    Place meter in diode mode.
    Remove all power to the logic board.
    Red meter probe to ground. Black meter probe to each LDO output of CD3215. Post the readings for each output and CD3215.
    • powerblackout
      • Feb 2018
      • 109
      Yep it was indeed bad. I replaced it and am now getting every LDO except for 1.1V. Repair wiki says there could be communication issue between the ROM chip and the CD3215.
      Voltage in MISO is 3.3V, but MOSI is anywhere from 0.8V to 1.2V. Shouldn't both of these be the same voltage for communication to work?
      I removed resistor on MOSI line, still same voltage coming out of CD3215. no short to ground detected between CD3215 and ROM chip.
      • mon2
        • Dec 2019
        • 14209
        It is possible that your instrument (meter?) is unable to properly measure this signal line. Keep in mind that it is a serial communication device interface.
        The line could very well be toggling high(3v3) and low (0v) and the multimeter is unable to properly measure this line. An oscilloscope will be the proper tool to use here or a low cost logic analyzer (some are ~$10-$20 on Aliexpress / Amazon).
        In either case, do you have the proper LDO voltages on every CD3215 device ?
        Ironically on the CD3215 rom, there is a new widget in Asia that offers the full tools to reflash the firmware. Was trying to get it shipped out before CNY but may be too late for now.
        With the replacement, what are the results for the power delivery ? Your box remains @ 5V ? What is the current draw ?
        • piernov
          • Jan 2016
          • 4435
          • France
          TBT/USB-C ROM are standard 25-series SPI EEPROM, no need for anything fancy to flash them, just correct adapter (socket or board) and the dump (can be different between boards and sides, still there's some cross-compatibility).
          • powerblackout
            • Feb 2018
            • 109
            Yes I get proper LDO voltages out of both chips, except for the 1.1V LDO. I'll hook my scope up and see if any traffic is happening.
            All ports are currently 5.17V 0.01A pull. They were close to 5.05V 0.35A before the CD3215 replacement, with the CD3215 getting pretty warm compared to the rest of the board.
            • powerblackout
              • Feb 2018
              • 109
              Ok measured with the scope, I see a bit of traffic happening right at powerup, but none after, sitting at 0.8V - 1.2V
              I plugged the ROM into my reader, I was able to dump it, meaning that the chip itself works fine?
              • mon2
                • Dec 2019
                • 14209
                @Piernov, thanks. Is there a public database of dumps for these models? Thinking it may be worthwhile for the tool for access to the flash dumps.
                • mon2
                  • Dec 2019
                  • 14209
                  Any chance of soldering issues with the replacement ? Lots of flux + hot air and make the BGA dance with a gentle nudge of the tweezers to remove any possible short underneath the device.
                  • nikey22
                    • Aug 2021
                    • 5
                    @mon2
                    aren't these CD3215s supposed to be replaced in pairs from my recall?
                    Also pay special attention to the actual part number:
                    CD3215B03 will not work in place of a CD3215C00
                    • powerblackout
                      • Feb 2018
                      • 109
                      Yes, mine are CD3215C00 and I replaced them with the same model #
                      It's certainly possible I didn't install it correctly, this is the first CD3215 I have done.
                      I ordered 2 off of ebay https://www.ebay.com/itm/193840530946
                      I tried reflowing the first replacement, then removed it and tried the 2nd replacement. Very careful to clear all solder from pads, using amtech flux, heating until they dance, giving a very very gentle nudge. Both replacements have behaved the same.
                      I have a CD3215 stencil ordered but it is not here yet.
                      Could the ROM be corrupt? Where could I find a replacement ROM file to flash?
                      • mon2
                        • Dec 2019
                        • 14209
                        Personally do not have enough experience with the CD3215 / 3217 devices, yet. From assorted readings, it is a custom Type C controller deployed by TI. TI has many public documents on similar devices.
                        Can the firmware not be applied over the CCx lines ? Did read about the UART interface.
                        Will be really nice to not have to desolder the flash device and just program it in-circuit.
                        On the firmware / ROM corruption - my thoughts exactly but not sure if there are public dumps of the flash for the assorted models. The tool in Asia is likely the usual flash programmer but I think they also implanted the mix of the flash dumps. Unless shown otherwise, it may be a good investment - just to get our hands on the flash rom dumps.
                        However, the heating up of the CD3215 should be investigated as this may be a soldering issue.
                        • powerblackout
                          • Feb 2018
                          • 109
                          That was the original issue, the CD3215 heating up. After replacement it no longer heats up, 5V 0.01A on the ammeter.
                          Am I correct that PPBUS_G3H should be 0V without the battery connected at this point?
                          • mon2
                            • Dec 2019
                            • 14209
                            What is PPBUS_G3H with the external Type C adapter connected ? Leave off the battery ?
                            Is it 0V ?
                            What is PPDCIN_G3H with the external power adapter ?
                            Remove all power. Meter in resistance mode (2k is ok).
                            Check & post the resistance to ground for F7000. Is it a low value ?
                            If yes, then you have a bad cap on this rail and is causing U7000 to turn OFF.
                            If you see a low resistance on PPBUS_G3H rail, consider to remove F7000 off the board. Then check the resistance again on the pads of F7000.
                            Is the low resistance on the PRODUCER side (ie. U7000) or the CONSUMER side (downstream rail = F7000, pad # 2) ?
                            If you find the resistance is OK (not too low) on F7000, then check the DC voltage on:
                            SMB_SMC_CHGR_SDA
                            SMB_SMC_CHGR_SCL
                            These are the I2C (SMBUS) communication lines used to configure U7000.
                            • powerblackout
                              • Feb 2018
                              • 109
                              PPBUS_G3H is 0V when the battery is disconnected and Type C adapter connected. 2.3Mohm resistance when disconnected
                              PPDCIN_G3H is 5.18V with external power. 4.8kohm resistance when disconnected
                              F7000 is 0.6Mohm resistance to ground on both ends.
                              My board doesn't have SMB_SMC_CHGR_SDA or SMB_SMC_CHGR_SCL
                              I'm not familiar enough to know if that is a typo or if I'm searching incorrectly lol!
                              EDIT: PPVIN_G3H_P3V3G3H is 4.8v while the PPCIN_G3H_CHGR_R is 5.17v, is that a problem, the voltage drop across the diode?
                              EDIT 2: Reflowed U7000 now getting 0.1V on PPBUS_G3H and PPVIN_G3H_P3V3G3H is 5.05V
                              • mon2
                                • Dec 2019
                                • 14209
                                These are good readings. No shorts on the inspected rails.
                                The SMBUS (I2C) interface pins are linked to the U7000 regulator.
                                See attached. Proceed with great caution as these are very tiny parts but you should be able to locate a sweet spot to take your measurements.
                                To confirm, your board is 820-00840-A ?
                                See attached on some test pads on this logic board for the SDA & SCL measurements.
                                Attach your external Type C adapter and very carefully check the voltages for the SCL and the SDA pads. Post their values.
                                • mon2
                                  • Dec 2019
                                  • 14209
                                  Yes, a diode does have a voltage drop. Not uncommon to have upto 0v6 of a drop from input to output.
                                  As an alternate confirmation of the diode area, remove all power - meter in resistance mode (2k is ok). Check the resistance to ground of PPVIN_G3H_P3V3G3H. If the reading is low then there could be a shorted cap here but you have 4v8 so that is not a bad reading.
                                  Next, configure your meter in DIODE mode.
                                  Black meter lead on pin #3 of D6905; Red meter lead on pin # 1.
                                  Then reverse the meter leads.
                                  Check again with pin # 2 of D6905 & #1 of the same dual diode.
                                  Post each reading.
                                  Finally, confirm the VOLTAGE reading @ PP3V3_G3H which is the output of L6995, pin # 2.
                                  • powerblackout
                                    • Feb 2018
                                    • 109
                                    Yep 820-00840-A
                                    Oh It's SMBUS not SMB my bad.
                                    Both SDA and SCL are 0v
                                    PP3V3_G3H is now 0v.. it was 3.3 before.. hmm Maybe when I reflowed U7000 I messed up the pins underneath, causing the enable for 3v3 to not work.
                                    • mon2
                                      • Dec 2019
                                      • 14209
                                      If you have reflowed U7000 then consider to apply flux onto the top side of the device -> high heat -> medium amount of air and allow for the balls underneath to melt naturally. Do NOT press down on the top side of the IC as this will squish the solder balls and make a mess.
                                      Keep moving in circles on the top of the device till you can see the balls sink down - naturally - test the condition using tweezers across 2 edges (corner).
                                      With a very gentle nudge, the IC should 'dance' and then spring right back to their proper position on the pads. Repeat this once or twice to confirm the balls are being corrected with this process and they will bounce back on their own.
                                      If you push too hard with the tweezers, then U7000 will end up in your neighbor's backyard. Just take your time here.
                                      The above should remove any solder faults underneath U7000.
                                      After this, allow the board to cool. Do not apply power.
                                      Check the resistance to ground of the SMBUS SDA & SCL lines.
                                      Post the readings.
                                      • powerblackout
                                        • Feb 2018
                                        • 109
                                        Ok reflowed 2 more times and I have PP3V3_G3H again.
                                        Now that it is back, the SDA and SCL lines are at 3.2V and I see them jumping around about once a second (meaning traffic?)
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
