MacBook Pro 16" A2141 charge issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Hello, received a logic board and repaired the USB C Chips (2x CD3217 B12 Chips) and voila board got twenty volts and turns on with it connected to the battery, however the board is not charging or even recognizing it is connected to a power source, it does work with the USB C dongles and notices the ethernet USB c dongle we connected and lucky for us the Battery had 90% health and it is a good battery because we charged it from another A2141 board. Now this is what I see when connected to the power source
    Not connected to battery
    20V
    .08 Amps
    when connected to a battery
    20V
    0.00 Amps
    A little guidance will def help me repair this issue and know how to fix more common issues like this.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14020
    Re: MacBook Pro 16" A2141 charge issue
    Hi.
    Post the voltage readings for:
    I2C_PWR_SDA
    I2C_PWR_SCL
    Killed 8 hours a few weeks ago to locate that the fault of a similar case was the TVS diode on the I2C lines (U6950). After removing this part, the battery was able to charge up fine. Arrow carries these parts but check the voltage on the lines first.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Thank you! Will check this line here shortly this week! I will post my results.
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Following up
        U6950 only gets 1.79volts on top pins 1 and 2 and 0 on 3 (ground) . I am assuming this is a bad diode?
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          I2C_PWR_SDA . 1.79V
          I2C_PWR_SCL 1.79V
          On both lines.
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 667
            Removed, ISL9240 seems fine.
            sigpic
            • mon2
              • Dec 2019
              • 14020
              Your I2C_PWR_xxx lines are good - see attached. These open-drain lines are pulled to 1v8 so no issue here.
              Yes, for sure if the ISL9240 is damaged then this is of concern. Aliexpress has these. Would have thought that Louis carries them by now but do not see them on his website.
              I am pretty sure we have them here so if you are in immediate need, can work out a fair price. We have a negotiated deal with Fedex @ $ 15 USD (commercial address) or $20 USD (residential address) = 2 day delivery to you. Send me a PM if in need of the ISL9240. Recently purchased a batch of these and I think they are now in the building.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                I ordered IS9240 from Mobile Sentrix they have them in stock now. Fairly cheap too. But I removed the idea the ISL9240 could be the culprit and it looks fine actually. Unless it is bad which it does hold the charge portion for the board which I am not surprised if it is.
                sigpic
                • mon2
                  • Dec 2019
                  • 14020
                  I would not trust the old ISL9240. I had ask Mobile to carry this device - guessing their search engine is not working so well to locate the device.
                  Can you post the link to the Mobilesentrix for the ISL9240 - unable to find it, so far.
                  OMG - Mobile Sentrix has different inventory for the USA website vs. the Canadian website. Not right. Will ask them...
                  Crazy that the USA website has the part.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 667
                    Ok so all checks out then and a bad ISL 9240 i Guess. I ordered 2 of them from Mobile Sentrix since these parts are very delicate.
                    sigpic
                    • mon2
                      • Dec 2019
                      • 14020
                      Good idea. Jealous that the USA website stocks more of the goodies than our local branch. Need a layered motherboard tester for the Iphone X to fix the camera / face ID / torch functions but they have the very old model in stock in Canada. Guess will buy it offshore from Qianli.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 667
                        Yeah. I already am assuming you have a business account with them since you can order from there. They wont let regular buyers register unless you have a legit business license like us. But yeah man ordered 2 and a few more goodies. We have so many computers in stock its not even funny...I am swamped to my neck.
                        sigpic
                        • rounin
                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                          by rounin
                          🛠 Original Issue
                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                          04-19-2025, 01:18 AM
                        • Stephen
                          A2141 MacBook Pro 16" lid sensor issue.
                          by Stephen
                          Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                          11-01-2024, 03:45 PM
                        • cheebster
                          MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                          by cheebster
                          Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                          Nand voltages are missing.
                          I've found no shorts at all so far, no signs of heat via thermal camera either.
                          PPBUS_G3H 12.31
                          PP3V3_G3H_RTC 3.387v
                          PP3V3_G3H 12.31v
                          PP2v5_NAND_SSD0 0v 58 ohms
                          PP2v5_NAND_SSD1 0v 57.8 ohms
                          PP1v8_SLPS2R 1.8v
                          PP1v1_SLPS2R 1.1v
                          P3V3_G3H_SOCPMU 3.37v
                          PP0V9_SLPDDR 0.9v...
                          10-11-2023, 11:31 AM
                        • saisoni20
                          macbook A2141 - SOUND ISSUE
                          by saisoni20
                          hi ,
                          I have A2141 macbook with sound issue. Left speaker is working ok but right is not working.
                          After running sudo command it is working good and after sometime is shutoff.
                          Anyone facing this kind of issues before?
                          05-26-2023, 07:18 PM
                        • Stephen
                          A2141 MacBook Pro 16" Turns on but no life, holds charge.
                          by Stephen
                          Customer computer came in, did a DFU revive, no luck, gives error, swapped out battery with two known working batteries still no luck. Board gets 20Volts, raises up to 1Amp then restarts, track pad clicks etc. Tried DFU restore, informed the customer that data recovery is most likely not possible since it didn't give us a revive and DFU restore was the next method to save the board, however it looks like not even DFU Restore is working as well. What could be causing this? I am assuming this is the infamous A2141 flaw that has the flawed Data lines that fail? Any suggestions would be great...
                          05-13-2024, 10:21 AM
